09-01-2012, 10:23 PM | #1 |
Rep 478
HK rattling side skirts
For anyone that listens to music with a lot of bass I know this has come up as an annoyance. On the inside its barely noticeable but turn up your radio and step outside the car and you will hear very ugly rattling coming from the side skirts.
Curious if anyone found any workarounds or temp fixes? |
09-02-2012, 10:53 AM | #2 |
Rep 250
Drives: E82 N52 6MT A51
Take it to you dealer. This is a 50k+ car. they'd better sort that out. Its not suppose to sound like a chintzy rice rocket when you crank music.
09-02-2012, 07:52 PM | #3 |
Rep 478
Ok Wayman519 thanks for the response. Looks like my situation is an anomaly and not the norm for stock f30s. Will check in with the dealer. When I touch the rear part of the side skirts they wiggle. Does yours ?
04-22-2013, 07:22 PM | #4 |
Rep 664
Drives: 2013 BMW 335i
did you happen to find a fix for this yet?
04-22-2013, 10:09 PM | #5 |
Rep 478
04-22-2013, 11:07 PM | #6 |
Rep 664
ooo ic. mine seems to be coming from the side skirts. if i put pressure on it, it stops.
03-06-2014, 10:16 AM | #7 | |
Rep 6
same problem
any genuine solutions on this (DIY ofcourse) |
03-06-2014, 10:17 PM | #10 |
Rep 664
what i tried to do while standing outside is pushing the side skirt up towards the car and it helps.... so its something between the skirt and where it attaches.... i think the skirt has to be remove in order to fix it.
03-09-2014, 11:49 PM | #11 |
Rep 2
Have the very same issue here in Perth, Australia on my 2013 F30 328i with HK sound. Rattling was unbearable so I took my Beemer back to the dealer where they apparently added foam into the side skirts. Fixed the problem from about a month, now the issue is back. Will bring it up again with the dealer at my next service.
Annoys me, as it must annoy everyone else! This sound system by HK was apparently designed together with the birth of the F30! Hmm... |
07-30-2014, 03:47 PM | #15 |
Rep 1,741
Same here. I think this is "normal". The side skirts are probably only attached in a few places. You can wiggle them. I would think removing them and putting 3M tape the full length would fix it.
Who's gonna try it first? |
