08-07-2020, 09:46 AM | #1 |
Rep 40
Vehicle Check?
My wife 2014 X1 Xline N20 with 90k kms has recently had a service warning on the idrive "Vehicle check". No warranty left on car. Anything I should know?
Service in last year and half: Total brake service and flush Rad Flush New tires New plugs on list of things to do. Check the inter web sounds like a more stealership BS. Inspection Details: BMW brakes Checking all safety systems Checking all interior lights Checking all exterior lights Checking windscreen washer system and toping up fluid level if necessary. Checking all Tyres for tread depth, patter of wear, overall condition and inflation pressure. Check BMW Mobility system (if applicable) Initialise run flat indicator (if applicable) Checking engine coolant level and concentration. Re-adjust mixture ratio or top up where necessary. Checking headlamp exterior condition and functionality. Checking steering fluid reservoir oil level (if hydraulic steering) Checking all brake lines and connections for tightness and correct positioning Checking under body and all visible parts for damage, correct positioning and tightness Checking steering system for failures, play, leaks, damage and wear Test Driving - Checking brakes, steering, shock absorbers and gearbox Exterior and interior is washed. Your BMW Service history is fully updated.
2010 RX-8 R3 Sparkling Black
2015 BMW X1 1992 RX-7 Type X Vintage Red (JDM FD3S) (Sold) 2006 RX-8 GT GG (Sold), 2009 RX-8 R3 VR Red (Sold) 2013 BMW 135i Sport (Sold) |
08-07-2020, 11:31 PM | #2 |
Rep 158
Yeah, it’s just a check interval programmed in. Like you mentioned, plugs are due. Did mine at about that same mileage. You will notice a difference once they are in.
-Steve
2015 BMW X1 35i MSport // BMS Intake |
