BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Remove trim from centre console on e90
      04-04-2016, 02:04 AM   #1
p-dawg
Drives: BMW F30 330D MSport
I have a Dension DAB+U along with the USB passthrough connector port fitted into my BMW e90.
It was fitted professionally and I know where the unit is fitted under the passenger footwell but the connector port is fitted inside my glovebox. As the DAB coverage is pretty poor where I am I wanted to remove it and look to sell it on.
I could take it to a place who fitted it but they will probably charge me a hours labour just to remove it. I don't think there's much to it. I just need to figure out how to take the trim up from the centre console. Does anyone know how I can lift up the metal trip by the auto gearbox so i can pull out all the wires. I also need to get to the armrest so i can remove the connector port.
Thanks
photo storage
      04-04-2016, 06:05 AM   #2
E60525d
E60525d's Avatar
Drives: 330d M Sport LCI
What aerial are you using, is it the factory shark fin?
I also have a DAB+U which is connected to the shark fin and the reception has been very impressive so far. The only area I have had bad reception is when I was in York city centre.
      04-04-2016, 06:17 AM   #3
bhurd320
Drives: 2008 320D msport
remove the gear lever gator then reach inside and pull up on the trim do the bit behind the gator 1st, if you sell the denson kit how much are you looking for it
      04-04-2016, 06:26 AM   #4
p-dawg
Really? How did you manage to connect it to the shark fin? If I could do that I think the reception would improve where I am. I'm currently using the window mount antenna which is hit and miss.
      04-04-2016, 06:28 AM   #5
p-dawg
If i was to sell it, I'd sell for about £150 which would include the usb passthrough kit.
      04-04-2016, 06:45 AM   #6
E60525d
E60525d's Avatar
You need a diversity antenna module that has the DAB connection.
You can buy them new for less than £150. I recently bought 2 used ones from ebay (albeit with no connector port) for less than £50 each.
      04-04-2016, 07:13 AM   #7
Dann
Dann's Avatar
133
Drives: E90 LCi 335i
If you do sell it I may be interested.
      04-04-2016, 07:42 AM   #8
p-dawg
Oh I didn't realise they sell for that cheap. If that is all they are worth then I'll probably just keep it.
      04-04-2016, 07:43 AM   #9
p-dawg
If I can figure out how to take it all out then I'll sell it. Oepn to offers.
      04-04-2016, 08:57 AM   #10
Dann
Dann's Avatar
133
http://www.pelicanparts.com/BMW/tech...eplacement.htm
To remove the console.
Obviously you would have to chase the antenna cable back to wherever it's stuck
