2010 2011 BMW 5 Series Forum F10 BMW F10 Coding DIY (and other Fxx models) |
11-18-2012, 02:14 PM | #1 |
Administrator
41318
Rep 21,248
See the comprehensive coding DIY and discussions @ http://www.f30post.com/forums/showthread.php?t=696777
11-18-2012, 03:54 PM | #2 |
Perennial PFC
338
Rep 1,275
Awesome Jason! Thanks for bringing this thread to our attention. I've an M5 coming in a few months and if I'm brave enough this info will help me a lot! I just read the first few pages, and if the remaining 55 pages contain as much information, this is a gold mine. 57 pages dating from May of this year up to today should give hours of worthwhile reading. Thank you.
11-25-2012, 02:37 PM | #3 | |
Rep 68
11-25-2012, 08:30 PM | #4 |
Perennial PFC
338
Rep 1,275
I'm sorry I'm of no help at the moment. Don't have a car yet and have just read about half way through the pages from Jason's link. From what I've read it seems the info used by svache came from people working on the F10 which he has adapted for the F30. You're much further into it though and probably have a better handle on the process. Svache seems very helpful, have you tried to contact him? He may know of US owners of the F10 M5 who are changing the settings. I agree, I'd want to be very sure of the settings I'm changing.
11-26-2012, 12:11 AM | #5 | |
Administrator
41318
Rep 21,248
And yes, the rest of the thread is plenty great and informational.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
11-26-2012, 10:00 AM | #6 |
Rep 90
This will obviously void your warranty, I assume... The F10 M5 will record the login attempts and next time you go for service they will see that you touched the configuration... Specially when adding paying features... like the TPMS that's like 300 Euros... Anybody has changed and then gone to the dealer for service ?
tet0010.00 |
12-19-2012, 07:49 AM | #7 |
Rep 51
12-20-2012, 12:20 PM | #8 |
OOO
Rep 27
What changes have you noticed (besides maybe the HU_NBT)? The US Spec 2013 M5 has been spot on with coding on other F10's I have done.
12-21-2012, 06:48 PM | #9 |
Rep 852
Was looking for this
BC_DIGITAL_V_KORREKTUR on the M5, but didn't see it? Am I just missing it or is it really not there? Note: I did find BC_V_KORREKTUR and disabled it. Still 4mph off (reads 74 when going 70)... anyone else successfully get their M5 to be accurate on the speedometer? Also note, that it is correctable with a *VERY SLIGHT* hardware (tire) change: But, I would prefer a software change. |
12-28-2012, 11:31 PM | #10 |
Rep 157
Just got my ENET cable today and started coding away.. Hopefully it helps some of you (if you decide to code):
**************************************** TPMS SENSOR READINGS **************************************** HU_NBT / 3001 / RDC_SAFETY -> activ / Werte=01 **************************************** AUTOMATIC HEADLIGHTS **************************************** FRM / 3050 / FLA_AUTO_AKTIV -> automatisch/ Werte=01 FRM / 3050 / FLA_VERBAUT -> aktiv HU_NBT / 3000 / HIGH_BEAM_ASSISTANT -> aktiv KAFAS2 / 3050/ FLA_ON_OFF -> aktiv **************************************** SIDE MIRROR CLOSING W/ KEYFOB **************************************** FRM / 3020 / ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN -> aktiv / Werte=01 CAS / 3003 / KOMFORTSCHLIESSUNG_FB -> activ / Werte=01 CAS / 3003 / KOMFORTSCHLIESSUNG_PA -> activ / Werte=01 **************************************** SIDE MIRROR DELAY TIME **************************************** CAS / 3003 / KMFRT_SCHLIESSEN -> wert_01 / Werte=00 (0F Default) **************************************** DRIVER'S DOOR UNLOCK ON START / STOP **************************************** CAS / 3002 / ER_KEYOUT_AUTOVR -> activ / Werte=01 **************************************** ENABLE CLOSE TRUNK FROM KEYFOB / BUTTON **************************************** HKFM_LS / 3010 / SCH_FBD -> activ / Werte=01 HKFM_LS / 3010 / SCH_TOEHKI -> activ / Werte=01 HKRM_LS / 3010 / TASTER_FBD -> activ / Werte=01 **************************************** DISABLE LEGAL DISCLAIMER **************************************** HU_NBT / 3001 / LEGAL_DISCLAIMER_TIME -> kein_ld HU_NBT / 3001 / MACRO_CAM_LEGALDISCLAIMER -> kein_ld **************************************** DISABLE PROTECTION FOR WINDOW OPENING / CLOSING (FRONT / REAR) **************************************** FRM / 3030 / FH_TUER_AUF_STOP_MAUT -> nicht_aktiv / Werte=00 JBBF / 3070 / FH_TUER_AUF_STOP_MAUT -> nicht_aktiv **************************************** DVD IN MOTION **************************************** HU_CIC / 3000 / SPEEDLOCK_X_KMH_MAX -> FF HU_CIC / 3000 / SPEEDLOCK_X_KMH_MIN -> FF HU_CIC / 3000 / VIDEO_HANDBRAKE-> Nicht_activ **************************************** HUD TURN SIGNALS **************************************** KOMBI / 3008 / HUD_PIA_BLINKER -> aktiv KOMBI / 3008 / BLINKER_HUD_ENABLE -> aktiv HU_NBT / 3000 / HUD_TURNSIGNAL -> aktiv **************************************** NAVI TRIP IMPORT **************************************** HU_NBT / 3000 / NAVI_TRIP_IMPORT -> aktiv **************************************** ENABLE ADDITIONAL CODEC SUPPORT **************************************** HU_NBT / 3000 / ENT_CODEC_OGG --> aktiv HU_NBT / 3000 / ENT_CODEC_XVID --> aktiv HU_NBT / 3000 / ENT_CODEC_VDC --> aktiv **************************************** DISABLE ACTIVE SOUND DESIGN **************************************** ASD / 3000 / Baureihe -> F021 **************************************** ADD GPS CURRENT POSITION MENU ITEM (UNDER OPTIONS) **************************************** HU_NBT / 3000 / NAVI_POSITION_MENU -> aktiv |
01-04-2013, 01:39 AM | #11 |
Rep 94
I had the auto high beam assit working fine but then I turned it off with the normal high beam stock control and now I can't get it back. What is the trick? Do i have to code again? I hope not
01-04-2013, 04:03 AM | #12 |
Rep 852
Thanks Protious. I know a lot have been looking for an undated cheat sheet.
Unfortunately, no one has found how to do the speedometer correction via coding yet for the F10 M5. If you figure it out, it would be great to add that to your list. |
01-04-2013, 07:28 AM | #13 | |
Internet Crash Test Dummy
334
Rep 1,055
Drives: F97 X3MC / F80 M3 / F90 M5
If you retrofit the stalk which has the HA button you don't need to cycle the lights anymore
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107 |
01-09-2013, 01:24 PM | #15 |
Rep 94
So I was in a 2011 GMC Terrian as a rental car the last couple days and look what it can do over bluetooth, album art from spotify and reliably show the song name (on my 13 m5 it only shows if I get the sequence of starting it right and then often does not update). So a 2011 GMC can get it right but not my 100K+ 13 BMW? Come on! Anybody know if there is anyway to enable this via coding?
01-09-2013, 10:13 PM | #16 | ||
Rep 108
Drives: X535d; M2, M3, M5, 540d, AMV8V
Garage List 2016 BMW X535i [0.00]
2015 Aston Martin V ... [0.00] 2015 BMW M4 Convert ... [0.00] 2013 BMW M5 [0.00] 2010 BMW X535d [0.00] |
01-12-2013, 08:42 AM | #18 |
334
Rep 1,055
As a few people have asked I figured I'd post a number of settings I've coded and seem to work. There're still plenty more options to explore and as I enable/discover them I'll update the post.
