      01-08-2025, 10:51 PM   #1
IL8Apex
IL8Apex's Avatar
54
Drives: G80 M3, E36 M3
Wheel Cleaner with CCB
This my first set of CCBs, and my wheels are ceramic coated. What are you guys using as a wheel cleaning spray when there’s low dust and no iron contamination? I assume I want to stay away from any cleaner that is meant for steel brakes since they’ll like contain caustic compounds for iron dust. PH neutral is a must I guess. Any suggestions appreciated.
2025 G80 M3 6MT / Imola Red II / Silverstone / Carbon Buckets / Carbon Exterior Package / CCB / HKStudie Exhaust
1999 E36 M3 / Titanium Silver / Black Vaders / Supersprint / Jim Conforti Tune / Fikse FM10 / Single Owner
      01-09-2025, 10:41 AM   #2
chefwong
Drives: X5
Leftover car wash shampoo ......
If you have a Pressure Washer, it's really just the surface film that is needed on a mechanical wash post HP rinse
Be mindful when you dress the rubbers
      01-23-2025, 11:15 PM   #3
FSHNGRY
FSHNGRY's Avatar
Drives: INDIVIDUAL F90 M5C LCI
I use Gtechnique "Iron fallout remover" and the "Citrus foam soap" in a completely differely bucket and brushes
NOW: '21 M5|FSHNGRY|TARTUFO|CCB| MPE|KW|IND|EVENTURI|EISENMANN|DINAN|BBS|
GONE: '15 F82 M4|YMB| IND|MPE|KW|BM3|
GONE: '11 E92 335iS|BLKSPHR|OYSTER|
GONE: '05 E46 ZHP|DINAN STG3 PKG| https://www.youtube.com/channel/UCva...WCpLE9CH6t9Jeg
      01-24-2025, 06:45 AM   #4
NSXR
Drives: Acura NSX
Never use anything on CCB's beyond water and soap that has a ph of at least 7, regardless of who might tell you to do so (they probably mean well).
The reason is because the carbon core of the disc oxidizes when exposed to oxygen (or temps over 600°F), which causes the disc to degrade. If you look closely at the edges and vanes of the disc you'll see a grey metallic coating, and it's this coating that keeps oxygen (air) from getting to the disc.
On the face of the disc you'll see the tell-tale cracks, and wear indicator circles. Inside these cracks and circles is this same metallic coating, protecting the disc from oxidization.
Using products with various chemicals in them can degrade this protective layer over time and cause the disc to lose integrity.
I'm a CCB guy, so if you have any other questions, feel free to DM me.
IL8Apex54.00
      06-29-2025, 08:49 AM   #5
popeye
Drives: 2026 M4 Comp Xdrive Miami Blue
I used Mequires hot wheel cleaner for gloss black wheels yesterday. I let it sit for a couple minutes and then rinsed with a pressure washer. When I went to pull the car in the garage it felt like less bite in the brakes. Did I ruin my ccb??
2026 M4 Miami Blue | Build Journal
[/URL] https://g80.bimmerpost.com/forums/sh...0#post32111100
2024 X5 40i Skyscraper Gray (Wife's car)
      06-29-2025, 09:10 AM   #6
NSXR
Drives: Acura NSX
Ph level is 8 so you didn't damage anything with it for sure. Most likely what happened is that the rotors were still wet when you pulled it in (if not on the front side then the back side), and CCB's don't work well when wet.
      06-29-2025, 09:28 AM   #7
popeye
The car was in the garage all day not driven. I backed it out and washed it in the shade so there was zero heat in the brakes or wheels. I started pulling forward and almost hit my garage wall because it felt like it wouldn't stop.
I understand ccb doesn't bite as quick when wet and cold so I hope that is all it was.
      06-29-2025, 09:30 AM   #8
popeye
Mequires data sheel says the ph level is 13.56 whatever that means.
https://www.meguiars.com/sites/defau.../G95%20SDS.pdf
      06-29-2025, 09:57 AM   #9
Tejas1836
Tejas1836's Avatar
1476
pressure washer, dawn detergent [Ph ~8-9] but only way the really get the wheels clean is hands on, [not necessarily these but something like them]
https://www.amazon.com/BokWin-5-Fing...ef=sr_1_7?th=1
Two is One and One is None
      07-07-2025, 03:38 PM   #10
cobrar97
Drives: '22 M3cx
You're probably looking for this. P&S Brake Buster. PH Neutral, does a great job and ANY brakes in your fleet, and actually does a pretty good job of cleaning regular debris off you tires too.
https://psdetailproducts.com/product...oEnaWc-qa24SgI
      07-07-2025, 05:24 PM   #11
dudley@07726
dudley@07726's Avatar
301
I use this and it’s quite good. It’s inexpensive especially compared to the P21s I used to use. Even though my wheels are ceramic coated, I spray this stuff on but still the wheels need agitation. Just spraying something on and rinsing off doesn’t cut it. Brake dust needs to be agitated.
2025 MB CLE53 AMG
