| 06-29-2014, 06:27 PM | #1 |
![]() ![]() 37
Rep 372
H&R Spring install - sometime things don't go your way!
so I started the spring install on my 35i M-sport this morning. Figured it would take 3-5 hours. Did the fronts first and then the back. Backs were cake. Front, not so much. First I tried taking the strut assembly out as a whole without compressing. I got nowhere with that as it just would not release at the base even after loosening the bolt and trying to spread the slot with a screwdriver. So I turn to the spring compression method and then tilting the strut outward. I guess I tilted it a little too much because for some reason, I could not tilt it back. I look at the inner CV boot and it is bulging. I have worked on Japanese makes until now and never had I had the joint come all the way out by turning out the knuckle! I jiggle it a little and manage to get it in.
After the install was done, I go for a test drive. I immediately know something is wrong as I can feel vibration as I'm backing out and then later, with acceleration. I know I must have fubar'd the CV joint. I go back to the garage, once again turning the strut out--although this time manage to get it out without compressing it. I remove the inner CV boot clamp. Lo and behold, floating in the grease is one of the three bearings!!! Luckily, I hammer it back on and add a little grease and then use a universal boot clamp on it. Test drive later was grand. H&R is everything I had hoped for. Looks good, rides excellent and handles well. So for those diy'ers out there, watch out for your CV joints!!! While I"m at it, whats the deal with the rear sway bar end links. On one side is the nut, on the other is a round smooth surface that is hard to clamp. Eventually I saw that the threaded end has a torx on the end but it's hard to access--not enough room! Already I hate working on BMWs... |
| 06-29-2014, 09:04 PM | #2 |
Rep 1,922
Drives: 2011 e91
This happened to me also. The dealer installed my ACS springs and they broke my left CV. They "fixed" it and sent it out. Turns out they forgot properly clamp the boot so I ended up flinging grease all over my engine. Brought it in and they repaired it no questions asked.
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
| 06-30-2014, 03:07 AM | #3 |
teh porcupine
107
Rep 1,726
Drives: 2020 Tesla 3 LR AWD
Normally I would install my own springs but after reading this I'll probably just hand it off to a garage that can also do the alignment.
| 06-30-2014, 12:45 PM | #4 |
Rep 1,922
Drives: 2011 e91
The lower mounts on the struts seem to be the biggest issue. even the dealer had a problem with mine and I had less than 1000 kms on the car at the time.
2011 E91
| 06-30-2014, 06:32 PM | #5 |
![]() ![]() 37
Rep 372
Thanks Twix. I don't feel so bad if the pros have done it. At least I managed to get it corrected although at the time, I was totalling thinking I REALLY messed up this time and to a brand new car that I just got less than a week ago!
At this point, no way am I going to consider doing any rear sway bar or exhaust mods. I'm going to finish up my tinting of the rear side windows and think about jb4, B3 Alpina flash and nothing more! |
FlowState290.50 |
| 07-01-2014, 07:59 AM | #6 |
Rep 1,922
Drives: 2011 e91
If you want extra power and no hassles, do DINAN. Much more expensive, but it's factory warranted through a DINAN authorized dealer.
I hear B3 is a really great flash for that transmission, changes it completely. The rear sway bar shouldn't be too bad at all compared to the front springs, much less stuff you have to deal with.
2011 E91
| 07-01-2014, 03:27 PM | #7 | |
![]() ![]() 37
Rep 372
Re: sway bar. Our stock rears are tiny! Very surprised. The sway bar end links are even worse--poly, not metal. I think if you did upgrade to the M3 bar, you would need new upgraded end links. |
| 07-01-2014, 04:55 PM | #8 |
Rep 1,922
Drives: 2011 e91
Check out Paradoxial. He's doing the swap right now
2011 E91
| 07-03-2014, 09:55 AM | #9 |
![]() ![]() 37
Rep 372
![]() ![]() Got an alignment at the dealer today. Said that the front camber has no adjustment. Not bad anyways. The drop definitely makes the 19" wheels look much better. As I said before, I love the ride. Still doesn't corner like a car but it is nice and firm without being harsh. |
| 07-03-2014, 06:27 PM | #10 | |
Rep 330
Thanks for Info./ Comments on installation, including Twix ones. Will take with me for understanding with a chosen Installer. Everything helps. |
| 07-03-2014, 06:52 PM | #11 |
![]() ![]() 37
Rep 372
I think if I had this kind of spreader tool, I could have taken out the strut without having to turn it out and completely avoid overextending the cv joint.
