      02-06-2013, 12:23 PM   #1
Teleskier
Drives: '13 X1 20mpg, '01 VW TDI 55mpg
Three different MPG displays all show different values?
I have not been driving my new X1 much (in favor of my better mileage TDI old car thus far), so I have not figured out the X1 MPG displays yet. But this has me feeling a bit like a dunce - since its operation is not self obvious to me - but should be. Argh.
We have three displays that give the MPG info - "Onboard Info" vs "Trip Computer" vs the mini odometer display controlled by the stalk.
Last week or so, I chose "Reset All" from the Trip Computer menu for the very first time, but currently each of three displays seem to give me different mpg and average speed numbers?
How?
The manual explains this poorly.
What's the formula here? When is each reset?
  1. Does "Trip Computer" get reset by using different Navigation destinations? After using Nav and reaching the destination, the miles in "trip computer" show "----"? Yet I still get mpg values?
  2. Does "Onboard Info" get reset by every new tank refill?
  3. Searching the web says some BMWs have a setting for "automatic resets", but I have not seen this in our car yet, but maybe it's the default?
  4. If the above is true, where do I keep the forever info such as all my miles since last time I manually hit "Reset All"?
So what I thought was "all my miles driven getting the car new" since I never did a manual reset myself (until last week), might not have been? It might have been reset on every Nav use or every tank refill?
It doesn't help that Onboard Info doesn't include what the mileage count is beside the average speed and MPG numbers. How do I know what it is measuring - and since when?
I'll probably figure this out eventually by trial and error, but can anyone explain it to me or give me hint? It should not be this confusing. Maybe it's just me.
Teleskier is offline
      02-06-2013, 01:47 PM   #2
Teleskier
> Hold the button on the signal indicator stalk while mpg is displayed until it resets. That resets whatever's displayed only.
Found this in my web search... not sure I have done this, but maybe I did.
At least it's a start along the path toward figuring out why the three mpg numbers are different...
Update#2 - Upon re-reading the X1 manual...
1. The ECO PRO bonus range DOES get automatically reset upon a gas tank refill.
2. The reset command from Trip Computer seems to reset only the trip computer going by the section title header (no mention of the "ALL" I seem to remember from the car)
3. No mention about what resets the Onboard Info?
4. It's curious that the pictures of Onboard Info vs Trip Computer on page 71 ALSO show a difference in Average Speed (but not MPG)
Teleskier is offline   Reply With Quote
      02-07-2013, 08:02 AM   #3
Monterra
Monterra's Avatar
Drives: 09 128i 6MT
I'm thinking of ordering an X1 soon, but want to get one as a loaner to verify efficiency under my foot/commute. You really get 55 in the tdi and 20 in the x1? I'm so pissed they didn't bring a diesel for us. If I can't eke out 28-29 driving moderately (65-75) on my mostly hwy free flowing 40mi commute, I may be on to a '14 cx-5 touring- that has enough power to get out of its own way now- but still no diesel.
6MT-Montego/Terra 128i ZSP
Save the manuals, bring the diesels BMW!
Monterra is offline   Reply With Quote
      02-07-2013, 09:27 AM   #4
Rockfish66
Drives: 2013 X1 xdrive 28i
I've been able to get in the 28's mileage-wise but only on pure highway parts of a trip - by resetting the mpg display once I get up to cruising speed. Even including the acceleration up the on-ramp into the average mpg calc will keep the average to around 25. Oh, and that's using eco pro. I've found that even while highway cruising that EP mode will reduce downshifting on slight grades, improving mileage.
My X1 has only 400 miles on it so far, so I'm really hoping things improve with a little more break-in.
Rockfish66 is offline   Reply With Quote
      02-07-2013, 10:49 AM   #5
Monterra
Monterra's Avatar
Drives: 09 128i 6MT
Thanks, that's kinda frustrating- my 128 that's rated 28hwy routinely beats that, and blows through 30 on trips. Granted most of the frustration is that 33 appears to be a bold faced lie because really 28 for a 3700-3800lb awd anything that hits 60 under 7 is actually pretty darn good, but 26-27 in a 35i is even more impressive- dammit!
      02-07-2013, 12:55 PM   #6
Teleskier
Yeah - resetting the MPG calculation once you're already up at highway speed is a bogus 'more generous than real life' measurement. Based on the EPA 33-hwy, you should be seeing 35+ by doing that. I too can get 50+ mpg only measuring while coasting downhill. Just don't measure the X1 trying to climb back up that same hill.
