      04-18-2017, 10:17 PM   #1
odieman23
Drives: BMW X1 xDrive28i M-Pkg & HK
Wide tires for 19" M Pkg wheels
Hello fellow X1 drivers;
I'm here to find out, who has different tire size than the factory one, or for those that have wider tires.
Well My X1 came with:
(Pirelli P Zero Run Flat)[220 AA A]
225/40R19 in the front {26.1" overall diameter}
255/35R19 in the rear {26" overall diameter}
I want to put wider tires on those (8" front and 9" rear wheels) but so far, I am interested in:
(Bridgestone Turanza ER 300 RFT)[320 A A]
245/40R19 in the front {26.7" overall diameter}
275/35R19 in the rear {26.5" overall diameter}
So I was told by a tire expert that the "overall diameter" is a factor and in this case. That the difference between from and rear height can't be much (in this case is (0.2 on the possible new ones). Now
Now being that they are wider (20mm added), I wonder if someone has 245 in the front and 275 in the back? Please share specs and pictures if possible.
Also, if someone has 20" wheels please share specs and pictures if possible
      04-19-2017, 08:30 AM   #2
hardparker
Father of Frankenfold
318
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
I plan on running those exact same sizes as soon as the Pirellis on our X1 are toast. The diameter difference is negligible and shouldn't cause any issues. Same for the minor differences in height and width. Should fit fine and give a little more sidewall to reduce ride harshness.
      04-19-2017, 10:44 AM   #3
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
I got 245/35R20 and 275/30R20 on my X1 lowered on KW V3 coilovers with no issues
      04-19-2017, 11:31 AM   #4
PrematureApex
Why so much tire? Looks? It's a ~250 bhp car afterall.
Just one word of caution, 245s on 8" wheel and 275s on 9" wheels is right at the recommended minimum widths (which isn't a big deal), but be prepared to lose some steering feel and turn-in sharpness.
Going that wide on relatively narrow wheels, I'd want put a pretty stiff tire on there, as a softer one is just going to make that aspect worse.
How about a 235/265 combo?
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      04-19-2017, 11:48 AM   #5
Gamb1t
Gamb1t's Avatar
Drives: X1, TM3LR, Solstice GXP, RX-8
^+1.
You will certainly lose some steering feel and sharpness. Plus don't forget increase in unsprung weight.
For AWD vehicles.... it's hip to be square.
I read that BMW's transfer case has low tolerances (vs other AWD cars) when it comes with tire diameter differences.
      04-19-2017, 07:55 PM   #6
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
Originally Posted by Gamb1t View Post
^+1.
My X1 came with staggered wheels... and when I went wider I actually got more steering response and sharpness.
      04-19-2017, 08:16 PM   #7
GTony
Australia
28
Drives: 2015 X3 F25 XDrive 28i M Sport
+1 on PrematureApex's 235/265 Combo.
      04-20-2017, 07:04 AM   #8
PrematureApex
How do you make this statement without letting people know that you:
1. Moved to 20" wheels (shorter sidewall, helps turn-in); and
2. Moved to 9" wheels up front and 10" wheels in the back
So nothing like what the OP is talking about.
      04-20-2017, 08:42 AM   #9
m3_tristan
Be Original.
m3_tristan's Avatar
Drives: 2011 E90 M3
If you read his whole post he asked for people running 20s
      04-20-2017, 11:32 AM   #10
Gamb1t
Gamb1t's Avatar
Indicates great desire that leads to action.
I am interested to see photos of Kittens in Mars.
I guess the M sport staggered tires are marshmallows that wider tires would actually be an improvement on steering response and turn-in.
Go wide if you are traction limited. Note that with wider rears you will induce more FWD-like understeer. It's ok if oversteer freaks one out.
      04-20-2017, 12:40 PM   #11
PrematureApex
Oh come on.
Just about his entire post is about wanting to run 245/275 on his stock 19s, and asking for opinions on that setup. That's the setup we commented on, handling wise.
He asked for pics of people running 20s, that's all.
Regardless, it doesn't change the point. The fact that you moved to 20s and wider wheels were critical pieces of information to go along with your allegedly improved turn-in given the context of the conversation (turn-in moving to wider tires on his current wheels).
      04-28-2017, 09:02 PM   #12
Ry3k3r
Ry3k3r's Avatar
Drives: 2015 X1 X28i
Hmmm Pussy on Mars eh...? Well who doesn't want to see that..?
When I was looking for my setup (sorry only on 19" diameter) I read that it has more to do with circumference of the wheel/tire set up rather than just the diameter. In Europe the tire setup has to be within 3% of each other by law and I believe BMW require it to be a little tighter than that (I read 1% on a European forum, just wish I could remember the name of it... ).
      05-03-2017, 06:10 PM   #13
GTony
Australia
28
odieman23,
Recommended 8" MIN.215 - IDEAL 225/235 - MAX. 245/255.
9" MIN.235 - IDEAL 245/255 - MAX. 265.
Ry3k3r,
They say to Stay within 3% of the ORIGINAL Tire Diameter.
When you have, or change to STAGGERED Fittings they have to be less than 1% of each other, which i think Includes xDrives for all fittings.
You can Mix and Match Various Combo's on these.
www.tirerack.com - www.1010tires.com - www.willtheyfit.com
Hope this further helps.
      05-03-2017, 06:28 PM   #14
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Running 19s. 235/35 on 8.5" 35mm ET front, and 275/35 on 9.5" rears had choice of two ETs, and chose wrong @ ET15. They stick out a little. If I can just curb the rears, maybe I'll have an excuse...
      05-04-2017, 05:51 AM   #15
escape3361
Drives: X1 2.0d
My X1 with 245/40R29 & 275/35R19
Hi there,
Below are puctures of my X1.
The wheels are OEM Style 128 :
Front 8 x19 with Toyo T1S 245/40R19
Rear 9.5 x 19 with Toyo T1S 275/35R19
      05-04-2017, 09:15 AM   #16
Alfisti
Drives: 2008 Saab 9-3 Combi
I still think 19's mean you run too little sidewall for the way these cars are sprung, 18's work better imho.
      05-04-2017, 10:05 AM   #17
jinda
jinda's Avatar
23
Drives: 2013 X1 xDrive35i M Sport
Both 35%? That should give you huge difference in overall wheel Ø right?
Like 647mm F and 675mm R?
2013 X1 x35i M Sport
Past: 2011 Mazda CX7 AWD Sport | 2004 BMW 330i ZSP/ZPP | 2008 Hummer H3 | 2005 Honda Civic VTi | 1997 Honda Civic ESi | 1996 Nissan Sentra SS EXi
      05-04-2017, 04:29 PM   #18
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
You are correct. I do remember the difference in diameter is .1", with the fronts being slightly taller. Next time I'll look...they might be 40 series.
I went from stock 18x8 RFs, and got Conti Extremes,(not RFs) and they ride better than stock, not that it's much of an improvement.
      05-04-2017, 08:29 PM   #19
hardparker
318
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
Originally Posted by escape3361 View Post
Hi there,
That tire size looks perfect to me. Nice and meaty.
How does it drive in terms of comfort and handling? Can you take a shot from the rear, down low, to see how the 275s look from behind?
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
      05-05-2017, 09:48 AM   #20
jinda
jinda's Avatar
23
28mm difference is 1.1" on overall diameter not just 0.1". That's a huge difference if that's true. Isn't that bad for the transfer case?
      05-05-2017, 11:11 AM   #21
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Read my response. I already said I may be wrong about the front tire's aspect ratio, so I checked. 245.40/19 FR and 275-35/19 rears. .1" difference.
