      09-04-2015, 06:37 AM   #1
tuanvo1982
Australia
Drives: BMW X1 xdrive20d 2010
My USB works (non-idrive) :happyanim:
I got issue with USB showing "Insert" and tried to search on Google and many forums. I tried to format the sticks in FAT and FAT32 but still no luck.
Today, I found 5 Usb sticks with different size (256M, 2G 32G 4G 8G) and version 2.0 3.0.
Finally the Kingston DataTralver 2G works perfect. I also put my Android phone(samsung galaxy alpha 16G) in and it works(take 2-3 second longer to load music). All music load in screen of radio (I don't have idrive+ navigator, my car is e84 xdrive20d 2010 and radio system is professional). The button on steering wheel works Perfect!!!!
      09-04-2015, 04:01 PM   #2
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
I'm glad that worked for you. I found a program called Double Twist, that was a free download, and I took my non- working 16G Sandisks and loaded the new program. Now these memory sticks work with my '13 pro model, non-idrive.
      09-04-2015, 05:18 PM   #3
tuanvo1982
Australia
It is very interesting about Double Twist. Could you please tell how what the new program which you loaded in to usb? and what did you do with Double Twist?
Cheers
      09-09-2015, 02:07 PM   #4
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
It's just a free app, and you drag and drop it into your opened flash drive. You have to make sure your settings on your head unit have check marks on both album and song to get true random.
      09-09-2015, 06:32 PM   #5
tuanvo1982
Australia
YEAH... I made it work even with USB 3.0 Now I plug the 32G USB 3.0 and it works. The main trick is if you change usb then need to turn off/on the radio in order to clear the buffer/cache of radio.
      09-10-2015, 01:55 PM   #6
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
Good tip, thanks!
      09-10-2015, 11:55 PM   #7
Teutonic
Teutonic's Avatar
They simply need to be FAT in order to work.
      09-11-2015, 06:35 AM   #8
tuanvo1982
Australia
FAT32 in my case is still working bit rate is 320 I have not tried lossless
      09-11-2015, 01:34 PM   #9
zeevette
Unllicensed
zeevette's Avatar
Drives: 2013 X1 35i
The flash drives I use are already FAT32 format, and random wouldn't work on mine until I added the DT program.
      09-11-2015, 05:58 PM   #10
tuanvo1982
Australia
My FAT32 works with RND mode but only random in the folder which I chose
      09-12-2015, 12:40 AM   #11
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
My 64 gb works with NTFS. Tried extFat32 bit didn't work.
      09-13-2015, 07:01 AM   #12
tuanvo1982
Australia
Try with Fat32 which is different from extfat32 :P
