      04-17-2013, 03:51 PM   #1
LatinBimmer
Peru
133
Drives: X5 2014 Sparkling Brown
Cool Official Retrofit Xenons (here is all you need)
Hello my friends, I just got time to post this thread.
As many of you read before, I was about to make the official retrofit of xenons to my X1, so a month ago I finally did it and I am more than impressed with the changes...honestly, a BMW with halogens is another car...
To sum up, I bought my xenon headlights from ebay and went to my dealer to install them...after all discussion, they received the official part list from BMW in order to install without any errors and problems. (They installed even level sensors and adaptive on curves function).
Here is what you need: (sorry, it's spanish)
Part # Descrip Qty
63117180829 DISPOSITIVO IGNITION 2
61316932796 DISPOSITIVO MANDO LUZ 1
37146853753 SENSOR DE ALTURA 1
61138383300 CAJA DE ENCHUFE 2
61130005199 TERMINAL CONECTOR C/CABLE 6
61130006665 TERMINAL 6
37146763734 SOPORTE LH DE SENSOR DE ALTURA 1
37146763733 BRAZO TENSOR DE SENSOR DE ALTURA 1
37146853754 SENSOR DE ALTURA 1
37146791073 SOPORTE DE SENSOR DE ALTURA LH 1
37146791074 SOPORTE BARRA DE REGULAC LH 1
37146752797 BARRA REGULACION POSTERIOR 1
07119904303 PERNO DE SENSOR ALTURA 4
37146850307 JAULA PRESTOL 2
07119904371 TORNILLO HEXAGONAL 2
07129904876 TUERCA 4
61130005197 CONECTOR 0,20,5MM2 10
61130006663 CONECTOR 0,75MM2 10
61121391684 CABLE ROJO-NEGRO 9
61126908725 CABLE GRIS-VERDE 9
61126902600 CABLE GRIS-AMARILLO 15
51717002953 GRAPAS REMACHABLES (NEGRO)
6399000 REEQUIPAMIENTO FAROS DE XENON (CODIFICACIÓN)
Any questions, just let me know!
      04-17-2013, 05:33 PM   #2
aramosc
Drives: X1 S-line 28i
Part # Descrip Qty
Attachment 847738
Muy Bien! Felicidades! How much was the whole retrofit?
      04-18-2013, 11:20 AM   #3
GreatStarSe7en
GreatStarSe7en's Avatar
Drives: 2013 X1 xDrive28i Sport Line
well, hurt by "a BMW with ......" but bitterly to admit, it's the truth.
I will try to do the same thing to mine
      04-18-2013, 11:54 AM   #4
fjrmann
Drives: 2011 BMW X3 X35i
one hundred billion dollars
      04-19-2013, 08:40 AM   #5
LatinBimmer
Peru
133
Sorry my friend, nothing personal I am just trying to help
      04-19-2013, 08:41 AM   #6
LatinBimmer
Peru
133
USD 2,500
      04-22-2013, 11:46 AM   #7
GreatStarSe7en
USD 2,500
Does the $2,500 include all labor and parts? Do you mind give me the link to your ebay parts seller? Thanks a lot.
      04-22-2013, 02:52 PM   #8
LatinBimmer
Peru
133
Yes, includes everything. This guy from ebay sold me xenon headlights used like new condition. http://stores.ebay.com/Bumer-Store (500 EUR)
And here: you can find every single part at discounted prices: Info@individual-cars.com
      04-22-2013, 04:06 PM   #9
JOE YOUNG
SEAL TEAM SIX
JOE YOUNG's Avatar
Drives: E46 E90 E84 F30 X3G01 LCI
[QUOTE=LatinBimmer;13865523]Yes, includes everything. This guy from ebay sold me xenon headlights used like new condition. http://stores.ebay.com/Bumer-Store (500 EUR)
yahh right ,..except the headlight assembly,. because you bought it off ebay..
      04-22-2013, 04:21 PM   #10
LatinBimmer
Peru
133
[QUOTE=mjy2000;13865993]
When I said includes assembly/install work, I mean it. I bought the headlights from ebay, but I bought everything else from my dealer. That's why I have official retrofit, no error codes, no warranty problems, no problems at all.
