      05-25-2016, 07:20 PM   #1
Ndx
Drives: 335i
X1 Xenon retrofit ...
Hi Guys,
I have an X1 with Halogen lights...
I purchased non AHL Xenon Headlights from EU.
I plugged them in .. HALO RINGS + EYEBROWS ( Work but flash )
Blinker is working OK
Xenon not turning on, I might have bad bulbs or ballast .. but maybe I need to change some wiring before that will work ?
Does anyone have any experience with this ?
thank you
      05-25-2016, 07:27 PM   #2
Njerts
Drives: x3 m40i
Have a look at this post in the DIY section on the same topic:
http://e84.xbimmers.com/forums/showthread.php?t=1226068
      05-26-2016, 11:07 AM   #3
Ndx
Drives: 335i
Woow thank you very much ... so I really just have to add ground to the connector ( bridge ) and that's it ?
Thank you!
      05-26-2016, 11:18 AM   #4
Njerts
Drives: x3 m40i
Thank you!
I think so.
For the halo rings you need to code off voltage monitoring.
You can use BMWhat for that.
      05-27-2016, 11:29 AM   #5
Ndx
Drives: 335i
Added pin in the plug and jumped it to ground ...
Xenons are alive ....
But I dont get high beam... anyway to code or white shutter ?
Thank you
      05-27-2016, 02:26 PM   #6
Njerts
Drives: x3 m40i
From the pins it should be driven by pin 5.
Does it show any faults?
      05-27-2016, 02:33 PM   #7
Ndx
Drives: 335i
I don't think that pin 5 is wired in harness I will check
I didn't code xenons yet maybe thats the issue
Thx
      05-27-2016, 02:49 PM   #8
Njerts
Drives: x3 m40i
The plot thickens...
I found more info for you:
http://www.e90post.com/forums/showthread.php?t=695805
It seems you need to switch pin 5 and 6 (I did not know this)
      05-31-2016, 12:48 AM   #9
Ndx
Drives: 335i
That did the trick .. it does power the shutters ! thx
With car ON ... Xenon igniter flickers ...
Once I coded car with $522 VO ... Xenon IS OK, Bi Xenon is OK ... but I lost angel eyes ...!
No idea ... if I need new FRM or power in FRM is now supplied somewhere else
      05-31-2016, 12:51 AM   #10
Njerts
Drives: x3 m40i
Have you coded DRL to angel eyes?
      05-31-2016, 10:50 AM   #11
Ndx
Drives: 335i
nope, but wouldn't be that by default ?
I think I might need FRM 3 that supports xenon and move some pins on FRM ...
I wonder if I could take 12V from IGN ON and feed directly to AE's
thoughts ?
      05-31-2016, 12:12 PM   #12
vstolpner
Drives: 2019 F39 X2 m35i
thoughts ?
You could certainly put in a controller which bypasses the ECU altogether and goes straight from the battery. Just in this case you won't be able to control them through coding. Also, the car will try to run something else as DRL's, and if you're coming off of a halogen setup that would be high beams. So you would still have to code that out unless you want to run high beams all the time or burn out your HID ballast.
      05-31-2016, 01:42 PM   #13
Ndx
Drives: 335i
I guess I can disable any DRL's in FRM ... and supply pin 1 with 12V... but where to hook up to 12V ...
      05-31-2016, 03:33 PM   #14
Njerts
Drives: x3 m40i
The E90 guys connect pin 1 and 7.
I suggest you measure 7 to see if it had power.
Not sure it it will work:
Quote from that page:
Join pin #1 to pin #7 to get the 3 LED's to function, they will turn on whenever your angel eyes are on. All wiring can be done inside the headlight with wiretaps (since the headlight harness won't have a wire for pin 7 on a non LCI car) and is completely reversible.
      05-31-2016, 04:30 PM   #15
vstolpner
If you're looking for a straight source from the battery then there's the jump start post on the passenger side towards the back of the engine compartment (look for the red cap). That's a straight connection to the battery as far as I'm aware.
      05-31-2016, 08:47 PM   #16
Ndx
Drives: 335i
Progress .. I moved around pins on FRM and rings are ON.. but flickering ...
Xenons not igniting for some reason .. maybe bad bulbs ...
Ordered new bulbs ...
Any ideas how to get rid flickering
my FRM is "AHL" what does that mean ?
      05-31-2016, 09:09 PM   #17
Njerts
Drives: x3 m40i
Normally turning off voltage monitor will stop flicker on LED's also setting it to max brightness to make sure the FRM does not use PWM to modulate intensity.
      05-31-2016, 09:28 PM   #18
vstolpner
Your bulbs may be just fine. Identify the power wires for the lights and connect them directly to a 12V source (like the battery) capable of 50-60W. If they light, your bulbs and ballasts are fine, if not, well....
      05-31-2016, 09:49 PM   #19
Ndx
Drives: 335i
Thx guys .. I have new bulbs on the way anyhow because these were mixed set pretty old ...
I need find a guide on coding the power options thank you
      06-02-2016, 08:02 PM   #20
Ndx
Drives: 335i
Hey
I finally completed the retrofit.
Everything is working as expected.
Didn't need to replace FRM... x1 came with AHL module... so I highly recommend checking before ordering new one
I didn't use harness just the stock cables moved at the plug and frm.
I didn't install leveling sensor ... but that's a piece of cake.
Thank you to everyone here that was helping.
I will write up how to ... shouldn't take longer than 2hrs to install everything
      06-02-2016, 08:12 PM   #21
Njerts
Drives: x3 m40i
Great, I am glad everything worked out in the end.
      06-02-2016, 08:31 PM   #22
Ndx
Drives: 335i
I'm more then happy to ... that I didn't have to improvise and all is stock ... no weird wiring or coding