Sadly yes. My TDI is race chipped, but never saw the mpg drop after installing the chip. Best money I ever spent. To be honest, 55mpg takes driving in an eco-pro-like mode, no jack rabbit starts, coasting to offramps on highways, etc. You know, the kind of driving I hate. What I loved about the chipped TDI however, is that even on my most "sport mode" crazy hit-the-turbo-all-day-for-fun acceleration on every start and beating 'superior' sports cars off the line at red lights (loved that) - the worst I ever saw was 48.5 mpg. Not bad for all that REAL LIFE fun!
Now on the X1 - it seems that no matter how I drive - I only get 20.something mpg. I meant to write the other day. I ran an errand in eco-pro mode where I reset all values. Mostly highway on RT2. I made a conscious effort to not step more than 33% into the gas pedal (watched the 'live' mpg needle to stay above 25mpg). It was pathetic slow and dangerous. Huge gaps open since I cannot keep up with traffic from every tiny slow down. Every car cut in front of me. Then a SCHOOL BUS cut in front of me, the gap was so big and my acceleration so poor. Rt2 inbound had no traffic stops. I coasted to every slow down. I turned my engine off manually at the two red lights (ASS will not engage for me recently). After all this eco excellence - I got a piss-poor 23.x mpg in what I'd consider the very best conditions I could be for typical (but real life) rural eco driving. On the way back, outbound Rt2 had some traffic in the rotary where it was not stopped but was 5-10mph slow while making its way around. There on that return leg, I was back to 20.x again while in eco but without the prior leg's coasting-in-neutral tricks! Nuts!
I could take going down from TDI 49 mpg down to X1 EPA 33. But real-life 49 down to real-life 20 is driving me crazy! I should be wanting to drive my new X1, not having "more acceleration and fun and better mpg to boot" in my 12-year-old old VW.
I really have to figure this out. This weekend I'm heading up for another long ski trip drive. I will reset all the numbers and watch the car like a hawk. For fun and my own science, I might try eco on the way up and sport on the way back. Something tells me both are going to be the same bad 20 mpg number. I'll also top off the tank to get the non-computer numbers.
      02-07-2013, 01:24 PM   #7
Monterra
Monterra's Avatar
Drives: 09 128i 6MT
Wow that's depressing but thanks for the in-depth coverage there. You rolling 17s or 18s- stock or winter tires? You broken in yet? Let us know how the longer trip does. I just booked my last covered service appt and they said they'd hold me an X1 28i xdrive from their fleet. If I have to hypermile the thing just to see 25 I really don't know, I'll probably press my luck (and wait) for the CX-5d or just say screw it and the CX-5g and deal with the few things I hate about it. Mostly its a pretty nice little truck, and I'm keeping the 1 so all is certainly not lost.
      02-07-2013, 04:35 PM   #8
nospam
Drives: X1 x28i; 128i; S2000
As I posted in the other thread, the MPG computed by the displays are way off in my experience. I just hit 1200 miles but I'm getting about 26 MPG combined now (calculated manually when I fill at the pump). Computer shows anywhere between 21.7 and 23.0 MPG.
Monterra, coming from another 128i owner you will be happy with the X1...much more so than the Mazda IMHO. Test drive and see.
nospam is offline   Reply With Quote
      02-07-2013, 04:49 PM   #9
Red Bread
Drives: My wife's car
Concur, we changed from a 135i to an X1 35i, and they feel very similar, as I've said elsewhere, our X1 actually gets slightly better city mileage than our N54 1er did, but slightly less hwy.
Red Bread is offline   United_States
      02-07-2013, 05:06 PM   #10
Monterra
Monterra's Avatar
Drives: 09 128i 6MT
Wow never had one be pessimistic that's crazy off. My 128 is consistently within 1mpg but always optimistic. Based strictly on test drives (already had 2 goes at each of them) I know I'll be happier in a basic x1 vs an almost loaded mazda but if I net low 20s on super it will nag me that I could have been sniffing 30 on regular in the no longer anemic 2.5l cx5. That's my quandary.
      02-07-2013, 05:30 PM   #11
HotRodW
HotRodW's Avatar
Drives: 2013 X1 xDrive28i M Sport
My computer mileage has been extremely accurate ... and extremely disappointing! Right after the miserable dealership experience, the fuel mileage is the biggest letdown. Quick? Check! Fun-to-drive? Check! Efficient? Nope!
