      02-06-2025, 10:18 AM   #1
starlights
Drives: G05 50i
Any recommendation for DIY Ceramic coating product with 1yr + life?
Can anyone recommend at home Ceramic product that will last over 12 months per application? Does such a product exist? There are many listed with tall claims on Amazon but reading through the reviews, their claims to longevity were suspect.
      02-06-2025, 10:27 AM   #2
TboneS54
YNWA
TboneS54's Avatar
Many products exist
Here're the best I know of:
Cancoat
Gyeon One
Carpro lite
Wolfgang SCS
And I believe other brands like Mckee's 37, meguairs, adam's have their own as well.
The main thing for you is to make sure the surface is very clean before application. Whether you polish or not (you should, at least lightly), you'll want to clay bar and then panel wipe before ceramic application.
The good news is that it's never been easier to DIY a coating. They're so much more forgiving and easy to use. Don't forget quality towels - that means 70/30 fiber split. Go for at least 300 weight.
They way you worded your OP, it souds like you're incredulous that there could exist products that last 12m+ well, there certainly are. In fact, most coatings will do 24 months up to 60. Gyeon Pure and Mohs are my favorites.
      02-06-2025, 10:29 AM   #3
RussV
Drives: 2024 BMW M2
I’ve used this on 2 of my cars. Easy application and slick surface. 9+ months longevity.
https://apexsurfaceprotection.store/...ollar-9-revamp
      02-06-2025, 10:43 AM   #4
John in VA
Drives: 2015 228i M Sport
Adam's ceramic & Graphene coatings offer great protection & are DIY:
https://adamspolishes.com/collection...ramic-coatings
      02-06-2025, 10:58 AM   #5
bosstones
Drives: o_0
OP, are you specifically looking for a product that has short term durability but lasts a minimum of 1 year? Or were you unaware of the tiers of products that can last much longer (2-3yrs, 3-5yrs, etc ...)? No wrong answer either way.
There are definitely products that last more than 1 year but recommendations will depend on what time/durability/life range you are seeking.
As Tbone stated, prep is key so ensure good bonding. Poor prep + excellent ceramic product will still lead to subpar results. Similarly, periodic maintenance of the coating, as well as add a sacrificial 'top coat', can extend the life of a base ceramic coating.
      02-06-2025, 01:35 PM   #6
E90convert
Drives: F87 M2 DCT, F15 X5 M-Sport
Esoteric Detailing recommended I self-install Gyeon Can Coat if I don't want to get the car professionally detailed and coated. The expectation is 12 months of coating life.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport
Other sold cars of interest: E90 335i, S2000, E92 335xi, C6Z, F30 335i, 987.2 S
      02-06-2025, 03:39 PM   #7
starlights
Drives: G05 50i
I am looking for the longest lasting. I mentioned 12+ months because the sense I got from reading reviews on Amazon for multiple products is that they last much less time than even a year despite of the extremely long lasting claims...
Thanks and I understand reg the surface prep. Once the weather warms up I am planning to get my orbital polisher out to remove swirls and scratches. Since I will be dedicating the entire weekend to this surface prep activity it would be good to preserve the finish with a long lasting coating.
      02-06-2025, 04:40 PM   #8
akashyap
Drives: G80 M3, E46 M3, X3M
I just applied Adams Advanced Graphene coating. It was pretty easy overall the and the protection seems good. I was a bit nervous as I hadnt done it before but happy with the results. Did it a little at a time over the course of about 5 days.
E46 M3
CDV Delete, Auto Solutions 30%, SGT Coilovers, TopSpeed Exhaust
G80 M3
Stock
      02-06-2025, 08:12 PM   #9
stbm5
Drives: 2018 M5 DG
pretty much any. I'm using Feynman at the moment. personally wouldn't believe anyones specs for duration but if you want to redo in a year then most brands are good. ive use cquartz in past and liked it. the new PAN coating has good reviews. just do a good prep, gentle washes down the road and most coatings will be good.
      02-07-2025, 07:29 PM   #10
starlights
Drives: G05 50i
Thanks all. Looking at GYEON MOHS EVO. Is that considered top tier for DIY ceramics? Will likely apply two coats.
I will be doing a one or two stage paint correction as required prior to applying ceramic.
      02-08-2025, 03:52 AM   #11
Uncle Sharky
Uncle Sharky's Avatar
Drives: G87
Adams Graphene....
spazzz192.50
ccdre409.50
      02-08-2025, 05:39 AM   #12
Portimao Blue M440ix
Portimao Blue M440ix's Avatar
269
Drives: Bmw m440ix g22
Originally Posted by Uncle Sharky View Post
Adams Graphene....
