BMW 3-Series (E90 E92) Forum
How to get better handling? Using non-staggered setup?
06-15-2008, 11:55 AM | #1 |
Gearing
86
Rep 3,965
I've been horsing around trying to get a more neutral feel to the cars handling. It plows into corners, barely holding the road going into the turn and then with little gas the rear would break loose.
I have 19" rims. 9" up front and 10.5" at the rear on Goodyear F1s on KWv3s. Does anyone have a sense if going to non-staggered would bring the car back some neutral handling characteristics?
If at first you don't succeed ...
06-19-2008, 12:55 AM | #2 |
e21 respect
36
Rep 599
Drives: 2008 335xi Coupe
I know that Dinan in the past has used not-staggered set up to create more neutral handling cars. I am unsure the physics behind it, but the theory is the larger the rear, the more it will push the front tires.
06-19-2008, 06:35 AM | #3 |
Rep 1,035
Non-staggered rims should help with the initial understeer.
May 3, '07European Delivery, Redelivered on 6/11/07 - Monaco Blue/Beige, Steptronic, ZPP, ZCW, PDC, iDrive/Navi with RTTI, Logic 7, Xenons, HD Radio
06-19-2008, 01:37 PM | #4 |
Rep 2,576
A larger front sway bar would help with understeer. Also adding some additional negative camber in your front end would help. Some might tell you that the rear sway bar needs to be larger, but that actually does not have as big an effect as the front. Increasing the FSB helps maintain the dynamic camber on the front axle allowing for a more solid contact patch on the tire through the turn.
I don't know of any aftermarket bars though. |
