TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > My 335D has been re-mapped! POWER!!!
      04-16-2007, 08:34 PM   #1
peppernick
Drives: M4 vert
Not many re-mapped E92 335Ds in the UK, today my D joins the rank of the 300+BHP club.
The ECU in the E92 335D is the latest Bosch DDE 7 ECU, in BMW's terminology, it's the most flexible and adaptive ECU to date. Cracking the encryption took some time, as some of you might know that over the past few months, there has been the unfortunate event of irretrievable date loss from the ECU when a re-map was attempted. However, I have to say this is no longer a problem.
Unlike other ECUs, careful research led to the approach of removing the entire ECU from the car to re-map. Using the OBD port is not deemed safe enough for us for this occasion although there are some mappers out there who are already employing the latter method . We took the failsafe route.
And here is the tiny brain that controls everything. How amazing. The ECU is made by Bosch and the latest DDE7 version. Each ECU software/microprocessor is specific to the car it comes with. My ECU is stamped with my chassis no. Cars with different specs such as i-Drive etc will have a different programme, although the majority of the processors are similar.
Crunch time. ECU guts laid bare. We had to get to the EPROM to obtain a record of the original map. Those 10 pins are the ports for information transfer.
Once the original map is obtained, it is saved for future 'reference'. The map is then emailed to Roy's source and an hour later, a custom modified map based on the original map is received. In the mean time, we shove the ECU in the freezer. No joke!
This is a vital part of the entire process. The ECU has to be within a certain temperature range for the new map to be uploaded. We had to try several times and put the ECU back in the freezer to guestimate this temperature window. Eventually, the new map was successfully transferred and a quick check to ensure no disparity in the new map and that we received on the computer.
Once the ECU is re-intalled in the car, a quick diagnostic check was performed. No fault codes! Yippeee!
We are ready to roll. Thumb the start button and the diesel block fired up straight away, settling to a steady idle. I prodded the throttle and straight away, even when the car was stationary, I could feel the difference. The throttle feels so much more alive.
On the move, MY GOD!!!! The car is totally transformed. The amount of power is mind boggling, let alone the torque! Estimated gains, 340BHP and 680Nm torque. The 335D pulls so hard in every gear that it defies believe. If I floor the throttle hard, DTC will flash even in 3rd; and today was 26 degrees and dry! Squeeze the throttle progressively and you literally blast past everything in sight. I tested with a stopwatch, 0-60 achieved in 4.8 sec, the speedometer whips from 80-120MPH in a few seconds, and it continues to pull. The re-map has also removed the top speed limiter, so the 335D should easily see 160+MPH. TBH, the in gear acceleration feels as quick as the E60 M5 I drove not long ago.
Another top mod in the bag! Big thumbs up to CA Automotive Videos to come soon.
      04-16-2007, 08:36 PM   #2
peppernick
Drives: M4 vert
Bear in mind my 335D is a guinea pig (it's OK, no pain no gain. But I trust CA Automotive's judgement). It is a success.
Just spent several hours driving the D hard, the ECU is continually adapting to the driving style. The harder I drive the car, the more responsive the car gets. Gearbox is holding up fine. The gearbox is the major weak link as it heats up too much at too high a state of tune (automatically feed information back to the ECU to reduce engine power), despite the engine and turbos keeping up with the demand. I think we can push a little bit more once the engine is more run in.
Tonight I used 2 cars for comparison, both on motorway in gear acceleration and around twisties. We chose the black ones as they are generally faster ..... :wink:
In gear acceleration, the 335D is on par with the CSL until 4.5k RPM where the CSL started pulling ahead with 3k more revs to utilise. Once the 335D upshifts, it surges ahead gaining on the CSL, and then lose out again when it runs out of puff. However, overall the CSL is never more than 2 cars ahead before we had to slow down or risk an instant ban and jail. The F430 is leagues ahead, no comparison, even for the CSL.
Twisties, the gargantuant torque of the 335D enable it to tailgate the F430 in any gear. CSL was more nervous over rutty areas and the gearbox had to be worked hard; but the E92 soaked up the undulations very well. The F430 was throwing sparks from it's underbelly, still amazingly quick but didn't pull on the E92 more than a car's length.
Pretty accomplished for a diesel! Can't wait to see the 335D tackle the Ring come June.
Here are 2 quick (low quality) videos I made using my camera. The first one was immediately after the remap and the second video is after several hours of spirited driving. You can hear the engine revving a lot more aggressively in the second video.
Immediately after re-map
ECU adjusting to aggressive driving
So far I'm very impressed with this upgrade. The gains are more noticable than the time when I had my 330CS supercharged by Infinitas using the SK+ S/C (231 to 286 BHP). For £525, it's a BLOODY GOOD mod :rocks:
      04-16-2007, 08:41 PM   #3
esbezee92
esbezee92's Avatar
Drives: Montego 328i Coupe
damn man that takes balls, idk if i could tear into my new bmw and shove parts in the freezer or be a guiniue pig
congrats tho the results speak for themself
      04-16-2007, 08:45 PM   #4
OwnAge
Gourik
OwnAge's Avatar
Drives: soon
2009 328i  [8.90]
Goood Stuff man. Nice pics and vids.
