F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > xDrive All-Wheel Drive Discussions > AR DP installed
Studio RSR
      03-05-2021, 10:45 PM   #1
dook303
Drives: f32
AR DP installed
Just went for a drive in my f32 xdrive afyer installing AR design catted DP. The install was fairly easy.
I had it all together, midpipe to DP bolted and DP to turbo bolted but redid it just to make sure it was seated properly and will not leak. I did end up with a sore and scratched wrist from sticking my hand through the wheel well to maneuver and tight the V clamp. That was a PITA. Probably spent 30 mins messing with the that clamp.
And my neck is sore as hell lol but worth the time.
      11-28-2021, 07:39 PM   #2
krunkerio
Drives: Acura ILX Hybrid Sedan 2014
I took part in the installation process. First, we tightened DPs to mid-pipes and then DPs to turbos. They have 1.5-2mm clearance between each other. Vibration caused by the exhaust, while increasing revvs. Don't think they touch each other because in this case, I would have heard a metallic sounds. Thinking now of wrapping them with termal cloth)
      02-15-2022, 07:13 AM   #3
pearlpower
Drives: 2013 328i
Notice any acceleration difference?
      02-17-2022, 11:35 AM   #4
Jvac
Drives: 2015 335i rwd
You definitely notice a difference with a sport cat installed. I put one on a few weeks ago. The car is faster. Throttle is lighter. There are lots of threads about downpipes in the engine section to read. Essentially, everyone who does this mod is happy with the result.
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
f30post
