      10-24-2021, 04:53 PM   #1
PRTSB1M
Drives: AW3 1M
Euro MDM (coding MK60)
I'm preparing to code my car for euro-spec MDM and was wondering if anyone else has modified the settings in MK60 module for their 1M and can comment on their experience? I found this thread for E9x M3, but there is a custom setup for 1M in NCSDummy.
Code:
Generated with NCS Dummy version 0.6.10 — copyright İ 2020 revtor
Output       : Module Functions
Chassis      : E89  (E81,E82,E84,E87,E88,E89,E90,E91,E92,E93)
Module       : MK60_M82.C01
FUNCTION KEYWORD         ADDRESS (LENGTH)   MASK         FUNCTION KEYWORD TRANSLATION                            OPTIONS
    PARAMETER KEYWORD        DATA               MASKED       PARAMETER KEYWORD TRANSLATION
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
DSC_Codierdaten          00300000 (12)                   Dynamic stability control (DSC) coding data
CHECKSUM                 00300000 (01)      FF           CHECKSUM
    grundcode_var            00                 00           basic code variable                                 PL2
<UNBELEGT>               00300001 (01)      1F           <UNOCCUPIED>
    <initwert>               00                 00           <initvalue>
<UNBELEGT>               00300001 (01)      E0           <UNOCCUPIED>
DRUCKMODELL_HA           00300002 (01)      07           PRESSURE MODEL REAR AXLE
    wert_00                  00                 00           value 00                                            !MAN_UMF_GTS
    wert_01                  01                 01           value 01                                            MAN_UMF_GTS
DRUCKMODELL_VA           00300002 (01)      38           PRESSURE MODEL FRONT AXLE
    wert_01                  01                 08           value 01                                            MAN_UMF_GTS
GETRIEBE_E82M            00300002 (01)      C0
    wert_00                  00                 00           value 00                                            !M_DOPPEL_KUPPEL
    wert_01                  02                 80           value 01                                            M_DOPPEL_KUPPEL
<UNBELEGT>               00300003 (01)      01           <UNOCCUPIED>
    <initwert>               01                 01           <initvalue>
PRE_MSR_E82M             00300003 (01)      02           E82 (1 SERIES M COUPÉ) PRE ENGINE DRAG-TORQUE CONTROL
    aktiv                    00                 00           enabled
    nicht_aktiv              01                 02           not enabled                                         PL2
<UNBELEGT>               00300003 (01)      04           <UNOCCUPIED>
RPA                      00300003 (01)      08           TIRE PUNCTURE WARNING (RPA)
    nicht_aktiv              00                 00           not enabled                                         DIRECT_RDC
    aktiv                    01                 08           enabled                                             !DIRECT_RDC
<UNBELEGT>               00300003 (01)      10           <UNOCCUPIED>
<UNBELEGT>               00300003 (01)      20           <UNOCCUPIED>
    <initwert>               01                 20           <initvalue>
US_VEHICLE               00300003 (01)      40           USA VEHICLE
    nicht_aktiv              00                 00           not enabled                                         PL2
    aktiv                    01                 40           enabled
<UNBELEGT>               00300003 (01)      80           <UNOCCUPIED>
    <initwert>               01                 80           <initvalue>
UEBERSTEUERN_MUE_0       00300004 (01)      FF           OVERSTEER FRICTION COEFFICIENT 0
    wert_00                  E6                 E6           value 00                                            !US
    wert_01                  33                 33           value 01                                            US
UEBERSTEUERN_MUE_1_2_M   00300005 (01)      FF           OVERSTEER FRICTION COEFFICIENT 1 2
