03-31-2018, 06:18 AM | #1 |
Rep 3,062
[F48] Installing EU spec instrument cluster KOMBI
Hello,
I've installed instrument cluster from eu spec version and I need to flash it with E-SYS. I've previously blanked VIN and erase the mileage. KOMBI read mileage from CAS and now it's like it was before. Problem is that I can't inject CAFD, so I have to flash it couse it has red dot and some options from donor car. Tried to flash it but with no luck, for the whole time i got error KOMBI_60_ETHERNET_63. Tried connecting via Gateway and via VIN. Tried disabling "active programming mode" and enabling "active coding mode", tried disabling Parallel programming but WITH NO LUCK. Same error for the whole time. I'm using newest full psdzdata, esys 3.27.1 and ASUS laptop with realtek card. My FA is factory, and never have problems with coding but it's my first time when I flash. My car had factory extended instrument cluster and HU_ENTRYNAV. Retrofiting hasn't been done. Help would be appreciated, really don't know what else I can do. |
