08-17-2015, 06:04 PM | #1 |
Rep 36
DIY - X1 Phone cradle removal needs help
Hi there,
I try to disassemble the armrest in order to remove phone cradle. However, my X1 x20d 2010 does look the same as any instruction on this forum. Anyone knows how to de-attach the cradle please help me. - I could remove the back of armrest as you see in the photo - Remove the top one as well but the armrest and the cradle seem to be a whole unit. I try to put a pin which connect them together from left to right and right to left but does not work at all. Thanks |
08-17-2015, 06:36 PM | #2 |
Rep 280
I never really looked at these adapters before, but HOLY CRAP are they crazy expensive. Upwards of $200 for a glorified usb cable? Are you kidding me?
Sorry I don't have anything helpful. Worst case, you can always take a Dremel to it. Good luck! |
08-17-2015, 06:51 PM | #3 |
Rep 36
Anyways Cheers mate, the worst case I will chop/break it off simply and de-attach the cable.
08-17-2015, 08:20 PM | #4 |
Rep 2,404
Hit the pin harder. Seriously...iirc it eventually popped out.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
08-17-2015, 08:41 PM | #5 |
Rep 36
08-18-2015, 12:28 PM | #6 |
Rep 2,404
I pushed from the right side to the left. Had to give it a bit of elbow grease to get going, but after that, it was easy.
08-21-2015, 07:44 AM | #8 |
Rep 18
http://www.bimmerfest.com/forums/sho...=735489&page=2
Originally Posted by Hen49 How safely remove phone cradle. 1. Move forward front seats to max. Easy 10min job. I use 2 flathead screwdriver mid & small. 2. Start right bottom of back panel center console (with cigarette lighter). 3. Release snap clips (vertical grove) there are 3 clips on both side. 4. Slide forward the center armrest. 5. Pull back panel center console upward. 6. From right side push axle-pin. 7. From left side pull pin like 4 inch don't remove it. 8. Open cubby and remove phone cradle. 9. Reverse process. Done. One more cover hole inside cubby use thin cardboard or plastic + super glue. Maybe some made few pics and better description how remove back panel of center console. It took me over an hour, but mainly because I struggled on disconnecting the wires. Removing the back cover was no problem using a flat screwdriver to start the process. I used a nail set and a mallet hammer to start pushing the axle pin toward the drivers seat. Removing the blue/pink cable was no problem since the release lever was fairly obvious. Removing the pink/black cable was difficult until I found that I had to remove the pink cover in the photo below. I pried it out with a flat screwdriver. The release is under this cover. |
08-22-2015, 07:04 AM | #9 | |
Rep 36
08-22-2015, 12:09 PM | #10 |
ATAP
Rep 165
Look closely at the pin. One side of the pin has grooves in it, similar to the hinge pins on the doors.
The grooves are what lock it in place. It needs to be whacked out, pushed from the opposite side which is tapered. BTW, I did it the wrong way and it still worked, just a bit harder. Last edited by Alanintx; 08-22-2015 at 06:48 PM.. |
08-22-2015, 07:00 PM | #11 | |
Rep 36
08-14-2020, 11:05 AM | #13 |
Rep 13
It's been a long time since this thread was active, but I thought I'd add that there is a cap you can put in the hole that is there after removing the phone cradle if you want a more finished look.
PN: 51-16-2-991-863
Dres
solidsleeper28.50 |
12-13-2020, 09:28 PM | #15 |
E46 Fanatic
42
Rep 152
Thanks, that oart number is correct.
I ordered that part and it fit the hole perfectly on my 2013 X1 sDrive28i. Thanks for posting the part number!
