12-03-2018, 12:02 PM | #1 |
Rep 668
Engine coolant low
Anyone had this warning? I live less than 2 miles from the dealership, so got it topped off first thing this morning when I saw the warning. But I'm still a little nervous after seeing what happened to Quickburn7's engine.
12-03-2018, 01:02 PM | #2 |
Rep 765
I had that message. About 30 seconds before my engine went Boom!
12-03-2018, 02:12 PM | #3 |
Rep 668
12-03-2018, 03:49 PM | #4 | |
Rep 668
Wondering if I can just check for a leak in my parking spot today as a tell-tale sign, without having to even start up the car if there is any issue. |
12-03-2018, 04:20 PM | #6 | ||
Rep 765
12-03-2018, 05:28 PM | #8 |
Rep 18,727
G30 guys had a few occurrence of Low Coolant message.
I did too, but after topping off, after almost a year, nothing yet. ::knock on woods::
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
12-03-2018, 05:44 PM | #9 |
155
Rep 176
Drives: BMW M5 CS, Porsche 911 GT3 RS
I had the message as well; they topped off but also replaced two coolant hoses under warranty (car has ~9200 miles). I did not have any noticeable leaking, but went from 4 weeks prior having the fluids topped off to almost none.
Good luck!
instagram: trackday.fanatic
12-03-2018, 06:03 PM | #10 |
Rep 10,190
Coolant is different than oil pressure (Quickburns issue) as others have pointed out. You can not drive the car with loss of oil pressure. Coolant low has nothing to do with pressure but instead the level. And its easily remedied as you did.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
vtknight966.50 |
12-03-2018, 06:13 PM | #11 |
Rep 668
12-03-2018, 09:01 PM | #12 |
Rep 249
I posted a similar question a month or so ago as I also got the message. Most said it was related to the lowering temperature. Not sure if it is any colder in CA recently.
r33_RGSport12997.50 |
12-03-2018, 10:35 PM | #13 |
Rep 18,727
Yea, we just hit "our" 32°F and rain recently.
12-11-2018, 10:23 PM | #14 |
Rep 27
Had this week for the first time when temp dropped to about 20F. I've ignored as it goes away if it's a bit warmer (over 30F). I guess I'll top off this wkd and see what happens.
12-09-2019, 04:59 PM | #15 |
Rep 66
Which coolant is used in the F90 as mine needs topping up and the manual doesnt state the type anywhere.
Does it have to be BMW or is another brand ok? |
12-16-2019, 08:10 AM | #16 |
Rep 162
I had the coolant level low message in my first F90 after appr. 11.000 km. We topped it up, but never got to follow it as the car was totalled shortly after that. No with the new F90 I just had the same warning at 13.000 km. Will ask the dealer now what to do.
HAZET Stahlwille Knipex German tools shipped worldwide.
http://www.jensputzier.com |
01-15-2020, 03:39 PM | #17 |
Rep 53
I've had it multiple times. I had an unknown leak back in August that looked like oil. Been running through coolant like crazy and just got told a rock punctured one of my auxiliary radiators after they pressure tested it. When you bring it in for a top off and they don't put in a crazy amount to either reservoir you should be fine. Otherwise it is something you should look into asap
2018 BMW M5 Black Sapphire Metallic
GONE - 2013 Audi S6 Phantom Black Pearl |
02-03-2020, 06:14 PM | #18 |
Rep 275
My car showed it for about 1 week. The day I took it in for service to top the coolant off the warning message went away. The mechanic told me that I had a full tank of coolant.
12-09-2020, 01:00 AM | #19 | |
Rep 162