Also if others have settings it would be great to share them. TPMS SENSOR READINGS HU_NBT -> 3001 -> RDC_SAFETY -> activ -> Werte=01AUTOMATIC HIGHBEAM ASSIST HEADLIGHTS FRM -> 3050 -> FLA_AUTO_AKTIV -> automatisch-> Werte=01SIDE MIRROR CLOSING WITH KEYFOB / COMFORT ACCESS FRM -> 3020 -> ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN -> aktiv -> Werte=01CHANGE DELAY FOR MIRRORS FOLDING IN WITH COMFORT ACCESS CAS -> 3003 FH MASTER -> KMFRT_SCHLIESSENENABLE CLOSE TRUNK FROM KEYFOB BUTTON HKFM_LS -> 3010 -> SCH_FBD -> activ -> Werte=01DVD IN MOTION HU_CIC -> 3000 -> SPEEDLOCK_X_KMH_MAX -> FFHUD TURN SIGNALS KOMBI -> 3008 -> HUD_PIA_BLINKER -> aktivNAVI TRIP IMPORT HU_CIC -> 3000 -> NAVI_TRIP_IMPORT = aktivDRIVER'S DOOR UNLOCK ON START / STOP CAS -> 3002 -> ER_KEYOUT_AUTOVR -> activ -> Werte=01DISABLE LEGAL DISCLAIMER HU_NBT -> 3001 -> LEGAL_DISCLAIMER_TIME -> kein_ldDISABLE PROTECTION FOR WINDOW OPENING / CLOSING (FRONT / REAR) FRM -> 3030 -> FH_TUER_AUF_STOP_MAUT -> nicht_aktiv -> Werte=00ENABLE GPS SYNC FOR CLOCK KOMBI -> 3000 -> Anzeige_Konfiguration -> GPS_UHR -> aktivENABLE DVD/VIDEO VIA USB PORT (AND VARIOUS MEDIA) HU_NBT -> 3003 -> API_USB_VIDEO --> bothENABLE HUD DISPLAY FOR ENTERTAINMENT LIST AND TELEPHONEBOOK ENTRIES KOMBI -> 3000 -> HUD_ENTERTAINMENT_ENABLE -> aktivENABLE WIFI HOTSPOT HU_NBT > 3003 -> WLAN_STATUS -> aktivENABLE THE IPCE WEBSERVER HU_NBT > 3000 -> IPCE_WEBSERVER
01-12-2013, 01:20 PM | #19 |
Rep 852
Thank you JMH - very nice!
Can you talk some more about the WIFI HOTSPOT and DLNA/UPnP server? Does it allow you to "pull" from the DLNA server to the car? Or are you able to "push" to the car from the laptop (acting as a server)? or something else? |
01-12-2013, 03:35 PM | #20 |
Rep 51
Definitely a great list... thank you.
Have you tried coding the following? If so, would you have info on the parameters? * I-Drive: display torque and power info * I-Drive: show M lap timer * Hazard flasher button: have the lights do a double flash instead of standard * Nav: show fuel station icon when the fuel light comes on I've read about these in other forums and figured it might be good to include in your overall list. Thanks again.
* 2021 BMW X7 M50i * 2016 BMW F10 M5 Pure Metal Silver Limited Edition * 2008 Lexus GX470 * 2000 Acura NSX-T |
01-13-2013, 07:35 AM | #21 | |
334
Rep 1,055
You can enable HU_CIC -> 3000 -> NAVI_FUELSTOP_PROPOSAL , this enables fuel stop icons on your NAV map once the fuel level is low enough. The icons will also display the gas station brand. There's another setting I haven't applied yet (TYPE_OF_FUEL) which should allow you to select the type of fuel preference when you use BMW Online for fuel price display. Haven't done the Hazard flash lights either For something fun you can try and enable KOMBI -> 3008 -> R_GANG_AKUSTIK_ENABLE (Enables the reverse gear gong for Japan, seems not to work for everyone, but if it does it might be "interesting" )
01-13-2013, 09:20 AM | #22 | |
334
Rep 1,055
If you have a client (laptop/itouch/iPad/Android phone/tablet, DLNA enabled hard drives etc) which support DLNA you'll be able to connect as a client and stream music/video . You should see a new media source (USB, Library, Bluetooth etc)
