      04-27-2013, 04:20 PM   #1
Blackwood74
Drives: 2012 x1
N20 engine malfunction light
Folks,
I'm new to this forum. I have a 2012 X1 xdrive28i with 19,000kms on it. I've had the car for a year with no issues whatsoever until this weekend.
On a road trip i was on the engine lost significant power and this Engine Malfunction Loss of Power code appeared. I turned off the engine and waited, restarted and the code cleared and all was fine. Upon my return home the code appeared 3 more times.
I do have an appt scheduled for Monday. Has anyone here experienced this and what came from it?
Cheers
      04-27-2013, 04:39 PM   #2
edx1
Drives: X1 xDrive35i
Not really, maybe check your gas cap.
I also watch the other forums with the same engine and haven't seen any "common" reasons for any engine errors. There have been very few reports of problems so far.
      04-27-2013, 04:55 PM   #3
HotRodW
HotRodW's Avatar
Drives: 2013 X1 xDrive28i M Sport
Fuel injector? A few have reported problems with those.
      04-27-2013, 07:19 PM   #4
CIWS
Moon Parasite
CIWS's Avatar
Drives: F30 335i MSport
Check with your local auto parts store and see if they will read the codes for you, it won't tell you a bad part per se (unless a gas cap) but it will give the code(s) for whatever malfunctions it saw.
2015 335i MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe -LLumar FormulaOne ceramic tint-aFe intake scoop and Pro Dry drop-in filter.
Was - 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged
      04-30-2013, 08:12 AM   #5
Blackwood74
Drives: 2012 x1
Thought I'd update you all. Looks like the turbo wastegate system failed. It's a fairly extensive job but its under warranty. They gave me a 2012 3 series loaner which is quite nice.
      04-30-2013, 09:26 AM   #6
edx1
This is now the second one I've heard of going bad...
      03-01-2014, 06:37 PM   #7
Naambezet
Netherlands
Drives: BMW X1 sDrive 20i
I had the same issue today, the engine was very jerky and the whole car was shaking when idling. Got an appointment friday for a checkup (not related to this)
      03-02-2014, 08:32 AM   #8
Yarvis
Yarvis's Avatar
Drives: 2013 BMW X1 x28i
What is the turbo wastegate issue some have complained about?
"Life is what happens to you while you're busy making other plans"......John Lennon
      03-27-2015, 04:44 PM   #9
Naambezet
Netherlands
Had this problem several times since then. They replaced the injectors under warranty and later they replaced the spark plugs ahead of the maintenance schedule. It still isn't solved, had it several times after that. Car is running on 3 or 2 cylinders, depends.
But it does really suck, it only happens with WOT and it happenned twice while I was driving on the Nurburgring
      03-28-2015, 11:14 AM   #10
Twix
Twix's Avatar
Drives: F87 LBB 6MT
2016 BMW M2  [0.00]
To add more info on this. I checked my CEL codes yesterday because of the downpipe. I had 2 wastegate codes hidden in there. They didn't cause the light to go off, but they were there nonetheless.
The codes I had were for wastegate learning: open too far and one just said fault. I also had MAF: too much air because of my aFe intake and of course, cat efficiency too low from the downpipe.
Only the downpipe caused the engine light to come on, but those two wastegate codes concern me. I'm counting the days until my wastegate pukes.
I'll try to post a picture of my print out when I find the piece of paper.
2016 M2 - 6MT
2014 X1 - Sold
2002 Land Rover Discovery II - 3" TF lift - 42" LED bar - 4" LED spots
      03-28-2015, 02:01 PM   #11
Drlu23
Drlu23's Avatar
9
Drives: X1 Xdrive 28i
Twix,
What should we expect if we feel that maybe the wastegate is going on us? Slower response, lack of power at a specific rpm range? I'm asking because I have been having high pitch sounds coming from the turbo and have been concerned. I'm not sure if this is just me or it is something that maybe on te way out.
Thanks
      03-28-2015, 09:32 PM   #12
Twix
Twix's Avatar
Drives: F87 LBB 6MT
2016 BMW M2  [0.00]
Possible bucking during high RPM shifts. That's about all we (tuning co and myself) have discovered. I have no felt loss in power or slower throttle response.
2016 M2 - 6MT
2014 X1 - Sold
      11-28-2015, 02:35 PM   #13
CERF04ZHP
Drives: e46/e84
Hey guys - wanted to resurrect this thread.
Last month my wife's X1 (N20) went into limp mode/reduced engine power a few times, so we brought it into the dealership. They diagnosed it as a faulty wastegate actuator and replaced it under warranty (17,500 mi). They told me the cause could have been brought on by "spirited driving". My wife drives like a little old lady. When I drive it, on occasion, I do lay into it a little bit, maybe passing on the highway or coming up an on-ramp, but I'm not banging it off the rev-limiter or anything.
Since the repair, it just doesn't feel the same. We just got back from a 500-mi. round trip and it seems like there's a lack of mid-range grunt. I have to press the accelerator down further in order to accelerate at the same rate, in any gear, as I did before the repair.
Has anyone experienced this? Could the dealer have recoded the computer or uploaded some sort of an output-reducing software in order to avoid a relapse?
Thanks for any input.
      11-28-2015, 05:11 PM   #14
Twix
Twix's Avatar
Drives: F87 LBB 6MT
2016 BMW M2  [0.00]
The dealer wouldn't install power reducing software. It's probably placebo effect. Could also be the trans re-learning your driving habits which can take awhile.
2016 M2 - 6MT
2014 X1 - Sold
      11-28-2015, 06:10 PM   #15
CERF04ZHP
Drives: e46/e84
That's what I thought. I'm going crazy.
Thanks man.
      12-06-2015, 07:08 AM   #16
xirsteon
Drives: X1 xDrive
Which of the x1s are n20s and n55s? What year to what year?
      12-06-2015, 09:17 PM   #17
Twix
Twix's Avatar
Drives: F87 LBB 6MT
2016 BMW M2  [0.00]
N55 is the 35i, N20 is the 28i. Although in Europe and ROW, the 28i used to be the N52 N/A 6 before late 2011. 2012, all 28i models are powered by the N20/N26 depending on your state's emission laws. The N55 has always been in the 35i variant.
2016 M2 - 6MT
2014 X1 - Sold
      12-07-2015, 07:22 AM   #18
xirsteon
Drives: X1 xDrive
Thx