    wert_00                  E0                 E0           value 00                                            !US
    wert_01                  ED                 ED           value 01                                            US
<UNBELEGT>               00300006 (01)      FF           <UNOCCUPIED>
    <initwert>               A6                 A6           <initvalue>
<UNBELEGT>               00300007 (01)      FF           <UNOCCUPIED>
    <initwert>               80                 80           <initvalue>
<UNBELEGT>               00300008 (01)      FF           <UNOCCUPIED>
    <initwert>               40                 40           <initvalue>
<UNBELEGT>               00300009 (01)      0F           <UNOCCUPIED>
    <initwert>               03                 03           <initvalue>
<UNBELEGT>               00300009 (01)      F0           <UNOCCUPIED>
    <initwert>               0B                 B0           <initvalue>
<UNBELEGT>               0030000A (01)      0F           <UNOCCUPIED>
DDS_PLUS                 0030000A (01)      10
    aktiv                    01                 10           enabled
MDYNAMIC_MODE_USA        0030000A (01)      20           BMW M DYNAMIC MODE USA
    nicht_aktiv              00                 00           not enabled                                         !US
    aktiv                    01                 20           enabled                                             US
<UNBELEGT>               0030000A (01)      40           <UNOCCUPIED>
<UNBELEGT>               0030000A (01)      80           <UNOCCUPIED>
<UNBELEGT>               0030000B (01)      FF           <UNOCCUPIED>
    <initwert>               E5                 E5           <initvalue>
<UNBELEGT>               0030000C (01)      FF           <UNOCCUPIED>
    <initwert>               E4                 E4           <initvalue>
<UNBELEGT>               0030000D (01)      07           <UNOCCUPIED>
<UNBELEGT>               0030000D (01)      08           <UNOCCUPIED>
    <initwert>               01                 08           <initvalue>
<UNBELEGT>               0030000D (01)      10           <UNOCCUPIED>
    <initwert>               01                 10           <initvalue>
<UNBELEGT>               0030000D (01)      20           <UNOCCUPIED>
<UNBELEGT>               0030000D (01)      40           <UNOCCUPIED>
    <initwert>               01                 40           <initvalue>
LAT_EBD                  0030000D (01)      80
    nicht_aktiv              00                 00           not enabled                                         !(COMPETITION_P,E82+N54B30T0)
    aktiv                    01                 80           enabled                                             COMPETITION_P,E82+N54B30T0
<UNBELEGT>               0030000E (01)      0F           <UNOCCUPIED>
<UNBELEGT>               0030000E (01)      10           <UNOCCUPIED>
<UNBELEGT>               0030000E (01)      20           <UNOCCUPIED>
<UNBELEGT>               0030000E (01)      C0           <UNOCCUPIED>
<UNBELEGT>               0030000F (01)      FF           <UNOCCUPIED>
<UNBELEGT>               00300010 (01)      0F           <UNOCCUPIED>
<UNBELEGT>               00300010 (01)      F0           <UNOCCUPIED>
<UNBELEGT>               00300011 (01)      0F           <UNOCCUPIED>
<UNBELEGT>               00300011 (01)      F0           <UNOCCUPIED>
DCC_Codierdaten          00300012 (0D)                   Dynamic cruise control (DCC) coding data
<UNBELEGT>               00300012 (01)      07           <UNOCCUPIED>
<UNBELEGT>               00300012 (01)      38           <UNOCCUPIED>
<UNBELEGT>               00300012 (01)      C0           <UNOCCUPIED>
<UNBELEGT>               00300013 (01)      07           <UNOCCUPIED>
<UNBELEGT>               00300013 (01)      38           <UNOCCUPIED>
<UNBELEGT>               00300013 (01)      40           <UNOCCUPIED>
<UNBELEGT>               00300013 (01)      80           <UNOCCUPIED>
<UNBELEGT>               00300014 (01)      3F           <UNOCCUPIED>
