BMW 3-Series (E90 E92) Forum
Engine Management Light - E92 - 325i N53 - UPDATE
03-27-2014, 04:01 AM | #1 |
Rep 114
Hi,
After 1 1/2 weeks iv had my first minor problem. Car is E92 - 325i 2008 N53 Just done my usual commute into work of about 12 miles - 3 miles of A road and 9 of Motorway at about 60mph. Just as i was coming to the end of my run, the orange engine warning light came on, and as i came to a halt on the traffic lights on the motorway slip road, engine idle was rough, vibrations through the pedals, idle moving around between 400-600rpm. Engine temp was on the floor. Joined my next section of motorway and reduced speed to about 50mph as it was quiet for my last few miles, gradually engine temp picked up and on exiting that final stretch, the lights went off on the slip road and as i came to a halt idle was fine for the rest of the trip. What could this have been, iv read lots of horror stories about injectors, coil packs etc and its one of the reasons i chose the 6 pot over the 320i. Can i be expecting more of this, or was it just a one off due to lack of temp? Any help much appreciated. Andy Last edited by andydutton; 03-28-2014 at 06:41 AM.. |
03-27-2014, 05:33 AM | #3 |
Rep 114
Thanks for the reply Nik.
Would it have stored that code from this morning now the light is off? Sorry i know very little about this. I have a mate who should be able to use his equipment, hope it doesn't come back, got a basic year warranty that i imagine will be of little to no worth. |
03-27-2014, 07:26 AM | #4 |
Rep 825
Hi Andy sorry to hear of your woes, but the N53 early engines weren't the most reliable due to their high pressure fuel injection. They are notorious for eating through fuel pumps injectors & coilpacks much like the N46 320i sadly. Id get it plugged in but the sypmtoms sound simllar to what i had with mine which was two failed injectors. Hope you get it resolved.
03-27-2014, 07:30 AM | #5 | |
Rep 755
Car: 2007 e90 335i 6MT - sports, premium, cold weather, light, and smoker's package. Performance Mods: Cobb AP v3, ETS 7" FMIC, Injen DCI, Michelin PSS, CDV delete, rear spoiler, BMW PE w/ Magnaflow tips, PTF pro-tune, VRSF downpipes, ER chargepipe w/ Tial Q, APEX 18" EC-7 wheels, MP outlet/ inlet, MMP Stg. 3 turbos. Other mods: BMW cargo liner, 20% window tint, BMW alarm system, Weathertech floorliner, Lux E90 V6 bulbs, Philips X-treme Vision H7 bulbs, Blackvue DR650GW-2CH.
03-27-2014, 01:04 PM | #6 |
Rep 114
Light back on on the drive home. It seems to be when i give it any juice, and by this i mean 25-50%. I read another post that said turn the engine off and on and the light goes which it did for about 5 mins then back on. Tried this again, no such luck for the remainder of the trip. Runs ok at gentle cruising speeds but then at idle is really rough, revs trying to dip below 400rpm.
Where do i stand with my independant garage on this? Iv had the car less than two weeks? It also came with a basic warranty from the AA, which covers some engine and electric parts, but i imagine not the ones that matter. Just looked through the policy and it covers the below apparently, not sure what the excess is. Fuel: fuel lift pump (mechanical or electrical),petrol injection pump Electrical: ignition coil Im yet to get to my mates for a reading, but may run it in to my trusted local garage tomorrow for a look over. Really not happy. Any continued help, much appreciated. Andy |
03-27-2014, 01:05 PM | #7 | |
Rep 114
Just out of interest what did your failed injectors cost and was this the end of it? Going to run it in to my local garage tomorrow to have a look over it. |
03-27-2014, 01:45 PM | #10 |
Rep 114
03-27-2014, 01:47 PM | #11 |
Rep 114
03-27-2014, 01:49 PM | #12 | |
Rep 433
Thankfully I had all the coils and injectors replaced under warranty. Best thing to do is run some diagnostics on it and see what codes it throws up. Coils were roughly £40 each and injectors were around £150 each from ECP. |
03-27-2014, 02:48 PM | #13 | |
Rep 114
Thanks for the info on ECP. How much did the labour come to out of interest? |
03-28-2014, 02:54 AM | #14 |
Rep 157
Could you not check with a main dealer to see if there is any quality enhancements (QEC) outstanding on the car?
My 2008 E92 325i (N53) had all coils replaced in 2012 while I had the car in for something else, dealer approached me and asked could they do it. Prior owner also had the Air filter housing and High Pressure Pump done as a result of the same.
2008 E92 325i Black Sapphire M-Sport Coupe
03-28-2014, 03:31 AM | #15 |
Rep 433
My repair was done under the BMW recall. Just give your local BMW service department a ring and ask them to check any outstanding recalls on your car,
03-28-2014, 03:39 AM | #16 | ||
Rep 114
Have you all had (touch wood) trouble free running since the BMW recall? Thanks, Andy |
03-28-2014, 04:09 AM | #17 | |
Rep 114
Thanks, Andy |
03-28-2014, 06:30 AM | #18 |
Rep 114
UPDATE - Garage got back to me. Passed on the following codes:
3104, 2AEC, 29D2. The last code is the cause of the other ones apparently and it shows a failure on the coil on cylinder 6. I have been advised to change all coils and that the spark plugs are due a change as they are still appear to be on the original set at 48k. He said the price of the coil directly from BMW has come down a lot recently and one of his connections in the parts office there said they are sending lots out! He gets them for 17 quid plus VAT each and NGK spark plugs for 8 quid each plus VAT. with his labour inc VAT he quoted me £264. The warranty would only potentially cover the faulty part plus id have to pay an excess so it might not be worth it for the hassle. If that cures it thats not as bad a figure as i have seen elsewhere and i trust the guy 100%. Im going to give BMW a call to see if they will still cover the coils. Opinions? |
03-28-2014, 09:21 AM | #19 |
Rep 114
Fair play to BMW Williams Manchester. Booked me in for monday for all 6 coils and security software update. Happy days, hope this solves it. The spark plugs will have to wait until my next service. How much would you expect to get out of them, my service history shows they have never been changed at 48k and I'm expected to be on about 54k by the time of my next service.
Excellent service by BMW, mightily impressed. |
03-29-2014, 04:49 AM | #20 |
Rep 157
Result
You could chance trying to get the spark plugs included while they are at it, just play dumb and ask, even if they quote for doing them might be worth it if they were never done and you have your indy price from them as reference plus seen as they are working on it already labour should be minimal, if anything. Ask and then weigh it up.
03-30-2014, 07:54 AM | #21 |
Rep 114
Spoke to my inde garage and he said the sparks will be fine until the next service. Im just happy BMW are doing the coils and dont want to get greedy, i just want a car that works!
BC MOTO M3 Lip spoiler arrived today, so if she behaves herself and is fine after this little hiccup she can have her present! Will keep you posted, but im hoping once coil 6 is replaced all will be well. |