Looks great! Do you have a link for the exact product.
      02-08-2025, 05:43 AM   #13
Uncle Sharky
Drives: G87
https://adamspolishes.com/products/g...collection-kit
      02-08-2025, 06:44 AM   #14
269
Thank you.
      02-08-2025, 09:51 AM   #15
bosstones
Drives: o_0
I wouldn't be surprised if some of the brands on Amazon were subpar products or maybe older variants (Gyeon CanCoat comes to mind .... original version, I think, was only intended to last several months but the newer version lasts over a year). It's also very possible that a good portion of the people didn't prep right, apply it right, or otherwise maintain the coating.
If you want the longest lasting, I think you'd need to go w/ a pro-grade product which, of course, we DIY-ers cannot buy.
I've heard good things about MoHS EVO but I think there are longer lasting ceramics (eg CarPro and Adam's). Gyeon only claims 3yrs for MoHS EVO. If you're good w/ that, go for it! Can't really go wrong w/ the major brands.
      02-08-2025, 06:22 PM   #16
starlights
Drives: G05 50i
Jeff, thanks. I will check out Adams and CarPro. I inspected my G05 today with an inspection light and fortunately 95% of the vehicle will only require 1 step correction. Regardless, it's a lot of prep work so I would naturally want the longest lasting coating.
PS - nice images on your flicker! I shot extensively as a pro until a few years ago
      02-09-2025, 09:46 AM   #17
TboneS54
YNWA
TboneS54's Avatar
You might not need a coating to last a long time because you might want to polish the car again (which would remove coating) after 2, 3 or 4 years. The odds of you keeping swirls away for years are not good.
      02-09-2025, 10:11 AM   #18
afadeev
afadeev's Avatar
1726
Drives: F80 M3
There are dozens of Ceramic coatings (avoid spray!) that claim 1+ years of durability. And there are dozens more entering the market every year.
Frankly, I haven't see any 3rd party tests to validate ANY of those cliaims.
This YouTuber is runnig a Ceramic coastings real-world test on 35 coatings, and is 6-months into the trial:
Longevity claims are highly questionable since they don't take into account your climate (AZ or AK - big difference) and how well you maintain your car (automatic car washes, or wash by hand?).
Personally, I've had 1+ years of durability with the following (in order of application, not peference):
So far, all four are holding up perfectly fine.
Water spotting is an annoyance, unless you run out to blow the water off the surfaces with a leaf blower after the rain.
Glass coatings, on the other hand, are still an ongoing challenge.
I haven't found anything that lasts more than 6 months in real life before chattering kicks in!
HTH,
a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White)
'25 Lexus RZ (White/Blue)
      02-10-2025, 01:08 PM   #19
redheat86
Drives: 24 G80
I've had excellent success with the Adams Advanced Graphene line on my winter hauler. We go up to Mt.Hood frequently in the winter which gets a ton of dirt from the rocks/sanding they do for the roads and it just sprays away using a hose. No comparison to other cermics but previously with only wax on the winter ride it required a wash mit.
      02-10-2025, 01:14 PM   #20
TallGibbs
Drives: 2024 M2 (coming Sep '24)
There is Dr. Beasley's "Pro" coating (especially if you have matte/frozen finish). I use their "regular" (non-pro) for my G87 in Frozen Portimao Blue and its fantastic! I have not tried their "pro" version though.
Non-Matte version (25+ years, lol):
https://www.drbeasleys.com/nano-resi...W90APaZpVFoaV_
Matte version (5+ years):
https://www.drbeasleys.com/matte-pai...5t63xV7wUrnnuw
Car History (oldest to newest): Accord, 318i, 330i, Prius, Prius, M2
      02-10-2025, 01:15 PM   #21
TallGibbs
starlights see above, sorry forgot to tag you in that one
      02-11-2025, 08:37 AM   #22
starlights
Drives: G05 50i
Thanks all, your responses have been very helpful with providing me options to research. For now, after a lot of you tube video comparisons (with a grain of salt at some) I am zeroing in on MOHS Evo. This video was helpful between my final two contenders :
Now researching the prep steps and wondering if Iron remover is a necessary step. My car is always garaged, doesn't get driven over 7-8K/Yr and apart from rock chips, doesn't have many micro scratches or swirls. I rinse less wash it a few times a year and follow that with wax so the surface is pretty shiny and clean..
I suspect that since my car is always garaged, any of these name brand ceramics will outlast my ownership of the vehicle.
Please continue to share your knowledge. Thanks!