MSA                      00300014 (01)      40           AUTOMATIC START/STOP (MSA)
    nicht_aktiv              00                 00           not enabled                                         !CO2_MSA
    aktiv                    01                 40           enabled                                             CO2_MSA
ABSCHALTBARKEIT_DSC      00300014 (01)      80           DYNAMIC STABILITY CONTROL (DSC) CAN SWITCH OFF
    nicht_aktiv              00                 00           not enabled                                         SIXT
    aktiv                    01                 80           enabled                                             !SIXT
<UNBELEGT>               00300015 (01)      FF           <UNOCCUPIED>
<UNBELEGT>               00300016 (01)      FF           <UNOCCUPIED>
<UNBELEGT>               00300017 (01)      FF           <UNOCCUPIED>
<UNBELEGT>               00300018 (01)      7F           <UNOCCUPIED>
<UNBELEGT>               00300018 (01)      80           <UNOCCUPIED>
<UNBELEGT>               00300019 (01)      FF           <UNOCCUPIED>
<UNBELEGT>               0030001A (01)      FF           <UNOCCUPIED>
<UNBELEGT>               0030001B (01)      FF           <UNOCCUPIED>
<UNBELEGT>               0030001C (01)      FF           <UNOCCUPIED>
<UNBELEGT>               0030001D (01)      07           <UNOCCUPIED>
<UNBELEGT>               0030001D (01)      38           <UNOCCUPIED>
<UNBELEGT>               0030001D (01)      C0           <UNOCCUPIED>
<UNBELEGT>               0030001E (01)      1F           <UNOCCUPIED>
<UNBELEGT>               0030001E (01)      60           <UNOCCUPIED>
POHO                     0030001E (01)      80
    aktiv                    01                 80           enabled
ESM_Codierdaten          0030001F (11)
<UNBELEGT>               0030001F (01)      FF           <UNOCCUPIED>
<UNBELEGT>               00300020 (01)      FF           <UNOCCUPIED>
<UNBELEGT>               00300021 (01)      FF           <UNOCCUPIED>
<UNBELEGT>               00300022 (01)      FF           <UNOCCUPIED>
<UNBELEGT>               00300023 (01)      FF           <UNOCCUPIED>
<UNBELEGT>               00300024 (01)      FF           <UNOCCUPIED>
<UNBELEGT>               00300025 (01)      FF           <UNOCCUPIED>
<UNBELEGT>               00300026 (01)      FF           <UNOCCUPIED>
<UNBELEGT>               00300027 (01)      FF           <UNOCCUPIED>
<UNBELEGT>               00300028 (01)      0F           <UNOCCUPIED>
<UNBELEGT>               00300028 (01)      F0           <UNOCCUPIED>
<UNBELEGT>               00300029 (01)      FF           <UNOCCUPIED>
<UNBELEGT>               0030002A (01)      FF           <UNOCCUPIED>
<UNBELEGT>               0030002B (01)      FF           <UNOCCUPIED>
<UNBELEGT>               0030002C (01)      FF           <UNOCCUPIED>
<UNBELEGT>               0030002D (01)      FF           <UNOCCUPIED>
<UNBELEGT>               0030002E (01)      FF           <UNOCCUPIED>
<UNBELEGT>               0030002F (01)      FF           <UNOCCUPIED>
SZL_Codierdaten          00300100 (01)
<UNBELEGT>               00300100 (01)      7F           <UNOCCUPIED>
    <initwert>               07                 07           <initvalue>
<UNBELEGT>               00300100 (01)      80           <UNOCCUPIED>
I think that DRUCKMODELL settings for MAN_UMF_GTS could be a compensation for the larger diameter brakes that came on the M3 GTS. Can anyone confirm/deny this?
More interestingly, does anyone know what PRE_MSR_E82M setting controls?
NCSDummy says this is
Code:
      10-24-2021, 07:09 PM   #2
ayao
Thread killer
646
Drives: 1M
I'm not sure if this thread will help?
https://www.1addicts.com/forums/show....php?t=1260003
      10-24-2021, 07:48 PM   #3
PRTSB1M
Drives: AW3 1M
Thanks for sharing I actually think the MSR is for DCT launch control, after looking at it a little closer and comparing to M3/Z4. Now I feel like I have to get another 1M and DCT swap it, all the options appear to be present for it.
