BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Replace F48 halogen headlamps and foglamps with...?
      01-21-2016, 10:08 PM   #1
metalblaze
Drives: 2018 X5 (F15)
Folks,
A newbie to BMWs and this forum. We recently got the 2016 X1 (US spec), and really enjoying the ride. We didn't get the Premium package due to several reasons, financial being one of them. We wish that BMW offered "lighting package" separately, because we miss not having the LEDs.
So, my question to the experts: What mods can be done to replace the standard H7 halogens headlamps and H8 foglamps with "superior" lights? We don't want the racer-boy "blue lamps" - but rather something that looks classy, white-ish, and generate good amount of light.
Any suggestions?
      01-21-2016, 11:08 PM   #2
bmtespar
bmtespar's Avatar
Drives: 19 X3 30i, 18 230iX Vert
You can upgrade the halogen bulbs. Anything else will either be crazy expensive or cheap and blind everyone since it's a halogen light canopy instead of s projector style light. BMW sells a $60 bulb upgrade but I believe others said they were just A Phillips or Sylvannia bulb that you can get cheaper at the auto store. Be carful with upgrading your driving lights. You can get much brighter bulbs but brighter means more heat and in such a compact design has lead to people melting the driving light assembly.
      01-22-2016, 03:51 AM   #3
KPD
KPD's Avatar
Drives: F48 xDrive 20i xLine
I can confirm BMW Genuine H8 fog lamps are in fact Osram Cool Blue Intense bulbs (64212CBI) that come in a BMW box instead of an Osram box! They also cost twice as much!! I guess it's the cost of the cardboard box. So... if you're replacing your fog lamps, don't be gullible like me. Just buy the Osram off Amazon. Alternative Philips' H8 have the same colour temperature as 64212CBI. But they cost slightly more because they have a longer lifetime (not as important for fog lights as opposed to headlights). See comparison photo here: http://f48.bimmerpost.com/forums/sho...8&postcount=22
Not sure about the regulations in the US. But bulbs cooler than 5000K aren't allowed here in the UK.
Can't comment on headlamps I'm afraid. I can only recommend buying a reputable brand (e.g. Philips, Osram, GE, etc.). Cheaper ones tend to overheat and may damage the plastic parts in your headlamp unit.
      01-22-2016, 08:18 AM   #4
metalblaze
Thanks for this info. Is this true for all F48s (with and without LED headlamps), or only those F48s which have the LED headlamps?
      01-22-2016, 08:32 AM   #5
M-Nick
M-Nick's Avatar
36
The fog lights is the same on all F48s, it doesn't matter if you have LED or halogen head lights
      01-22-2016, 08:43 AM   #6
metalblaze
Very helpful - thank you. The F48 owner's manual says that low beams are 55W H7LL (H7 long life), and the high beams are 55W H7. If I replace my current halogens with Philips X-treme vision H7s (http://www.powerbulbs.com/us/product...on-130-h7-twin), can the same bulbs be used for both low and high beams?
      01-22-2016, 09:20 AM   #7
KPD
KPD's Avatar
All variants have the same halogen fog lights (Osram Original Line 64212 here in the UK; Colour temperature is 3200K).
Just to clarify, I meant the replacement BMW Genuine blue halogen H8 bulbs (part number 63112359505) are Osram 64212CBI in my previous post.
      01-22-2016, 10:10 AM   #8
bmtespar
bmtespar's Avatar
Two. h7 head light bulbs. The only difference in between the ones you mentioned is that one is long life bulb. They do provide a brighter light as witnessed by many others but typically don't last as long.
      01-22-2016, 11:53 AM   #9
Wisly
Wisly's Avatar
Croatia
14
Drives: X1 18d
I have halogens on my 1 series.
Philips lasted very short, maybe 3 months and Osram much longer, still on it.
I put it on low beam lights. I think that high beam shines very bright no mather which bulb is there.
      01-22-2016, 01:15 PM   #10
Remmm
Remmm's Avatar
Netherlands
Drives: F48 Alpinweiss
I have led headlights and i really disliked the yellow foglights so i puy in 50w led h8 with canbus "misleaders" looks great..
Especially now the fog lights come on when opening (coded)
