02-13-2022, 07:25 AM | #1 |
Rep 1,059
Emergency NEUTRAL gear release F48
Hi guys, I need some help here. I am unable to engage my gear shifter into neutral while in P position. With the engine switched off, handbrake released I lift the gear knob leather cover, press and hold down the yellow emergency stick, press the button on the gear knob and try to move it into N position. It wont let me do it and I dont want to force it.
Im pretty sure that is how to emergency release the car from P into N to get towed away for example. I have in the summer successfully repaired my gear selector ( broken spring ). After that I changed my cracked parking button. At that time I had to remove the gear stick while in N position. I think I rushed there and didnt place the gear stick in the right way. My car shifts positions without issues when engine is running. It is just when I park it feels a bit weird when I go from R to P. So today I decided to take out the gear stick and reseat it. No chance. Also right after the parking button fix I tried to start my car and after start I was not able to move it out of P. I had forced it kind of and then it worked. Thats why I wanted today to take it out and reseat it. Anyone has any idea how to release the gear from P ito N other than using the yellow stick? Also, if I start the car, put it into N and then pull out the gear knob. Reseat it. Is that safe? That could be one way around it but I dont know what would happen, if it is safe and most of all I dont want to damage my car. Thanks for all advice guys |
02-14-2022, 01:02 PM | #2 | |
Rep 655
As far as I know, the yellow emergency button below the leather cover is the only way to move from Parking to Neutral without starting the engine. But, you know, It's tough to push it, and you should listen to some warnings while doing it. Well, at least without disassembling the gearbox. On the other hand, I don't think removing the gear knob while the engine is running is safe. I have to say that sometimes I feel resistant while changing from P to R, and I never disassemble it like you when repairing the spring. Could it be a symptom of something worse? Hopefully not .
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
02-14-2022, 01:39 PM | #3 | |
Rep 1,059
I kinda forced the shifter out of parking. It works ever since but when going from R to P it doesnt feel 100% smooth. Unlike when I. goind from D to P. It goes easy. I will probably contact a friend who works at BMW and ask him to ask one of his mechanics. Alternatively I could get the selector out again and see whats wrong. But not sure if I can remove the surrounding trims with the shifter in. |
02-14-2022, 04:39 PM | #4 | |
Rep 655
02-15-2022, 02:00 PM | #5 | |
Rep 1,059
02-15-2022, 03:55 PM | #6 |
Rep 655
And you're probably right. I did it before knowing that I should use the yellow button to move it to N .
02-16-2022, 03:38 AM | #8 | |
Rep 910
Reading your post, imo you should take your own advice and get someone who knows. An experienced BMW mechanic should be able to tell you a) if you have a problem and b) how best to fix it without risking further damage. From my own past failures, they usually got worse when I took riskier action trying fix a previous mistake. |
03-05-2022, 07:06 AM | #9 |
Rep 1,059
update: long time but I finally managed to get on with this. I have pulled out the gear shifter rod while in parked position. No problem after putting it back. Gear goin smoothly, clearly the rod wasnt put inside straightly.
As for the emergency park release, it is still not working so Im gonna have to look at the gear selector at some point. Thats a big job but at least I know I can do it as the shifter can come out even if not in N position. |
03-07-2022, 09:39 AM | #10 | |
Rep 655
03-07-2022, 04:38 PM | #11 | ||
Rep 1,059
