      07-09-2018, 04:20 PM   #1
dastardly
Drives: bmw x1 e84 20d
trailer hitch help
Hi Guys
I will be fitting a westfalia trailer hitch "towbar" and vehicle specific harness shortly and my question is after I install the wiring harness and re connect the battery do I need to enter a code for the radio or any coding for the car at all or once I reconnect the battery Im good to go thanks for your replys and help Craig
      07-10-2018, 06:26 AM   #2
KWX1
KWX1's Avatar
25
Drives: X1 Xdrive35i
You will have to reset you clock. That should be it.
2014 X1 Xdrive35i /BMS intake/JB4/ GFB DV/CPE charge pipe/ VRSF downpipe/ Alpina TCU flash
      07-11-2018, 09:34 PM   #3
dastardly
ok talked to bmw no radio code but the car had to be coded to tell it a trailer harness module was connected to can-bus the tow hitch installers did this as part of the install all good now very happy with install
