2010 2011 BMW 5 Series Forum F10
2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Help with lowering !
      04-04-2011, 09:15 AM   #1
perisak
Drives: m550d
Hi Guys. I have just lowered my new F10 with RD sports springs. I have adaptive drive on my car. But the car are making noises from the front. I think its coming from the suspension. Does anyone know if there is anything that need to be done after changing springs? Like reprogram or de-gas the suspensions or?
      04-04-2011, 10:35 AM   #2
gatoman39
gatoman39's Avatar
Drives: 2011 E92 335 M-Sport
I'm assuming you got the alignment adjusted.
      04-04-2011, 11:04 AM   #3
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
2011 F10 528i  [10.00]
Make sure you have your sway bar end links are connected properly. My mod shop forgot to connect one end of the link bar and it had strange noise. Eventually the end link drop to the ground. Took my car back to shop for repair and I busted those guys badly.
2011 F10 528i Black Sapphire / Oyster Black
2000 E46 325ci Cabrio Titanium Silver / Black - retired
1997 E36/7 Z3 Montreal Blue / Black - retired
      04-04-2011, 11:36 AM   #4
perisak
Drives: m550d
Yes, I have made the alignment adjustments. And I think (hope) they have installed it right. Any more ideas?
      04-05-2011, 05:53 PM   #5
Vinfast
Drives: '14 550i M-Sport
My BMW dealer told me there was no way to de-gas a strut --- possibly you can reprogram the ARS, but they also said that was not necessary. What does the noise sound like and do you hear it only when turning, stopping, etc.?
      04-06-2011, 02:35 PM   #6
perisak
Drives: m550d
Hi. The sounds comes when Im turning. (like 30 degrees on the wheel), specially at low speed. Could be the EDC dampers. Its less noise in comfort mode than sport mode.
      04-06-2011, 07:34 PM   #7
Vinfast
If whomever put on your lowering springs says everything is okay, then I'd try the software update of the Active Roll Stabilization. I had a grinding noise when turning at lower speeds on mine before putting on the lowering springs, and after the software update, the noise went away.
      04-11-2011, 01:52 PM   #8
perisak
Drives: m550d
The sounds seems to come from the rear sway bar and have nothing to do with the lowering springs.
      05-12-2011, 02:26 PM   #9
perisak
Drives: m550d
Problem seems to be solved today. Software for the rear active swaybar is updated by BMW, and the noice is gone.
5post
