05-19-2025, 10:52 AM | #1 |
![]() ![]() 546
Rep 1,525
Wheels are a nightmare to clean
Hey all,
I'm experiencing levels of rage never thought possible washing my car and i need advice before i push my '24 M2 off a cliff. Besides changing to iSweep2000 or buying new $5000 wheels, how do y'all clean your wheels Can you post tools (with links) that allow you to clean your wheels thoroughly & quickly. My wheels are graphene coated but brake dust is still maddening. I use P&S wheel cleaner in a IK foam sprayer I can't get behind the front calipers. I have to use a paint stirrer inside a thin/cheap wash mit. Still bunches. I have wheel woolies but the smallest one isn't long enough for the barrels but the larger ones won't clear the rotors. The spokes I use detail brushes and still can't it all. Behind the spokes too Any advice would be awesome
miiipilot
'24 M2 Brooklyn Grey, 6mt, Bi-Color, Black M-Color seats, '16 MG M2, DCT, Exec. Took Delivery 4/30/16 (Sold) |
05-19-2025, 12:42 PM | #2 |
![]() ![]() 1019
Rep 1,931
Drives: X5M, M3 ZCP 6MT, MB E63 AMG
Okay here we go, first my wheels are ceramic coated, and I have low dust pads but that doesn't eliminate all the dust.
So, I use Sonnax Wheel cleaner with wheel woolies, if I can't get behind the calipers I don't worry about it, because the next time I might. Then I use a foam cannon with foaming soap to spray then again, before moving on to the car. I use this foam toilet bowl brush from a dollar store to get into the spokes of my 666M wheels. I really don't find it to be much of a pain anymore. Besides this is my therapeutic time with my cars. And I really enjoy washing them, and putting on my indoor car cover. Only to take the cover off another one of my cars.
It is never taken for granted that a commitment to speed and acceleration must be matched with an equivalent ambition when it comes time to stop!
05-19-2025, 01:57 PM | #3 |
![]() ![]() 322
Rep 237
I wish that with the technology these days, they could invent a brake pad material that stop well but doesn’t produce any dust (that sticks to the wheels).
I found the best way is at least once a year to remove the wheels and deep clean everything. But that is a lot of work.
StradaRedlands8432.50 miiipilot546.00 |
05-20-2025, 04:02 AM | #4 |
![]() 143
Rep 226
The old saying "a labor of love". I remove them once a year as well to clean and wax the inside. The ceramic pads do reduce the density of the buildup. I used to use Sonax but I found Griots heavy duty wheel cleaner to cost less, and it smells a lot better. The constant question I see here is getting under the caliper. I have some brushes I purchased on amazon that fit but I also have 19" rims and a standard caliper. Get a nice plastic stool, get the music playing and sit your ass in front of the wheel.
05-20-2025, 06:33 AM | #5 |
Rep 624
1. If your car is a pure street car get rid of the OE brake pads ASAP and get something like the CarboTech 1521. This will cut your brake dust by 80% and at least double the life of your rotors.
2. Ceramic coat your wheels. 3. Buy the correct wheel cleaning tools to make the job easier. 4. If you can afford a '24 M2 you can afford a $3500 set of much easier to clean (and definitely lighter) wheels. To do it right you should follow all 4 steps. |
05-20-2025, 07:31 AM | #6 |
![]() ![]() ![]() ![]() ![]() 2224
Rep 989
Switch to Akebono pads. They have 90% less dust, and makes cleaning my 666 wheels of the devil much easier lol.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance." |
miiipilot546.00 |
05-20-2025, 07:44 AM | #7 |
![]() 1502
Rep 1,685
If your wheel style is '666', what did you expect?
- Jeff
bosstones' flickr |
miiipilot546.00 |
05-20-2025, 08:29 AM | #8 | |
Rep 624
I believe they're 930M's. |
05-20-2025, 09:45 AM | #10 |
Track rat, unreliable but well-meaning
![]() 79
Rep 127
There’s a lot of good advice already shared. One simple thing I sometimes do, is make no attempt at all to clean the wheel in the caliper interference zone on the first/main pass. Once that’s done, just roll the car 18” and the remaining dirt is usually easily accessible.
