03-24-2023, 01:38 PM | #1 |
Rep 247
Washing Machine: 1, Key Fob: 0
So my key fob went through a wash cycle. I dried it out and replaced the battery. Upon leaving for work the remote unlocking/locking wouldn't work but I was able to open the car with the physical key and hold the fob up to the steering column to start it. Once at work it took a few tries but I was able to remotely lock it. When leaving work I couldn't remotely unlock it. As it sits every time I have to start the car I have to hold the key fob up to the steering column and lock it manually.
From my understanding if it starts this way the key fob electronics should be ok. I also tried replacing the battery a second time with no improvement, and also cleaned off all the metal inside the fob and the battery too. Lastly, I tried programming the fob to the car again using the method I saw in a Kies Motorsports video. I'm able to start the car via the column, shut it off, then start it again without holding the fob up again. I exit the car and the fob buttons still didn't work and once back in the car I have to use the column method to start it again. I did this twice. Is the fob toast or is there something else I can try? |
03-24-2023, 03:37 PM | #3 |
Rep 4,266
Might be stating the obvious here from past experience but did you remove the sticker on the back of the battery? I did this once on our Range Rover key and gave the dealership plenty of laughs when they discovered i'd left it on
Failing that I guess a trip to the dealers might help to see if its FUBAR
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
03-24-2023, 06:00 PM | #6 |
Rep 1,595
If your FOB's remote sending circuit is damaged, you may just have a transponder chip now. Waiting some time may allow it to dry out, but slim chance.
Options: https://f30.bimmerpost.com/forums/sh....php?t=1869591 Based on your own inclination, this may work: https://f30.bimmerpost.com/forums/sh....php?t=1896038
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
Dagstar376.50 |
03-24-2023, 10:06 PM | #7 |
Rep 16,171
In theory the fob circuitry should be water proof, but corrosion could still cause it to not function. I'd open it up and give it a thorough spraying with CRC contact cleaner.
03-27-2023, 08:07 AM | #8 |
Rep 247
I tried everything suggested with no success. I'm going to follow the advice in fe7565's links and contact a locksmith for a quote, but probably will take the cheaper route of having the chip moved to a different board. I'm sure some local electronics repair shop could do the soldering. My skill is pretty amateur.
03-28-2023, 03:03 AM | #9 | |
Rep 1,595
The used OEM FOBs on EBay have a transponder but their EEPROM is already programmed. The Chinese ones are virgin but I trust the OEM internals vs Chinese. In either case you have to swap their EEPROM with yours, unless a locksmith is willing to program it for you using their EEPROM programmer. In the DC area I was not able to find any locksmiths that wanted to work with a FEM BMW, and the same was true for national chains. It requires a lot more work and more expensive equipment than most cars and higher risk. So they ignored me. One of them wanted to charge me $100 just to sync a FOB with the car…which is shown in numerous YouTube videos and takes 2 mins. And does nothing if your remote signal circuit is broken.
