      07-31-2016, 02:46 PM   #1
baz4270
Drives: 2010 X1 2.0D SE
Bluetooth
Hi
Just brought an X1, and very happy with it.
I have got the sat nav with aux in function, and USB port. I have also got all the telephone buttons but no Bluetooth connection function
Has any one fitted a Bluetooth unit? And so where is it located on the car?
Any help would be much appreciated.. 👍🏻
Barry
      07-31-2016, 03:00 PM   #2
Njerts
Drives: x3 m40i
You should see some pairing option if you go the the phone menu.
      08-01-2016, 02:17 AM   #3
baz4270
No Bluetooth option unfortunately 🙁
      08-01-2016, 05:11 AM   #4
RENT-A-GOAT
RENT-A-GOAT's Avatar
Drives: F31 320D Xdrive Msport+
What model year is your X1 seems very odd it hasn't got BT with the nav etc
[url=https://www.deutschespeed.com/threads/the-bimmerpost-refugee-thread.561/]Click here for the Bimmerpost UK Refugees - Censorship Sucks![/url]
      08-01-2016, 10:29 AM   #5
baz4270
It's a 2010 model.. 👍🏻
      08-01-2016, 03:15 PM   #6
P@shencia
Drives: BMW X1 x20d 2010
Do you have usb/aux-in or only usb at glove box?
If you have usb/aux you have combox, and you can see under the floor in baggage. If it's true, you need bt antenna and coding
      08-01-2016, 04:16 PM   #7
baz4270
I have the aux in by the gear stick and USB port in the glove box. I am guessing I can't install the Bluetooth receiver. 😔
      08-01-2016, 04:44 PM   #8
P@shencia
You can, but you need:
- combox media
- microphone
- usb/aux
- bt antenna
- mounting plate(2 different types: under steering column or under floor in the trunk)
- most optical cable
- hsd cable for usb
- wiring for microphone, aux, power
- mounting and coding
      08-02-2016, 05:51 AM   #9
baz4270
Ok thanks for info 👍🏻
Might just have to live the loudspeaker on my phone for calls 😄😄
Sounds like a bigger job than just sticking in a Bluetooth receiver....
      08-02-2016, 06:50 AM   #10
RENT-A-GOAT
If you don't mind a non factory solution have a look at the parrot systems very good less install work and can be used with steering wheel controls too.
      08-02-2016, 08:27 AM   #11
baz4270
Ok that sounds like a better option for me! Thank you, will have a search around and see what comes up 👍🏻👍🏻