2021 M2 Comp 6MT | Hockenheim Silver | 18x10 Forged TA16 | Bimmerworld | Competition Motorsport | OMP | Lifeline | RE71RS | PFC | Girodisc | @Track/S | Ground Control | SPL
afadeev1724.50 |
05-20-2025, 10:46 AM | #11 | |
![]() ![]() 546
Rep 1,525
miiipilot
05-20-2025, 10:50 AM | #12 |
Rep 624
Mine take about 2 minutes each. The best part is that my hand is small enough to fit between the spokes so I can get the barrel as well.
05-20-2025, 10:51 AM | #13 | |
![]() ![]() 546
Rep 1,525
They are graphene coated Ive got a bunch of tools, but was looking for actual tools others have used to help (that Dollar Gen foam brush looks like it'll work) Seriously? Not helpful
miiipilot
05-20-2025, 10:53 AM | #14 |
![]() ![]() 546
Rep 1,525
2024 M2...930 style i think
miiipilot
05-20-2025, 10:54 AM | #15 |
![]() ![]() 546
Rep 1,525
miiipilot
05-20-2025, 11:25 AM | #16 |
![]() ![]() 1019
Rep 1,931
So, I've got these 2NH calipers from an M3 equipped with the Carbon Ceramic Brakes (CCB) setup, and it turns out Akebono doesn't even make pads for them. I'm currently running Dynamic Friction low-dust pads for now, but I've been eyeing Carbotech. I actually called them up this morning, and the lady there gave me the whole rundown on their pads. The pads alone will set me back $563, if they work as advertised it will be worth it, because the 666M wheels take the most time to clean, out of my three vehicles.
miiipilot546.00 |
05-20-2025, 12:23 PM | #18 |
![]() ![]() 546
Rep 1,525
I wouldnt care about the barrels or calipers of those bc even if it's 1/2" thick, you can't see the build up.
miiipilot
05-20-2025, 12:25 PM | #19 |
![]() 1502
Rep 1,685
Ah....yeah, those don't look fun.
Is it Brake Buster that you're using? If so, I was underwhelmed by it. It's a light cleaner and, personally, I saw no value in it over using car wash. Sonax Beast and Griot's Heavy Duty Wheel Cleaner work well. The Griot's is a little more economical and doesn't have a sulfer-y smell. As others have said, ceramic pads should help w/ dust. I run Akebonos on my N55 X1 and the difference from OE is night and day. I do feel the brakes having less initial bite and feel they are a little softer but it is good for what it it. Haven't made the switch on the Moupe or C4S yet as I like the bite w/ steel/composite pads and it gives me something to bitch about.
- Jeff
bosstones' flickr Last edited by bosstones; 05-20-2025 at 12:26 PM.. |
miiipilot546.00 |
05-20-2025, 05:07 PM | #20 | |
![]() ![]() 546
Rep 1,525
miiipilot
05-21-2025, 01:55 PM | #21 |
![]() ![]() 1019
Rep 1,931
First off, my wheels never get that dirty. My only issue is that there isn't any device that can get behind the front calipers to clean the barrel, as space is very tight, so I have to move the car forward or backwards to get at it. Even my wheel woolie can't fit.
miiipilot546.00 |
05-21-2025, 03:51 PM | #22 |
![]() 1569
Rep 1,244
I have Akebono Euro pads and just swapped my 666M wheels back onto the car last week. I haven't driven the car much and I do see a small amount of brake dust and road dirt starting to accumulate, but in my specific case where I wash the car every couple of weeks any drive maybe only a few hundred miles in between, the relatively light buildup described above ought to come off by just spraying them with Sonax Full Effect (or similar product), letting them sit for 5 minutes, and hitting them with the pressure washer.
2018 ///M3 Competition 6MT Mineral Grey
2023 X3 ///M40i Brooklyn Grey |