      10-28-2021, 05:08 PM   #4
PRTSB1M
Drives: AW3 1M
I was able to get the coding done today. Here is what I read from the car:
Code:
RPA
	nicht_aktiv
MSA
	nicht_aktiv
MDYNAMIC_MODE_USA
	aktiv
LAT_EBD
	aktiv
US_VEHICLE
	nicht_aktiv
POHO
	nicht_aktiv
DDS_PLUS
	nicht_aktiv
ABSCHALTBARKEIT_DSC
	aktiv
DRUCKMODELL_HA
	wert_00
DRUCKMODELL_VA
	wert_00
GETRIEBE_E82M
	wert_00
PRE_MSR_E82M
	nicht_aktiv
UEBERSTEUERN_MUE_0
	wert_01
	wert_01
Here is what I modified it to:
Code:
RPA
	nicht_aktiv
MSA
	nicht_aktiv
MDYNAMIC_MODE_USA
	nicht_aktiv
LAT_EBD
	aktiv
US_VEHICLE
	nicht_aktiv
POHO
	nicht_aktiv
DDS_PLUS
	nicht_aktiv
ABSCHALTBARKEIT_DSC
	aktiv
DRUCKMODELL_HA
	wert_00
DRUCKMODELL_VA
	wert_00
GETRIEBE_E82M
	wert_00
PRE_MSR_E82M
	nicht_aktiv
UEBERSTEUERN_MUE_0
	wert_00
	wert_00
Unfortunately, it is another rainy day, so I will have to report back later with more details on noticeable driving dynamics changes.
ayao646.00
      10-30-2021, 04:18 PM   #5
PRTSB1M
Drives: AW3 1M
After testing on semi-dry roads today, I can say that the rear end definitely comes farther around and the interference that does occur definitely seems less like “fun time is over” and more like “let us keep you on the road.”
I have previously installed a drexler differential in my car, so YMMV, but it feels much better
ayao646.00
      10-14-2022, 09:18 AM   #6
PRTSB1M
Drives: AW3 1M
I was digging back into MK60 coding, and did a side-by-side comparisons in NCSDummy of 1M vs M3 data values, option codes, etc. Stock US 1M values are the same as US E92 M3, for both 'OVERSTEER FRICTION COEFFICIENT' settings; which could explain why it's a little too intrusive.
Euro 1M setting for MUE_0 is the same as Euro E92 M3: E6
Euro 1M setting for MUE_1_2 is a unique value, not used for any M3 variant: E0
- for this setting NCSDummy shows calculated values for M3 MK60
- the calculated value for Euro 1M is 2 m/s^2, whereas Euro E92 M3 is 1.703 m/s^2
- the calculated value for US 1M/E92 M3 is 2.203 m/s^2
ayao646.00
      10-15-2022, 02:41 PM   #7
ayao
Thread killer
646
Drives: 1M
I do not fully understand the practical implications of what you've found in the 1M vs M3 NCSDummy comparison?
      10-16-2022, 07:37 AM   #8
PRTSB1M
Drives: AW3 1M
We know that 1M is a parts bin car, mixing E82 135i with E92 M3. We also know that BMW has held back performance features from US market cars. I was just trying to show exactly what those differences are.
As an engineer, I work from the assumption that these parts are mostly the same, with some different firmware versions to properly interpret the settings. For example, M3 MK60 shows 8 possible values (wert_00-wert_07) for the oversteer friction coefficients, whereas 1M MK60 shows 2 possible values (wert_00-wert_01). Here is a breakdown:
US MUE_1_2
E93 M3: 3.5 m/s^2
E90 M3: 2.797 m/s^2
E92 M3: 2.203 m/s^2
E82 1M: 2.203 m/s^2
Non-US MUE_1_2
E93 M3: 2.594 m/s^2
E82 1M: 2.000 m/s^2
E92 M3: 1.703 m/s^2
E92 M3 GTS: 1.703 m/s^2
Now that I'm looking at it again, I don't see a listing for Euro E90 with S65B40, only with S65B44 (which should be GTS engine); so it might be that Euro 1M and Euro E90 M3 have same MDM settings.
I don't know the exact calculation, but, thinking about safety, I would assume that BMW would reduce customer's ability to drift in E93 where there is no roof to keep unbelted passengers in the car. My extrapolation being that the larger the MUE_1_2 value is, the sooner the ECU will intervene for you.
ayao646.00
      10-16-2022, 08:04 AM   #9
PRTSB1M
Drives: AW3 1M
I will make another assumption now that you've got my noodle going... I think that MDYNAMIC_MODE_USA being active removes the steering angle sensor from the calculations; which is why it is such a quick end of sliding. I bet if you leave the oversteer friction coefficients alone and just switch this off, the MDM will be more graceful on US cars.
ayao646.00
1addicts
