04-08-2021, 11:40 AM | #1 |
Rep 3
Is this possible?
Hi guys, i wanted to know if it was possible to code something in particular my BMW. My F48 doesn't have any kind of alarm installed but i wanted to code a feature like when you get out your vehicle, and lock the car with the key fob, in case any door wasn't closed properly, make the car honk to warn me about it (that the car was able to lock -basically it happens when main car door is not closed well- or feel the door isn't closed to do the locking)... just like when you try to lock your car while the engine is on, the same honking.
What I'm trying to say is that id like to make the car honk when car door is not closed properly but when it is closed properly, i don't expect it to make a honk... Hope you guys could help me in this matter, and if it is not possible to do that coding, what would you recommend me do? |
04-08-2021, 02:08 PM | #2 |
Rep 1,087
I'm pretty sure that 1) there is an immobilizer, so there is a type of "alarm" 2) the chirp/beep won't go off if any door or trunk is open. The minute you close it, it'll beep.
Test it.. get out of your car, hit the lock button and then close the door.. it'll beep then. Also open up your window, arm your car, wait until the clownnose security light blinks, then reach in and open the door.. the alarm should go off. There should also be a motion sensor, so don't be surprised if just flapping your arms inside the open window sets it off as well. |
04-09-2021, 04:52 AM | #3 |
Air Vice Marshall
256
Rep 1,639
As a point of interest, BMW did supply X1's to some places without alarms/immobilizers. Mostly where they were used as rental vehicles by tourists. Cyprus was one such place.
2012 BMW 320d Sport (F31). 2013 BMW X3 xDrive 30d M Sport (F25). 2020 BMW X1 xDrive 2.0i MSport (F48). 2022 MB EQB 300 4MATIC AMG Line Premium |
04-09-2021, 10:55 AM | #4 |
Rep 3
I think my car doesn't have that feature equipped, i just did what you said and if the main driver door isn't closed at all, and if you press the lock in the keyfob, nothing happens... No beep, no honk, and during the day is so bright and noisy i can barely see or hear the locking system to know if it worked or not. 😭
