07-29-2017, 12:04 PM | #1 |
Rep 184
2 new tires
2013 xdrive 28i. Running Conti DWS 06. Nails in both right-side tires - the front was just above the tread into the sidewalk, so not plugable. I got 2 new ones, thinking the new would go on the rear, the bad tire would be trashed, and the plugged tire will become a spare. Picked-up the car in the pouring rain, so didn't look close till later in the day. I was surprised they put the new tires on the front - maybe they thought it's FWD?
Question 1: New on the rear or front? Question 2: Where to get an inexpensive rim for the spare? Thanks! |
07-30-2017, 10:10 AM | #3 |
Rep 2,411
What's the mileage/tread depth on the new ones? You have to be careful to not go too different in overall diameter for the sake of the center diff.
My X1 wears rear tires significantly quicker than the fronts...so that's at least one reason to start them off in the rear...to get them evened up with the front asap.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
07-30-2017, 10:14 AM | #4 |
Rep 485
Discount tire is a very good dealer in the US, and they'll put the new one on the back if it's same size all around.
The idea is that if either rear tire blows, it makes vehicle unstable, and prone to flip as it spins around. If the front blows it just pulls hard that direction, but understeers so no spin. Even as a tire seller we just put em where it felt right, and if I had FWD only vehicle, i think I'd put up front, and leave minimal tread on back where no wear. |
07-30-2017, 11:33 AM | #5 |
Rep 40
Unless there's a major compelling reason to do it otherwise, Always put new tires on the rear. Better traction in the rear reduces the chance of spinning under braking.
https://www.tirerack.com/tires/tiret...jsp?techid=236 |
07-30-2017, 01:46 PM | #6 |
Rep 184
Although I don't have a proper tread depth measuring tool, I get the difference to be about 3/16. The new tires are totally new, 0 miles. The owner's manual is silent on the topic.
07-31-2017, 10:25 AM | #7 |
Rep 184
I just talked with my service advisor at my BMW dealership. He said there is no issue as long as same size tires are on the same axle. He said he typically advises that the new tires be placed on the front, but acknowledged that opinions vary.
07-31-2017, 11:47 AM | #8 | |
Rep 435
You'll get a larger diameter variance in the camber of the tire and how the vehicle is weighted and tire pressure. I've always believed this to be nothing but tire sales driven. |
07-31-2017, 06:57 PM | #9 | |
Rep 2,411
And for what it's worth, I've read more than a few threads about serious issues on xdrive cars running staggered setups with differring diameters at each axle.
07-31-2017, 07:03 PM | #10 | |
Rep 2,411
I mean, at a minimum, the greater the difference, the greater the heat/wear on the unit. Whether or not you should really be worried about a failure or not is a different story, I agree. I don't think one could argue against the fact that a LSD is going to last longer the closer each end is 1:1. Certainly it would.
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) Last edited by PrematureApex; 07-31-2017 at 07:09 PM.. |
07-31-2017, 07:19 PM | #11 |
Rep 435
The problem is the same manufacturer changes it service intervals according to what their warranty covers or doesn't. It's easy legally to point blame to tire size difference when shit hits the fan.
07-31-2017, 07:24 PM | #12 |
Rep 184
Gheez, I have the BMW dealer and my 40 years in business tire guy saying "no issue". I looked around online but I could only find discussions of "potential" problems, but didn't find any with actual problems. I have a lot of respect for your knowledge, Prem Apex.
What to do? If issues arise, are there any warnings? Thanks |
