01-15-2014, 06:05 PM | #1 |
Rep 374
Owner's of new 320d's in foreign lands: Can you measure urea/def fluid level?
I've got a 2014 BMW 328d with the n47 diesel engine. It is I believe essentially the same as the BMW 320d sold in Europe and other lands. It uses ADBlue/urea fluid injected into the exhaust for improved emissions. In the U.S. the fluid is called def or diesel emission fluid. The 328d carries 3 U.S. gallons of the def.
My question to other owners of 320d's is: Can the def fluid level be measured - - much in the same way that you can measure oil level - - electronically in the iDrive? The U.S. owner's manual says that the def fluid may have to be replenished (at some indeterminate point) before the scheduled oil service interval, which in the U.S. is every 10,000 mi (about every 16,000 kilometers). The owner's manual goes on to say if the 328d is driven in a "particularly sport style" (perish the thought) the def may have to be replenished even more often. Not to worry. The owner's manual says the def fluid level may be measured at any time. The manual says the fluid level can be displayed in the iDrive Control Screen as follows: select "Vehicle info", then select "Vehicle status", then select "Diesel exhaust fluid". The only trouble is that there is no selection for "Diesel exhaust fluid" on the U.S. 328d's, so no way to measure def level - - no way that is until the low level warning light comes on to tell you that you will soon run dry. I wrote to BMW North America about this discrepancy and their answer (by telephone message) was that the manual is written to cover many different markets besides the U.S. - - the implication being that there are some countries or markets where the 320d/328d can measure def fluid, as stated in the owner's manual. This is not a huge deal. I'm just curious. I think BMW NA may be blowing smoke up my auspuff. __________
'14 328d, '13 M3 ZCP, '12 535i, '11 335d, '09 Z4 DINAN Stage II, '05 330i ZHP, '05 M3 ZCP, '02 M3, '91 328i, '90 535i, '88 528e, '88 M5, '87 M6, '95 Z3, 95 M3, '93 M5, '87 325e, '89 535i, '86 635i, '73 Bavaria. |
01-22-2014, 09:53 PM | #3 |
2024 M440i GC (G26)
279
Rep 511
My code reader (Actron CP9580A) reads "reagent level" off the OBD II port. This is level of fluid in the DEF tank. My new 328d (2000 miles) reads 97% at the moment. There's a few other parameters like consumption rate you can read as well. Not the easiest solution, but a way to determine tank level before you get the warning.
FYI, this reader can access roughly 300 different readings from the OBDII port, and store/plot them in real time. Quite handy. |
01-23-2014, 09:48 AM | #4 | |
Rep 374
Where did you purchase your code reader? Thanks
01-23-2014, 12:55 PM | #5 |
2024 M440i GC (G26)
279
Rep 511
I use an Actron CP9580A reader. A bit pricey compared to others, but it will do everything including real-time readout, graphs, and storage of data. I got mine at Autozone; nearly any auto parts store will carry these.
edit: note the "a" in the part number is important. The other version of the tool, the CP9580 doesn't state that it reads extended PID data. I can say that the CP9580a has no problem reading the DEF level and several other parameters related to exhaust fluid use for the BMW 328d, along with about 300 other parameters from the OBDII port. Last edited by diablo2112; 01-23-2014 at 01:05 PM.. |
03-23-2014, 02:26 PM | #6 | |
Rep 12
Thanks, Lynn (328d, US version) |
08-11-2014, 09:49 AM | #8 |
Curmudgeon and Pedant
690
Rep 3,489
08-12-2014, 08:12 AM | #9 |
Rep 30
