05-13-2025, 08:22 AM | #3 |
![]() ![]() ![]() 8433
Rep 5,184
Drives: 2006 BMW 330i MT
Garage List 2007 BMW 328i [8.25]
2013 BMW X5 35i [8.17] 2009 BMW 328i Touri ... [8.50] 2006 BMW 330i [8.59] 2011 BMW 528i [8.92] |
My car had some pretty bad water spots all over it when I bought it. I used CG's product to clean it up. It was a bit of work to really get them off, but they did come off. I've been really careful to not park near sprinklers since then, and have only had to use it again once. That was right after getting some spots and they came right off that time.
https://www.chemicalguys.com/product...r-spot-remover |
kingywheels0.00 |
05-13-2025, 09:07 AM | #4 | |
![]() 1725
Rep 2,837
1. Start with regular wet towel, if not enough ... 2. Spray some spray detailer or waterless wash on the area, if not enough ... 3. Bring out the water spot remover, if not enough ... 3. Bring out Iron remover or Bug & Tar remover. This always wins, but requires clean-up afterwards. HTH, a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
kingywheels0.00 |
Yesterday, 05:39 PM | #5 |
![]() ![]() 362
Rep 1,019
I have heavy water spots on the front grill of my brand new X3 G45. The front grill is made of a satin silver-colored plastic material. It is not metal. It is not paint. I realize there are lots of water spot removers available, but I cannot find any specifically for plastic trim, such as my front grill. I’m hesitant to use the ones for paint, because I’m afraid they’re harsh and may damage my satin plastic finish. I’ve heard some people recommend a mix of vinegar, but again, I’m afraid it will harm my plastic. I’d like to find a tried and true water spot remover for plastic trim. Thoughts? Ideas? Suggestions?
Yesterday, 06:25 PM | #6 |
![]() ![]() ![]() ![]() 680
Rep 956
i have been using CarPro Descale with moderate success. for the gloss black trim i dont dilute it, just rub some in, let it dwell then clean off. if your water spots are severe you may need to polish them out.
regarding the common options (CarPro, CG, GTechnic), they aren't too caustic, they are just acidic washes. |
Yesterday, 10:39 PM | #7 | |
![]() 1725
Rep 2,837
Ceramic coatings will make water sports WORSE!
Water spots are mineral deposits left after water evaporates, and ceramic/graphene promote water beading. After water beads, it evaporates and creates concentrated area of mineral deposits left behind by evaporating water. Please only polish plastic trim pieces after everything else failed! Plastic is fragile, and you are as likely to polish through the outer trim coating veneer layer as you are to only abrade the water spot deposits! Quote:
https://diydetail.com/products/water...s&_ss=e&_v=1.0 a
'15 F80 M3 (SO/SS)
StradaRedlands8432.50 |
Yesterday, 10:56 PM | #8 |
![]() ![]() ![]() ![]() 470
Rep 892
If your water spots are from washing simply use DeIonized water or distilled water. If its rain spots, then follow advice above. I use waterless wash to get rid of spots as soon as possible using DI water and follow that with Turtle Wax T-9 1-Step Wax & Dry (https://www.amazon.com/dp/B0007TV6M0). I have graphene on my vehicle and as was pointed out above, it does not prevent water spots on its own. Tap water is the worst if you have high dissolved solids and is best avoided.
Today, 07:59 AM | #10 |
![]() ![]() 6794
Rep 5,033
Ceramic coatings definitely cause beading. The beads should slide off easily, but if they sit on the surface and dry, they absolutely can cause water spots.
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
tracer bullet4979.00 |
