09-08-2012, 12:38 PM | #1 |
woof
84
Rep 1,233
F30 F3x DIY Xenon Headlight Adjustment / Alignment
2013 F13 ///M6 Sakhir Orange 2013 F30 335i Estoril Blue II 2008 E92 ///M3 Interlagos Blue 2007 E92 335i Montego Blue Last edited by gerbs; 09-08-2012 at 12:58 PM.. |
09-09-2012, 11:35 PM | #5 |
Rep 2,991
Hey thanks for this! I did manage to drop one of the adjustment caps, luckily I was able to fish it out from the bottom.
The adjustment is a 6mm Allen key. |
09-12-2012, 01:00 PM | #7 |
**Fortune Favors The Brave**
13
Rep 173
Drives: 2013 328i M Sport
great write up! thanks gerbs!
2013 ///M Sport Estoril Blue - Navigation - Enhanced BT - Xenons - Sport Auto
10-08-2012, 09:07 PM | #8 |
Rep 13
I must be doing something wrong. I can turn the white adjuster Ccw or cw, but the height of the xenons never changes.
Anyone have an idea why this might be? Andrew |
10-08-2012, 10:46 PM | #9 | |
Rep 218
10-09-2012, 09:49 PM | #10 | |
Rep 13
I project the beam on my garge wall, turn the adjuster and nothing changes. I do think the aim is low, so I wish it would work. Andrew |
10-18-2012, 01:11 PM | #11 |
Rep 286
You just made my day Gerbs! The dealer said this could take hours to do, yeah right! I knew there would be 5 minute fix to this problem, I need to do this asap as my driver side is almost useless at night (from factory).
'12 335i Sport Apline White w/black... Totaled
'14 535i xdrive M-Sport Carbon Black w/Mocha Nappa |
11-06-2012, 08:35 PM | #12 |
2013 328i Sport, Alpine White, w/Premium/Nav. Pkg.
Rep 10
Hi, I just bought 2 weeks ago my first BMW, and is an F30 with the active xenon headligths. This is my first car with this kind of active lights (also is my first post here), so I don't have previous experience with this, but I feel that the beams were factory adjusted too low (specially for the driver's side). The beam (left) barely can iluminate below the bumper of a car in front at a distance of 30 ft.... I don't know if adjust it by myself (it looks pretty easy) or ask the dealer to perform this task under warranty.
By the way, I read in some thread that the system performs an "automatic" self adjustment each time that the car starts, but I don't know if this is true. Any advice is appreciated. Thanks! |
11-16-2012, 10:30 AM | #13 |
Rep 729
Did you ever resolve this? I have the same problem, I can turn the adjuster but the height of the lights doesn't alter at all. I'm definitely turning the adjuster shown in the pics.
11-16-2012, 06:50 PM | #14 |
Rep 603
Not saying you are wrong but try shining the light against a wall with lines ( brick wall) and see if there is any changes. I haven't tried this on the f30 but on the z4, I had to turn quite a bit
11-17-2012, 06:24 AM | #15 | |
Rep 729
I'm wondering if there's something different about having adaptive headlights and/or it being a UK spec model (from what I've read there is a difference between UK and US adaptive h/light systems). Has anyone with adaptive or UK spec successfully done this? |
11-17-2012, 05:37 PM | #17 |
Rep 10
Xenon Headlights adjustment
Well, I just got a call from the dealer to pick up my plates, so I'll take the opportunity at the dealer and request to adjust the headlights. BTW, checking the description for the Lighting package (see pic taken from BMWUSA website), it says that headlights have "a dynamic auto-leveling feature to adjust automatically beams depending of cargo and or passengers loads..." so perhaps the system automatically "compensate" any adjustment/alignment done only with that screws. Perhaps code is required to introduce for set up the lights (any info?)...
BTW, I will also ask to turn Auto Start/Stop OFF by default (and still get the flexibility to turn on) or sets the A.S.S function in memory as last used setting. Additionally, (I'm just curious) my car also came with beacon light (sort of strobe light) attached to the rear mirror (similar to the picture attached but clear color) and, according to the car's manual, this light is part of the alarm system. The car's features data sheet doesn't indicate that the alarm is included with it (for US market, the alarm option cost an additional 400$), but the car already have premium pkg. (including Comfort Access), Technology Pkg, Lighting pkg. and heated front seats. Maybe I'm wrong, but with the comfort access already there, I'm suspecting that all the alarm's hardware is already installed in the car (horn & alarm light are there, right?) so could be just a matter of "code activation".... so I will ask at the dealer's service and get some answers... With the alarm installed the only thing additional that I'm looking for is get the sound and light alarm at activation. Perhaps they can code this too. I will post any info.
2013 F30 328i | Sportline | Alpine White | Leather Gray Dakota Everest | 8-speed | Navigation/HUD | Xenon Headlights | Technology & Premium | Moonroof | Anthracite Wood Trim | Heated seats
11-19-2012, 07:12 AM | #18 |
Rep 397
Drives: 11 E90 M3 ZCP
FYI The adjustment screw referenced in this DIY is for horizontal adjustment not vertical. My passenger side headlight was aimed to DOT spec but the driver side is a few inches off.
11-19-2012, 01:52 PM | #19 |
Rep 3,205
Thanks for the DIY, will be doing this tonight.
11-20-2012, 09:53 AM | #20 | |
Rep 729
If you are right, do you know how to adjust the vertical alignment? |
11-20-2012, 10:53 AM | #21 | |
Rep 729
The correct adjustment screw is inboard of that one and accessible through a hole that may or may not have a plug in it (my car had a plug on the driver's side but not the passenger's). You have to look through the hole at an angle and it's several inches below it, but still accessible with a normal length screwdriver. It looks exactly the same as the other adjuster pictured above. This photo hopefully gives you some idea... |
CIWS655.00 |
11-20-2012, 12:23 PM | #22 |
Rep 4,323
wait so how does one do the vertical?
I wonder if OP inadvertently did horizontal, and thus, the looked like a vertical adjustment?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
