02-15-2025, 10:00 AM | #1 |
![]() ![]() 8666
Rep 5,854
What spray do you use on your ceramic coating?
What product/ spray do you use to clean and maintain your ceramic coating?
02-15-2025, 10:16 AM | #2 |
![]() ![]() ![]() 4979
Rep 5,059
I've been happy with the Adam's "Graphene Detail Spray". But I have a newish coating on the Z4 (DIY) so it is probably hard to tell which one is doing the job. It goes on and off easily and is a low enough % that you don't need to be too worried about leaving something behind that you didn't polish / buff / whatever you call it. I do still spray it on the towel down wind just in case.
I also started putting it on my X3 that has a bunch of Zaino on it, and can tell it beads water / snow is easier to remove longer than the Zaino itself ever did. I know you're not supposed to put one type over the other but for that car I don't care a ton and it has actually been working. I tried it as a test and am glad I did. Typically I just use the normal car wash soaps but have a "strip wash" that you supposedly use once a year, but I haven't had the Z4 a full year yet so I'll give that a go this spring. |
Westside Guy8666.00 |
02-15-2025, 11:15 AM | #3 |
![]() 3510
Rep 3,060
Dr. Beasley’s.
Always and only Dr. Beasley’s. The best.
///M
02-15-2025, 11:27 AM | #4 |
![]() ![]() 8666
Rep 5,854
02-15-2025, 11:59 AM | #5 | |
![]() 1726
Rep 2,838
Clean - if the entire care is dirty - wash it. If only a section needs to be clean, I use waterless wash on a microfiber towel to wipe-off the dirt or bird poop. Maintain - all brands have some sort of spray-and-wipe ceramic "booster" product, or "detail" spray. I used to stick within the brand family of the base ceramic coating product I had used on that car. So, since I started with Adam's on two cars, I also got Graphene CS3 (which is what Adam's rep recommended for maintenance). For my McKeys and Gyeon coated cars - I either use the above, or another similar McKeys branded spray product I had bought (one or the other brand goes on sale ever so often). Frankly, they all seam to work the same, and are highly interchangeable. I don't regularly "boost" any of the coatings, nor does the coating look or bead water any different in areas where spray was recently applied. To a large extent, "boosters" are a way to add recurring revenue after selling you the ceramic coating. IMHO, a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
02-15-2025, 01:29 PM | #6 |
![]() ![]() 394
Rep 340
Drives: BMW Z4C 3.0si 3 pedal
You can make your own Elixir. Carpro and most detailers are mostly water in their bottled products. So making your own cost considerably less.
Carpro Merlins Mixture there are a lot of results, people commenting on multiple combinations. 2oz Reload / 2oz Ech20 / 28oz Distilled Water. |
02-16-2025, 03:41 PM | #7 |
YNWA
![]() 1354
Rep 1,065
Shouldn't use any spray on top of ceramic coating except to extend its life near the end, before you polish and coat again.
Use an iron x product periodically. Use good soap with no b.s. in it.
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
starlights471.50 |
02-16-2025, 10:28 PM | #8 |
![]() 3510
Rep 3,060
Nope. Just towels. But they're the best.
///M
02-28-2025, 07:45 AM | #10 |
![]() ![]() 8666
Rep 5,854
So I was visiting the shop that installed my PPF and ceramic coating and their head detailer recommended this Chemical Guys product. I just purchased it on Amazon and hope to use it shortly.
mks219.00 |
02-28-2025, 11:18 AM | #12 |
![]() ![]() ![]() 847
Rep 490
sharkymcpeterson1167.50 |
02-28-2025, 02:49 PM | #13 |
![]() ![]() 8666
Rep 5,854
02-28-2025, 03:33 PM | #14 | |
![]() ![]() 284
Rep 237
(https://www.carpro-us.com/protection...-0-500ml-17oz/) Carpro Ech20: $17.59 (https://www.carpro-us.com/wash/water...te-500ml-17oz/) vs Adams Graphene CS3: $24.99/16oz (https://adamspolishes.com/products/g...e-cs3%E2%84%A2) So, a bottle of detail spray costs half as much? And then factor in usage rate and shelf sitting time. How long are you expecting your carpro home mix to sit around for? Let's say Adam's bottle has enough to last a year of usage. I can just buy a second bottle for a second year and we're at cost equilibrium. Is Reload good to sit around for years and years and years? Are you REALLY coming out on top with the home brew? |
02-28-2025, 04:23 PM | #16 | |
![]() ![]() 394
Rep 340
Carpro Ech2o 2oz @ $1.04 /oz x 2 = $2.08 28oz of distilled Water $.50 or less. So for $6.82 you do the math and see which is the better deal. The Carpro products are shelf stable from my experience. Been doing this for 3-4 years now and no issues . Usually make about 2 batches/year depending on my usage. I use the detailer whenever I take the car out for a Cars & Coffee or club events which are often through out the year. 1 16oz bottle of something @ 25.00 gets expensive. Not to mention the Carpro Elixir works extremely well. Last edited by cbpip; 02-28-2025 at 05:45 PM.. |
02-28-2025, 05:43 PM | #17 | |
![]() ![]() 284
Rep 237
02-28-2025, 05:57 PM | #18 | |
![]() ![]() 394
Rep 340
Amazon sells the 17oz bottle for $40.00 as well as the extremely inflated price you quoted for 3.4 oz at $19.00 Buy direct from Carpro and it's $36.00 for 17 oz which is $2.12 /oz. |
02-28-2025, 05:59 PM | #19 |
![]() ![]() ![]() ![]() 2880
Rep 926
I use reload on my weekend warrior my detailer recommended it 6 years ago. I only apply once or twice a year. I think it’s best to use the same company that you used for the coating
02-28-2025, 06:12 PM | #20 |
![]() ![]() 394
Rep 340
I agree with using straight Reload as a refresh for the Ceramic coating once or twice a year .
Using the mixture as a detailer works to keep things fresh in between. Carpro sells the same mixture, but you're just paying for water at an overly inflated cost. Carpro jumped on the wagon about 2 years ago once they found out people were mixing their own detailer from Reload and Ech20 and started offering Carpro Elixir Quick Detailer . |
