08-20-2017, 08:09 PM | #45 |
Rep 330
08-24-2017, 08:26 PM | #46 |
Rep 277
09-10-2017, 09:27 AM | #47 |
Rep 22
E38 M-PARS with 245/40/18 FRONTS & 275/35/18 REARS
No rubbing in the front or rear at stock ride height. I will update this once I lower it on H&Rs.
2015 E84 x128i/Alpineweiss/TunerWerks Module/E38 MPARS/
1991 Toyota Soarer - turbo6 Last edited by kapetajr; 09-10-2017 at 09:33 AM.. |
09-10-2017, 04:23 PM | #48 |
Rep 277
09-11-2017, 11:58 AM | #49 |
Rep 22
Thanks for the info. Can the tap be taken care of with a dremel or cutoff wheel?
1991 Toyota Soarer - turbo6 |
09-14-2017, 05:37 AM | #51 |
Rep 277
I used a Dremel to cut the tap then sprayed some black paint on it
09-14-2017, 05:38 AM | #52 |
Rep 277
09-15-2017, 08:23 AM | #55 |
Rep 435
09-15-2017, 08:55 AM | #56 | |
Rep 22
Toyo Proxe 4's http://www.toyotires.ca/tire/pattern/proxes-4 No issues so far, I have driven about 1000km's with the tires. Doing the Tcase, Diff and Transmission pan/fluids this weekend.
09-15-2017, 02:41 PM | #57 |
Rep 435
09-16-2017, 08:58 PM | #58 |
Rep 113
Any links to the theory ? I'm interested because they just changed my transfer case last week under warranty. I don't want to pay the bill if it arrives again because of wrong size of tires. My warranty expires next week.
09-17-2017, 03:38 PM | #59 | |
Rep 22
"The tire circumference can fluctuate up to 1% or more as a result of mixed tires or wear. The tire tolerance logic decides depending on the driver's command and driving situation whether the slip is to occur in the transfer case clutch or at the contact area between tire and road. If the slip is permitted in the transfer case clutch, the locking pressure set by the pre-con- trol is reduced in order to keep the work loss low. In the driving dynamic control situation, the clutch is locked slightly more than normal, the four wheel drive is always guaranteed when required. For maximum xDrive performance, tires (and wheels) of the same diameter should be installed on the vehicle." |
09-18-2017, 10:59 AM | #61 |
Rep 435
Besides common sense?
In fact some vehicles these days use ABS sensors to measure when a tire is low on air instead of physical sensors in the wheels. This works because it compares the number of rotations on one wheel to another. When the tire is low, the number of rotations will be higher thus tripping the TPMS idiot light. |
09-19-2017, 03:15 AM | #62 |
Rep 277
Here is more pictures of the rear setup. I got new faces to pull in the rear about a half inch which will give me more clearance from the fender. My KW are settling and are not as soft anymore. I ll post more pictures when my new faces come back from powder coating. Also remember that is a 5" lip in the rear. Lol
09-19-2017, 07:23 PM | #63 | |
Rep 113
09-19-2017, 08:40 PM | #64 |
Rep 435
Yep this is where I give up because it seems like there may be a lot that doesn't make sense in your world sorry, no hard feelings.
02-22-2018, 11:43 AM | #66 |
Rep 4
Hello, New to this forum, just bought a 2012 X1 28i.
After seeing these pictures i'm excited to change out the stock 17's for some of the iconic BMW styles. Has anyone ever put an 8" wide 17 rim on the x1? Would this require a spacer? I'm not sure what the offset is on the rims I'm looking at, but i'm being told either 34 or 40. Thanks! |
