      11-12-2014, 11:56 PM   #1
Teutonic
Teutonic's Avatar
SOLVED: How to use large capacity USB Flash Drive for your audio collection
Hello all,
I always wanted to use a flash drive as my main audio source instead of connecting my iPod or phone on the USB input. I wanted to eliminate any temptations from all kind of curious individuals that peak inside my vehicle, and not worry to connect, disconnect, forget the phone in the car, etc.
These days, you can get USB flash drives no bigger than a thumb that will easily offer you 64Gb or larger capacity, which will allow to take in your vehicle a lot more albums, or maybe even your whole collection.
There were however many complaints from the users that BMW does not accept flash drives (or thumb/stick drives) that are bigger than 32Gb. The explanation is that if you go to a 64GB or a bigger USB stick, then it will likely be formatted as exFAT or NTFS which the car does not currently recognize. Most 64GB sticks cannot be formatted as normal FAT32 because they do not support variable sector/cluster sizes. The FAT32 it is more common for many devices, and our case is no exception.
Windows operating system offers only exFAT or NTFS formats for drives that are bigger than 32Gb.
So I found on internet a software that will allow you to format any drive in a FAT32 format fast and easy. Just download the link and run the software. It is very easy, even for the ones that are not very familiar with a software. Pick the drive, select the format and after you are ready, just copy and paste your songs.
Big thanks to this guy that made it possible, I wish I could offer him a beer!
The sugestive picture attached was taken from BMW website.
I hope it is valuable for you, as it is for me. Happy listening!
http://www.ridgecrop.demon.co.uk/ind...?guiformat.htm
      11-18-2014, 06:38 PM   #2
taxpro
Drives: 2014 X1 xDrive35i, 2001 540iA
Nice! Tracus, how large of a thumb drive did you format using this tool and found that the entire capacity was usable?
      11-22-2014, 01:36 AM   #3
Teutonic
Teutonic's Avatar
Thumb drive, 64Gb was the one that gave me trouble and is the biggest one I own so far. There are still few that are coming FAT32 initialy but those are exception. But even with those, if you need to do a format, you will need the tool since the OS will not do it.
I did not buy a 128gb yet but I am planning to do that.
I used the soft though for a few 512Gb desktop SSD and they are working perfectly.
      12-29-2022, 07:21 PM   #4
Packard42
Drives: BMW 335i
128BG FAT32 thumb drive
I have been using a 64GB thumb drive for a while with no problems but my CD collection has grown. This time, I'm using a 128GB thumb drive that is USB 2.0 and it came formatted FAT32. PNY brand. Copying files now. Hope it works.
The 64GB drive is USB 3.0 and has a red tab, so 3.0 does not appear to be an issue.
      04-11-2023, 06:27 AM   #5
JPriami
JPriami's Avatar
Drives: 2014 BMW X1 28i
Interesting..I just got a 2014 x1 E84. I wasn't able to use the USB for music yet. Didn't know why. I'll have to give FAT32 a try. Thank you.
(Edit)
FYI: I tried a 128Gb format to FAT32. Still no dice for me.
      04-11-2023, 04:52 PM   #6
Teutonic
Teutonic's Avatar
(Edit)
It should work. try a different software or try a different stick
