      10-30-2019, 01:32 PM   #1
joakimeg
Drives: BMW 316i 2006
Post Car wont start after replacing fuel system
Hello,
I bought a x1 18d where the fuel system broke down after filling gasoline on it.
From what the seller told me the only thing missing was replacing the injectors. SO I replaced the injectors and rail.
He sounded legit and the HPFP seems new from what I can see.
The car cranks, but wont start.
Got following fault code: 4B90 Rail-pressure monitoring on engine start.
Could the pump in the tank be faulty? Is it suppose to prime on ignition?
Any ideas? Before connecting the injectors I filled a big glass of diesel coming from the HPFP and it looked good.
Do I have to program the injectors?
- Thanks!
      10-30-2019, 07:55 PM   #2
kiloTHREE
Drives: '13 xDrive28i
Did you not prime the hpfp? Uh oh...
      10-31-2019, 02:36 AM   #3
joakimeg
Can you explain more what you mean by priming it?
      11-01-2019, 07:12 AM   #4
Nesa5
Drives: BMW E84 2011
I think you should have a priming bulb somewhere on the engine to pump it by hand.
Tags
4b90, fault, hpfp breakdown, rail-pressure
