03-25-2023, 06:11 PM | #2 |
Rep 2,815
Drives: F33 430 and F39 M35i
Why did you start a new thread?
People were answering you. Best answer: get a b58. |
03-31-2023, 06:17 AM | #4 |
Rep 530
Drives: 2019 440i XDrive GC
Did you look through the B48 engine modification thread on the forum at all? What are most people running for power? Typically you're not going to have much to gain outside of the OTS maps until you go big turbo/meth injection/port injection/etc. So my honest suggestion that should really answer your question is... stick with bolt-ons and an OTS tune. If you want more than that and have to ask this same question multiple times, you haven't done nearly enough research to go past the bolt-on level. If you're serious about making more power than OTS/bolt-ons give you, it's time you start doing serious research, call up tuning shops who work on and tune B48s, and start making connections with others who have gone past the bolt-ons stage with the B48. Asking the group is going to get you the same answers you got on the last thread (which i also answered you in).
Big power on a small engine means big money and big knowledge...
Current: 2019 440i xDrive Gran Coupe - Alpine White, Coral Red Dakota Leather, 8AT, MSport, THP, BM3; 2015 X5 35i xDrive - Mineral White Metallic, Mocha Dakota Leather; Previous: 2015 Subaru WRX - World Rally Blue, Premium, FBO+Tune
johnung4546.50 |
03-31-2023, 07:35 AM | #5 |
Rep 106
Sorry, but this is just dumb. If making big power is your goal, you bought the wrong car. Sell it, buy something else and save yourself a ton of money and headaches. You can dump $5k into that car and still not have more power than just buying something else. If you can’t afford an M3/M4, buy a B58. A simple downpipe, tune, and some E85 and you’ll have 5x the car you have now and still be very reliable.
alohasurftoad3127.50 |
03-31-2023, 08:57 AM | #6 |
Rep 4,921
alohasurftoad3127.50 chowser512038.50 |
04-01-2023, 03:12 AM | #8 |
Rep 1,826
Wires1664.50 alohasurftoad3127.50 |
04-01-2023, 07:02 AM | #9 | |
Rep 4,921
"How much hp can b48 handle on stock internals i have 330e and want to knwo how much hp it can handle. I want to get the same performace as the m3 f80/g80" but yeh, why not open a third thread to see if you can get a different answer. Would be good if you could confirm Einstein's definition of insanity: "Doing the same thing over and over expecting a different result" |
04-01-2023, 11:09 AM | #10 |
Rep 1,072
We’ve gotten a stock b48 low compression to reliably hold ~475 whp for a couple months BUT OP apparently doesn’t know how a turbo car and/or what is involved when pushing limits for boost/timing/oil pressure/etc to keep it alive when reducing safety margins.
Doesn’t cost a lot to get there, but since OP has no idea how this works, it’s best to stick to off the shelf “stage 1 stage 2” maps or buy another car
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
Wires1664.50 oem.plus_440gc366.50 |
04-03-2023, 07:04 PM | #11 |
Rep 2,815
There's a whole B48 section here:
https://f30.bimmerpost.com/forums/fo...play.php?f=422 start a third thread there and get the same answers. |
JBH661235.50 |
04-05-2023, 05:34 AM | #12 | |
Rep 39
thanks for the good knowlege ps what comression number was he running Last edited by Shahmirplayes; 04-05-2023 at 05:38 AM.. Reason: worn mesage |
04-05-2023, 06:04 PM | #13 | |
Rep 39
04-05-2023, 06:25 PM | #14 | |
Rep 39
04-06-2023, 06:33 AM | #16 |
Rep 629
04-06-2023, 06:35 AM | #17 |
Rep 530
It won't.... this is the exact response i've given 3+ times to him in 2 threads as well as a ton of other people. He's dead set on MAX power possible on a B48.
Wires1664.50 |
04-06-2023, 07:20 AM | #18 |
Rep 4,921
Looks like you are trying to make it a G80 M3, you need to redo all the suspension, engine and drivetrain. You'll need the water injection like the M2 competition for maximum power.
Happy OP? We've turned it around to "you need an actual M car again!" Patiently waiting for thread #3 to open..... |
04-21-2023, 06:30 AM | #19 |
Rep 39