To be fair, there are plenty of forum members who are satisfied with their mileage. Obviously, I am not one of them. I'm starting to wish I had waited for the Q5 TDI or GLK diesel. The CX-5 diesel, when/if it comes to the US, should be an impressive value if you can live without some of the extras.
HotRodW is online now   United_States
      02-08-2013, 08:20 AM   #12
vbbuilt
Drives: x28i
Out of curiousity, isn't diesel more expensive than premium? Here in Leesburg VA, for today, one local outlet is selling premium at 3.75 per gallon and 3.89 per gallon for diesel.
Factoring in MPG for X1 vs the CX-5, at the end of the day, would the CX-5 come out cheaper than the X1? Do you really get that much more value for diesel than premium? I'm not an expert on engines, but from a performance perspective, I had read that in general, diesels are not as "peppy" ? Or has technology gotten to the point where diesel engines are now on-par with turbo?
Just wondering! Thanks, Vince.
vbbuilt is offline   Reply With Quote
      02-08-2013, 09:35 AM   #13
HotRodW
HotRodW's Avatar
In my travels here in the midwest (primarily Michigan, Indiana, Illinois and Wisconsin), diesel prices are all over the place. Unlike gasoline, the prices are very inconsistent from station to station. I would say as a rule the price is close to premium, maybe a bit above. But there were times last year when diesel was not just cheaper than premium, but it could be found for less than the cost of regular unleaded.
As a rule, diesels are low HP, high torque engines. They move well off the line, but they tend to lose grunt at higher RPM's. They're great for towing and stop-and-go driving, and very efficient for highway cruising at steady rpm's. VAG diesels are known to exceed their EPA highway ratings.
The Mazda Skyactiv-D breaks some paradigms by using a lower compression ratio than a typical oil-burner. The result is a diesel that doesn't require exhaust after-treatment to meet emissions requirements. Lower compression ratio also means less stress on components, so lighter materials can be used, including the engine block which is made of aluminum instead of cast iron. Obviously I have not experienced it myself, but those who have claim it still has impressive torque, but maintains power at higher engine speeds making it behave more like a gasoline engine.
Aside from better fuel efficiency, diesels tend to maintain their value better over time. Much of the investment put in up front can be recovered at resale, and the fuel savings is gravy. Time will tell if the Mazda diesel does the same. You also have the benefit of extended driving between fill-ups, which for me would be a huge benefit.
      02-08-2013, 09:48 AM   #14
Monterra
Monterra's Avatar
Drives: 09 128i 6MT
What he said, the Passat diesel, as much as I generally loathe VW products is a great vehicle, and not at all underpowered. The power is different, much shorter rev band and sweet spot, doesn't have the rush of power building to 7k like my I6 but you can spec a manual and look on fuelly.com- these things can touch/exceed 50mpg and crack 800 miles on a tank straight hwy. Are they fun to drive? Depends on your driving and what you consider fun, but if you do a lot of miles especially hwy miles they are very compelling.
      02-08-2013, 09:50 AM   #15
bosstones
Drives: o_0
Thank you for mentioning this! I have never found the OBC (or analog gauge) readouts to be accurate on any BMW I've driven dating back to 2001. They were usually optimistic but grossly so. Since getting my MCS a couple years back, I've only been crunching the #'s of miles driven since last fill up/gallons added at next fill up.
Currently debating going with a 35i over the 28i since the few options I want are standard on it but I'm tracking you guys' reported fuel economy since that may be the great equalizer. I DD my Moupe spring thru fall and get around 19mpg of fun (manually calculated). I replaced my old ZJ (too many electrical/harness gremlins) that got slightly lower fuel economy than the Moupe with the MCS as a winter vehicle & hauling mule since I wanted something manual, fun, and with good gas mileage. Looking to replace the MCS, though, since I think it is overrated on all but fuel economy (these WS-60's are really making me hate the car, too). However, if people are simply judging mpg by the OBC, I and most people I know do not take that to be an accurate assessment. Actual fuel economy may be better or worse. I have never known anyone that hand crunched the #'s to be remotely near what the OBC reported.
bosstones is offline   Reply With Quote
      02-08-2013, 01:36 PM   #16
vbbuilt
Drives: x28i
Hottrod, thanks for the feedback and explanation! That's very helpful!
Vince.
Forum Jump
