      02-04-2013, 08:51 PM   #1
xyz100
Drives: Challenger
Radio removal pics
Found these pictures on aliexpress from the company that sells X1 GPS (Winklink). Might be useful for DIY radio upgrades.
      03-11-2013, 04:46 AM   #2
sanchaym
Drives: BMW X1 2012 December
No
No
      04-23-2014, 02:33 PM   #3
Mr Kleen
teh porcupine
Mr Kleen's Avatar
Germany
49
Drives: 2013 X1 Sdrive28i
2013 BMW X1  [5.00]
I'm searching for a DIY on removing the trim pieces (plan on wrapping the Piano Black trim with brushed silver vinyl). This is as close to instructions as I've seen in my searching, so I'm going to bump this up.
      05-05-2014, 01:23 PM   #4
PSUSMU
Drives: 2008 Porsche 911 Carrera S
I was helping my neighbor remove his CIC to install the Bimmer-Tech review camera retrofit. His console trim in #5/#6 is different. We were able to remove the center cross section with 6 buttons, because it's separate from the console. How do we remove the console surround trim?
The tabs on the left/right by the cable wire (right, unshown) are preventing us from removing the CIC.
RSI, LLC | Fender Rolling | Suspension | Engine | Other Stuff
      05-11-2014, 09:19 PM   #5
Abbie
Drives: 2013 E84
Bumping this... having the same exact problem. attaching another picture, so hopefully people can weigh in...
just to explain what the problem is...
after removing all plastic coverings, you cannot remove the CIC very easily (without braking any parts) as the black bottom trim (the one piece that's holding the cup holder) blocks the CIC unit.
any help is much appreciated!
      06-26-2015, 04:31 AM   #6
XbimE84
Drives: E84 Sdrive 2.0D
Hi,
could you tell me how you get the AC removed? I installed the fuscon bluetooth kit but without removing the AC panel and something doesnt quit fit wel
      07-03-2015, 10:22 AM   #7
XbimE84
Nobody? I tried with the prying tools, but only the bezel moves a little from the AC, I want to remove it
      02-08-2016, 06:24 PM   #8
andresilva252
Drives: BMW X1 20d sdrive
Same problem here!
