BMW 3-Series (E90 E92) Forum
Dpf fault
05-03-2014, 05:41 AM | #1 |
Rep 289
Dpf fault
Alright guys I had dpf yellow fault show up on dash yesterday so I took it on a 50 miles drive down motorway in fourth well above 2,500 rpm and fault light showed again today, what are my options btw the car drives fine still nice and smooth no issues except for the light comming on for 30 seconds ????
05-03-2014, 09:38 AM | #2 |
Rep 323
It's telling to you your dpf is getting close to blocked, on way to get it to regen now once the code is stored is to have it deleted first then a regen forced and take for a spin . If you ignore this warning it will soon block completely leading to poor performance and other problems.
But you need to address the issue why it has blocked are you getting upto temperature ? a lot of short journeys lately? Last edited by Leah1; 05-03-2014 at 09:39 AM.. Reason: Spelling |
05-03-2014, 09:54 AM | #3 | |
Rep 289
What problems will happen if it's left? Because car is driving fine at the moment |
05-03-2014, 12:41 PM | #4 | |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
As said, get the code cleared, regen forced and all should be good.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
05-06-2014, 09:59 AM | #5 |
Rep 333
Youll need to clear the codes as you drive (get a co driver to clear the codes every few mins).
Same thing happended on mine and forced a regen after about 15-20 miles of driving and clearing the codes. |
05-06-2014, 11:54 AM | #6 |
Rep 2,503
If you don't have someone to assist in manually reading/clearing the codes I know ISTA /D Rheingold has a DPF Regen service function. You ask it to do the Regen, then drive off whilst still connected. It has a live status of the Regen.
05-08-2014, 02:58 AM | #7 |
Rep 142
It's been covered quite a lot, but I'd recommend checking the engine is running at the correct temp (via hidden menu)
So if it isn't it'll cost you half as much and save the hassle of you getting another forced regen in a few months time |