      04-16-2007, 08:46 PM   #5
325 Baller
325 Baller's Avatar
Drives: X3 28i
2006 325i  [0.00]
congrats, awsome engine in that car and thankfully someone was able to put it to its fullest. Would a PROcede work in it too? That would make it a force to be reckoned with.
      04-16-2007, 08:59 PM   #6
Not Ur Avg 3
Not Ur Avg 3's Avatar
Drives: 06' 325i
2006 325i  [0.00]
that sick bro
tru diesel power right there
Perfection In The Making...
      04-16-2007, 09:10 PM   #7
MonacoBimm
Panama
44
Drives: Sapp. Black 330i(2nd e90)
Damn, thats nice.
      04-16-2007, 09:24 PM   #8
ironic
ironic's Avatar
Drives: Jet Black 335i
wow the freezer huh? nice looking car man, one of my favorites
Widebody 335i Project Car BUILD | PHOTOSHOOT
      04-17-2007, 02:45 AM   #9
stefano7171
stefano7171's Avatar
15
Drives: BMW e93 335i Msport
Congrats man! great job! you are probably driving the quickest diesel in the world (save for Audi cars used in Le Mans... ;-) )
Current: e93 335 Msport, black sapphire on sanbeige, MT, 19" rims 225m, satnav, usb, CA, voice control, HBA, windstop, heated seats.
      04-17-2007, 02:55 AM   #10
Grubbe
Drives: 320d
No he is not, not even close, not even on the same map.
      04-17-2007, 03:06 AM   #11
spesrf25
spesrf25's Avatar
Drives: X5d X-Line
You have to lemme know when you plan on hitting Santa Pod.
BMW X5d (Ordered)
2007 335i Coupe (sold)
      04-17-2007, 03:12 AM   #12
335i black rider
If there's a will,there's a way.
Ecuador
Drives: 07' 335i coupe
nice job...congratulations..
97' BMW 540i 6speed manual 300hp, 32v, 4.4l
06' Range Rover Sport
07' Bmw 335i black coupe
      04-17-2007, 03:15 AM   #13
- Paul -
- Paul -'s Avatar
England
697
Drives: see above.
2005 320D SE  [10.00]
2005 645  [9.00]
335D vs 335I Santa Pod - UK4????
      04-17-2007, 05:47 AM   #14
peppernick
Drives: M4 vert
Cooling the ECU down decreases the voltage sensitivity when programming some EPROMs. Makes it easier to upload the new map. We had to stick the ECU in the freezer a few times, and as long as 30mins on one occasion just to allow us a window of opportunity to upload the entire map.
Trust me, there are MUCH FASTER diesels in Europe :rocks:
Bring it on
      04-17-2007, 05:48 AM   #15
peppernick
Drives: M4 vert
We know the 335D can take more, the US spec 335i are pushing 380BHP but the immense torque from the D can potentially cause the gearbox to overheat. The ECU will limit engine power momentarily until the gearbox cools down and full power is available again. This is only apparent to the driver as I can tell at a specific throttle position, the engine is slightly softer than what it should be. Nurburgring will be the ultimate testing ground
However, at the power level I'm running, this only happens under significant strenous driving ie. powering the 335D up a 20 degree slope during very spirited driving using full kickdown to second gear. At the moment, this protective feature cannot be overidden but by fitting a gearbox oil cooler, theorectically can improve things. It is being looked into
      04-17-2007, 06:23 AM   #16
spesrf25
spesrf25's Avatar
Drives: X5d X-Line
Originally Posted by peppernick View Post
Bring it on
I don't know....now I'm kinda scared of the big bada$$ deisel.....lol.
J/k, I'd be willing to take a beatin to see that bad boy go down the strip.
BMW X5d (Ordered)
      04-17-2007, 08:28 AM   #17
330cdsport
Right Responsible
330cdsport's Avatar
Drives: AW F21 M135i
What a superstar you are - and balls of steel too!!!
That car is now one mean lookin' force to be reckoned with - Love It
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension
Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys.
      04-17-2007, 10:56 AM   #18
Terry335
Drives: 335i
Now that's real R&D work.
      04-17-2007, 12:39 PM   #19
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
Thats very impressive
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      04-17-2007, 01:32 PM   #20
squeezebm
Drives: Audi
:rocks: Pepper u even made me drop my pizza whilst reading this pick up my 335d tomorrow not even sat in it yet and already thinking of the re-map Tell ur man @ CA Automotive that he needs a proper under counter Commercial freezer that he can set to run @ desired temp +/- 1'c so getting the ecu to desired temp would be a lot easier/quicker.Obviously running my own refrigeration company has nothing to do with this suggestion
      04-17-2007, 01:56 PM   #21
MacAttack
MacAttack's Avatar
Drives: fast enough
2007 BMW  [0.00]
Pep...that's amazing! Very impressive work. ..."estimated gains...340BHP and 680Nm torque"...
2007 E92 335i Coupe: Monaco Blue/Premium/Sports/Winter Package/Nav/CA/6MT/TT/Active Cruise/Active Steering/iPod/Rear Shade/Tint/Short Shifter/OEM Alum Pedals//
      04-17-2007, 02:51 PM   #22
Dr_Dirt
Dr_Dirt's Avatar
Drives: E90 335i 6AT
Nice I might have to upgrade if they ever bring those diesels to the US!