I left the other link to buy parts if you find someone to install everything.. in my country there is no qualified bmw non-dealers options.
      04-22-2013, 05:24 PM   #11
GreatStarSe7en
One more question: other than 2 Xenon headlights (1 left and 1 right), I should also get all the parts you listed to finish the retrofit. Is my understanding correct?
      04-23-2013, 07:32 AM   #12
vbbuilt
Drives: x28i
How does that after-market upgrade affect your vehicle warranty? If your upgrade fails in the future, what then?
Vince.
      04-23-2013, 10:17 AM   #13
LatinBimmer
Peru
133
Yes, let me clarify.
If you retrofit xenon headlights without all these parts with a non official bmw dealer, you will always get error messages and you'll break your warranty. (besides, level sensors, adaptative curves, etc will not work).
If you take all these parts to your dealer, he will do the official retrofit and you keep your warranty. I did it and everything is ok.
      04-23-2013, 10:18 AM   #14
LatinBimmer
Peru
133
Vince.
Response in my previous post my friend. If the official retrofit fails, it will be covered. Your BMW dealer did the retrofit.
      04-23-2013, 05:08 PM   #15
GreatStarSe7en
Thank you so much for the further explanation. but I got problem looking for this last one
It doesn't look like the part number is correct. and the 2nd one from the bottom doesn't seem to be used in X1? (according to realoem.com).
please advise.
      04-24-2013, 11:05 AM   #16
LatinBimmer
Peru
133
please advise.
This one is the "part number" used locally by the dealer to Coding the retrofit. Your local dealer will assign a number when they send you the quotes.
The second one is the light switch on the panel, I had the manual level, now the new one is automatic by sensors (no level dial)
      04-24-2013, 01:04 PM   #17
GreatStarSe7en
Thank you! I'll check with my dealer and see if would be able to do that.
      04-26-2013, 04:26 PM   #18
JOE YOUNG
SEAL TEAM SIX
JOE YOUNG's Avatar
Part # Descrip Qty
Attachment 847738
TRANSLATIONS:
3117180829 IGNITION DEVICE 2
61316932796 LIGHT CONTROL DEVICE 1
HEIGHT SENSOR 1 ​​37146853753
61138383300 PLUG BOX 2
61130005199 CONNECTOR TERMINAL C / CABLE 6
37146763734 BRACKET HEIGHT SENSOR LH 1
37146763733 TENSIONER ARM HEIGHT SENSOR 1
HEIGHT SENSOR 1 ​​37146853754
37146791073 BRACKET HEIGHT SENSOR LH 1
Regulat 37146791074 LH SUPPORT BAR 1
37146752797 CONTROL BAR REAR 1
07119904303 BOLT, SENSOR HEIGHT 4
CAGE 37146850307 Prestol 2
07119904371 SCREW HEX 2
07129904876 NUT 4
61130005197 CONNECTOR 0,20,5 MM2 ​​10
61130006663 CONNECTOR 0.75 MM2 ​​10
61121391684 LEAD RED-BLACK 9
61126908725 WIRE GRAY-GREEN 9
61126902600 WIRE YELLOW GREY-15
STAPLES 51717002953 rivet (BLACK)
XENON CONVERSION 6399000 (CODING)
      06-09-2013, 04:07 AM   #19
Jori
Drives: 1series
Set for sale
http://e84.xbimmers.com/forums/showt...9#post14132509
      07-09-2013, 03:26 AM   #20
superbogel
B1990BB
Indonesia
Drives: BMW E84 + F10
I am looking into this, but my VIN number is checked and not available for my country, can that still be installed to my non xenon x1?
      07-09-2013, 03:36 AM   #21
Jori
Drives: 1series
Check this: http://e84.xbimmers.com/forums/showthread.php?t=556512
      04-14-2014, 10:40 AM   #22
nillan
Drives: 2015 X1 x28i
used housing (did they include lamps and ballasts?
hello latinbimmer,
can you please tell me if the housings you bought included the bulb and ballasts. i did not see them in the parts list.
really appreciate your help
thanks
nillan
