      04-17-2025, 01:49 PM   #1
tighfitzgerald
tighfitzgerald's Avatar
Drives: 2011 M3 Coupe
2011 BMW M3  [10.00]
Mr. Clean Magic Eraser on Glass?
Yes, I just recently decided to replce the tint on my car. Water spots. Everywhere, and unending (softened and triple filtered water well water). I picked up CLR ina plastic spray, and majic eraser pads. Tried the pads and they are TOPS! I kept the solution from touching the paint, cleaned, wiped, rinsed, wiped. 95% of a back window was cleared in two passes. A few remain but they look to be a bit more than a spot. Highly recommend for any detail/tintheads out there!
      04-17-2025, 03:00 PM   #2
TboneS54
YNWA
TboneS54's Avatar
wat
      04-17-2025, 04:18 PM   #3
scubajim
scubajim's Avatar
143
Drives: 16 BMW 435 F33
My windows are not tinted but I use magic eraser regularly. Cleans very effectively.
      04-18-2025, 06:35 AM   #4
slilley
Drives: 2023 X5, plus others
Same here! The only place I don't use them is on the inside rear window, since I don't want to risk damaging the defroster leads.
      04-18-2025, 12:35 PM   #5
silvermanor
Drives: M3 comp xdrive
Magic erasers are made out of foam that is essentially like fine grit sandpaper. Not the best thing to use on glass as you're going to etch it and create fine scratches over time.
      04-18-2025, 03:47 PM   #6
scubajim
scubajim's Avatar
143
It shouldn't be used as a daily cleaner. It should always be used with a lubricant/glass cleaner. A couple times a year to remove build up on exterior glass or off gassing on interior windows.
slilley194.50
