      07-29-2019, 06:45 PM   #1
05X3lover
Drives: '15 Dark Gray X1 AWD
How do I charge my phone with the ignition off?
Hi everyone, I cannot figure out how to charge my iPhone with the ignition off in my wife's '15 X1. On a keyed ignition, you just put the key in the run position, and the cigarette lighter charging port charges the phone.
But the key fob ignition only seems to have 2 positions: ignition on and car running, or ignition/car off and the fob still in place, which allows the stereo to work. When I turn it off though my phone charger immediately stops working.
So how do I charge the phone with the vehicle not running? TIA.
      07-29-2019, 08:35 PM   #2
kringer2
Drives: 2014 X1 28i xdrive
Without adding an USB hardwired or re-wiring the accessory outlet you cannot. As far as I know you would have to wire it to an always hot fuse behind the glove box.
      07-30-2019, 03:51 PM   #3
mreric
Drives: 2015 BMW X1
just carry a portable battery back. keep it charge while you drive. charge your phone phone when car is off.
take it with you when you need it on the go.
      07-30-2019, 04:19 PM   #4
05X3lover
Thanks for those replies, I appreciate the comments. I'll get a portable battery pack as recommended.
