09-02-2023, 06:13 PM | #1 |
Rep 1,415
Driver side window smear
How to deal with window smear? Any time I wash the car, the driver side window starts smearing like in the enclosed picture. Even later when everything is dry, it still smears, but not as bad.
Rob |
09-04-2023, 12:16 PM | #2 |
Rep 2,359
Is there something on the weatherstripping leaving this mark? Window mechanism or vapor barrier? I'd take the door panel off to investigate.
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
tracer bullet3445.50 |
09-04-2023, 01:05 PM | #3 |
The Seeker
14954
Rep 3,685
There are various guides that are (usually) felt-covered in there, you've probably lost one (no fault of your own), so the door panel has to come off to find/fix it. Have a pair of disposable gloves handy, it's a dirty job because of the sealant they use. I've never taken my BMW door panel off, but they're all pretty much the same.
c.parra1.50 |
09-04-2023, 02:12 PM | #4 |
Rep 1,250
Drives: 2009 E92 M3 Dakar Yellow II
if you pull the vapor barrier off make sure your get some 3m Window Weld or other such butyl tape to make it water tight again, this is very important.
chassis7600.00 |
09-04-2023, 05:17 PM | #5 |
Rep 2,359
When working with the vapor barriers I try to do all I can by pulling it down from the top & sides, without removing the bottom edge in hopes that they won't leak later. A heat gun helps make the butyl caulk adhere better.
12-27-2023, 04:43 AM | #6 |
Rep 1,285
Drives: 2022 x5 40!
These new cars don’t have that anymore unless it’s behind this plastic shell when you take the door panel off with my experience, installing Removing the door panel to get to the speaker it’s not like a plastic vapor barrier that you use to find when you took the door Panel off . Almost like a composite shell
12-27-2023, 07:41 AM | #7 | |
Rep 2,359
12-27-2023, 08:37 AM | #8 |
11104
Rep 27,832
have you checked the area where the window rolls down into your door? the material that protects the window? could be something like a bug or something caught in there so every time it rolls down its getting impacted by whatever is in there
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
12-27-2023, 12:25 PM | #9 |
Rep 893
Start simple first before tearing things apart. Put the window all the way down and use a damp microfiber cloth (with some diluted all purpose cleaner) to clean the seals where the window slides up and down and see if that helps.
2024 M3 CompX Dravit Grey - MP HAS - Millway - MHC+ carbon - CS software - Fabspeed - MAD - PPF
2019 G05 X5 x40i, built 2001 600whp B5 S4. |
Unimatrix074.00 Westside Guy6772.50 |
