BMW 3-Series (E90 E92) Forum
Vollkommen Design M Sport Lip~Help!!!
07-29-2014, 10:00 PM | #1 |
Rep 121
okay so i installed the vollkomen design m sport lip with 3m double sided tape and then i drilled the under part in with washers and screws, but the other day it started to sag and the whole front part just stopped holding, the double sided tape wont hold it. can someone help me? what should i do?
07-30-2014, 07:10 AM | #3 | |
Rep 740
Solution: pull the bumper off (10 minute job, instruction in DIY section of this forum) and mount with bolts/washers on both sides/nuts. I've had the bumper off about 5 times now, it really is very simple. Mounting a lip without pulling the bumper is not sufficient (you're not the first here with this question) |
07-30-2014, 10:48 AM | #4 | |
Rep 471
12-13-2014, 10:18 PM | #5 | |
Rep 955
9 holes, 9 screws, 9 3/16 washers and 3M (20lbs capable) double sided tape only at the top line... |
Tags |
m sport, vollkommn design front lip |