And check out this thread: http://www.e90post.com/forums/showthread.php?t=635166 Last edited by themishmosh; 07-03-2014 at 07:25 PM.. |
| 12-31-2014, 09:05 PM | #12 |
![]() 14
Rep 94
I just received HR springs this week. I am considering doing the job myself. This is the first time working on springs; is there any useful manuals or guides I can use to do the job?
Thanks - Lu |
| 01-02-2015, 09:23 PM | #13 |
Rep 1,922
Drives: 2011 e91
It's pretty straight forward, just watch the CV boots on the front end. A couple of us have had tears after installing lowering springs. It's not a spring related tear, but one that happens while removing or installing the new front springs. I'd recommend having a shop do it, that way they can slide it onto the alignment rack right away.
2011 E91
| 01-04-2015, 02:37 PM | #14 |
Let's save military ranks for those who earn it!
46
Rep 1,161
Drives: ...on the Ragged Edge
You may dislike working on them, but you X1 looks fantastic! ðŸ‘
Richard
2013 BMW M3 Individual -- Fire Orange (sold) 2013 BMW X1 xDrive35i M-Sport -- Valencia Orange (sold) 2011 BMW 1-series M Coupe (#205/220) -- Valencia Orange (sold) 2009 BMW 135i M-Sport Coupe -- Space Grey (sold) |
| 07-23-2015, 06:47 PM | #15 |
![]() 859
Rep 2,417
It's pretty much impossible as far as I can tell to pivot the knuckle without the inner CV pulling out of the cup.
The question is, does it pop back in with either a good push, or a couple smacks on the axle nut with a sledge, without losing a bearing or two. Luckily, mine popped back in without issue, but both sides definitely pulled out getting the strut out. |
| 10-22-2016, 07:28 PM | #16 |
![]() 315
Rep 296
You guys think this tool will do the trick?
2 pc set for spring strut clamp 5.0 x 7.0 mm and 5.5 x 8.2mm For spreading spring strut clamps on VAG VW BMW Citroen Ford ![]() I just installed h&r springs on my wife's f30 yesterday and I had to use a ghetto flat screw driver + vice grips that worked beautifully. On the f30, I spread the clamp, tilted the strut assembly out of the fender well and twisted it until it came out. Are you guys saying this method will not work on the x1? Instead, would it work better to leave the top tower bolts connected, spread the knuckle, mallet the stut assembly off the bottom, then remove the top bolts? |
| 10-23-2016, 07:15 PM | #17 | |
![]() 859
Rep 2,417
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
| 10-29-2016, 06:49 PM | #18 | |
![]() ![]() 37
Rep 372
| 10-31-2016, 07:20 AM | #19 | |
![]() 859
Rep 2,417
| 10-19-2017, 10:58 AM | #20 |
![]() ![]() ![]() 420
Rep 585
Hi guys,
I noticed some folks had an E93 M3 rear sway bar installed on their X1s. I just had a local performance shop here in Baltimore attempt to install one on my vehicle but the angle and geometry of the bar was way off compared to where it should be. I bought a kit from a shop out of Ohio that supplied kartboy endlinks with the bar and bushings. I was just hoping for some feedback on how/who installed your sway bar. Thanks, Rob |
| 10-19-2017, 07:38 PM | #21 | |
![]() 859
Rep 2,417
The E84 X1 rear bar overall geometry is 100% the same as any other E series car. Maybe check the part # on the bar to make sure it was correct? Does it look like this: ![]() Or... ![]() Those are the E93 and E92 bars, respectively. This is what they replace (the critical points are the same, despite looking a bit different): ![]() Depending on how far you drop the subframe, it certainly is a bit of a PITA to remove/install, but it fits like a glove once in the right position.
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) Last edited by PrematureApex; 10-19-2017 at 07:57 PM.. |
| Bookmarks |
