Bimmerpost
4 Series
2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums EUROPE (Continental) Sport plus on 330e G20 and exhaust valve
      10-05-2021, 03:58 PM   #1
MarcusAurelius2nd
Drives: 330e M sport
Hello two questions:
1.
I know sport mode is available as standard on the 330e. But is there a way to get sport+ on it?
2.
Can the exhaust valve be opened fully on the 330e from Europe? And if so, how?
For the record my car is an m sport.
      02-24-2022, 11:59 AM   #2
HappyGuy_Holland
HappyGuy_Holland's Avatar
Netherlands
Drives: G20 330 e F31 320i F30 320i
A little late perhaps but the exhaust valve opening by default is already figured out: put the car in sport(+), rev it a few times untill valves open, find the right side exhaust end & muffler, just a few inches under there you will find a valve with a connector, disconnect the connector cable when valve is open and tape it (for care), also close off the other side (tape) and tie wrap the cable to prevent it from damaging. The valve should be open all times now.
(Found this elsewhere in this forum, havent tried it yet )
      05-06-2022, 03:55 AM   #3
johnketteridge
Drives: MY21 330E TOURING
On my 330e this didn't work.
So i used bimmerlink to open the valve and deconnected the connector then.
      05-18-2022, 12:35 PM   #4
Conezz
Drives: G20
Doesn’t BimmerLink allow you to keep it open permanently without removing connectors?
      06-21-2022, 02:30 PM   #5
Frans
Drives: 520i G30 2020
Does anyone have an answer if Sport + can be coded on the 330e?
Did it on my G30 and it makes a nice difference but can not find any tutorial or claim it works on the 330e model.
Cheers
      10-09-2022, 07:28 AM   #6
gorthol
gorthol's Avatar
Spain
64
Drives: BMW 330e 2021
2021 BMW 330e  [0.00]
Cheers
Isn't Sport Xtraboost basically Sport+ on this car? You only get the 292hp on Xtraboost.
      10-09-2022, 07:29 AM   #7
gorthol
gorthol's Avatar
Spain
64
In theory yes, in practice it didnt work on my car. So I just disconnected it and have somebody 3d-print a fake intermediate connector to hold the cable.
g20
