03-10-2023, 11:26 PM | #1 |
Rep 3
Drives: 2013 bmw 328xi
HELP. 2013 328xi n26
Had an issue where I ran out of gas due to faulty tank level sensor. Replaced I tank pump assembly and replaced injector at the same time because it was time anyways. But now on idle it revs up and almost dies, hesitates when I try to rev it and sounds like it’s not firing on all cylinders. No cel. Had a lean code before injectors. That’s all I’ve gotten. Any help would be amazing!
03-11-2023, 01:34 PM | #2 |
Rep 1,599
Fuel filter? Best would be to check what codes are in the car using ISTA+. Not all codes show wirth the average commercial code readers. The code(s) may help you steer towards the root problem.
Using ISTA+ also allows you to check the fuel rail pressure and fuel pumps operation, along with the injectors
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
sledge2820.00 |
03-11-2023, 01:48 PM | #3 | |
Rep 3
03-11-2023, 02:15 PM | #4 | |
Rep 1,599
sledge2820.00 |
03-11-2023, 02:28 PM | #5 | |
Rep 3
03-11-2023, 02:36 PM | #6 | |
Rep 1,599
ENET cable needed (there may be cheaper cable options): https://www.amazon.com/Ethernet-Diag.../dp/B07FVN68JR
sledge2820.00 |
