      11-26-2012, 05:31 PM   #1
M3tallicar
Drives: 4 wheels
28 vs 35 brakes?
Sorry if this has been discussed before but I didn't find the details. I have seen some comments that the 35 has different brakes from the 28, if anyone has the details of the differences I would appreciate it
M3tallicar is offline
      11-26-2012, 05:44 PM   #2
Red Bread
Drives: My wife's car
What's interesting is that RealOEM lists larger brakes up until 4/12 production for the 28iX.
X1 28iX - front - 330x24 until 4/12 and then 312x24; rear - 300x20
X1 35iX - front - 348x30; rear - 336x22
Red Bread is offline   United_States
      11-26-2012, 07:15 PM   #3
Bill B.
Bill B.'s Avatar
Drives: '12 135i, '13 X1 35i
The brakes are essentially those of the e9x 328 vs 335. As noted above, the rotors are larger for the 35, with different calipers, carriers, and lines.
Surprisingly though, as the master cylinder is the same, some clever e9x 328 owners actually have purchased 335 brake bits from those who have upgraded to big brake kits and have bolted them onto their 328s without issue.
Bill B. is offline   United_States
      11-26-2012, 08:56 PM   #4
M3tallicar
Drives: 4 wheels
Thanks! Anyone done any effectiveness comparisons?
Tough to choose between them, each has its strengths and weaknesses.
M3tallicar is offline   Reply With Quote
      11-26-2012, 09:25 PM   #5
nospam
Drives: X1 x28i; 128i; S2000
Interesting discussion.
What are the stopping distances of the 28i vs 35i?
nospam is offline   Reply With Quote
      11-26-2012, 10:02 PM   #6
Bill B.
Bill B.'s Avatar
Good question. I would assume the comparison would be similar to the (e9x) 3 series differences. The 328 actually performs better in stopping distance tests compared to the 335.
      11-27-2012, 01:00 PM   #7
Lucky13
Lucky13
Drives: E93 335i
I don't know about stopping distance but I am still amazed that there is almost no brake dust due to the ceramic brakes. My E93 wheels are dirty in 2-3 days with 50 miles driving while we can drive the X1 hundreds of miles and the wheels are still clean.
1995 325i,1996 328ci,1997 528i,1997 Z3 2.8,
2001 X5 3.0,2001 330i Conv,2002 M3 Conv,
2003 M3 Coupe,2004 M3 Coupe,2004 Z4 3.0,
2004 X3 3.0,2007 X3 3.0,2007 335i Conv.,
2013 X1 28 sdrive M Sport
Lucky13 is offline   United_States
      11-27-2012, 01:54 PM   #8
Red Bread
Great point, the X1 does not dust nearly as much as any of our previous BMW's. After driving both the 28i and the 35i, the brake pedal feel on the 35i felt much better, same as the F30's we drove. I'd suspect that any 328i braking advantage in magazines was due more to different tires than the lighter weight of the 328i and would also more than disappear after repeated stops.
      11-27-2012, 02:06 PM   #9
Bill B.
Bill B.'s Avatar
When was the last time you put pads on the e93? I've been wondering if the new composition has been offered as a replacement for the older models?
      11-27-2012, 02:07 PM   #10
Red Bread
We got new pads and rotors on our 1er shortly before selling it and if they were better, it was a really, really small difference.
      11-29-2012, 10:41 AM   #11
javajaws
javajaws's Avatar
Drives: 2010 335i AW/Saddle/msport
I'm used to the brakes on a 2010 335 and when I test drove a X1 sDrive28i the other day I thought they felt a little underpowered. Sort of reminded me of my old 325.
I plan on driving an xDrive35 today, I'll let you know how they feel.
javajaws is offline   Reply With Quote
      11-30-2012, 03:50 AM   #12
dicker
dicker's Avatar
Drives: '13 X1 35i
Send a message via AIM to dicker
I think the OEM pads don't bite enough. My xDr35i has the worst brakes I've ever had on a BMW.
dicker is offline   United_States
      11-30-2012, 10:05 AM   #13
Bill B.
Bill B.'s Avatar
Yeah, you do give up that initial bite that the old dusty pads had, but frankly, I'm lazy enough to admit that it's a trade I'll gladly make for not having to clean the @#$%*! wheels every three days.
      11-30-2012, 10:33 AM   #14
Red Bread
Hmm, I actually like the pedal feel and feedback much more than the 135i's brakes, which were very disappointing given their design. These feel very similar to my M Coupe's brakes, which have been my favorite both on the street and the track.
      11-30-2012, 10:47 AM   #15
Bill B.
Bill B.'s Avatar
Really? What year 135i?
      11-30-2012, 10:56 AM   #16
Red Bread
2008, but they all have the same brakes. Stopping distance were okay, but pedal feel and heat soak were a big problem with them. This has been common with recent Brembo fixed caliper setups. The ceramic pistons on the 135i, pads on the 370Z and general design on the STI and EVO setups have all caused various issues.
BMW's normal single piston design may not be glamorous, but they do work fairly well. I'm not sure what BMW's goal with the 135i brakes was, maybe they just knew it would be a relatively small sample and they were testing whether multi piston setups made much of a difference in terms of the covered maintenance interval? I suppose they do seem to have adapted more multi piston setups, with the F30 335i going to them and the M5. I assume the F80 M3 will come with them too.
      11-30-2012, 09:52 PM   #17
nospam
Though the brakes felt solid in normal use, their performance in testing wasn't as impressive. The lighter xDrive28i required 134 feet to come to a stop from 60 mph, while the xDrive35i needed 126 feet. A 3839-pound 2013 Acura RDX we recently tested needed a good deal less room to stop, at 117 feet.
Read more: http://www.motortrend.com/roadtests/...#ixzz2DlJSc3wB
      12-01-2012, 12:15 AM   #18
nospam
Range Rover Evoque:
Braking, 60-0 mph:
128 ft, 4-door
125 ft, 2-door
http://www.motortrend.com/roadtests/...r_evoque_test/
      12-01-2012, 02:47 AM   #19
Jossen
Jossen's Avatar
Drives: X1 to come...
So would the BMW performance brake system make a huge impact performance-wise?
Is it compatible with my double set(I bought a winterset at half the price too) of BMW-OEM 17 inch rims?
Jossen is offline   Reply With Quote
      12-01-2012, 09:30 AM   #20
Grovsnus
Drives: Le Mans blue X1 35i
Range Rover Evoque:
Braking, 60-0 mph:
128 ft, 4-door
125 ft, 2-door
Stop distance, shmop distance.
The actual brake distance to 0 isn't as important as many seem to think. When did you see an accident where the vehicle failed to come to a full stop, not counting fender-benders by tailgating idiots?
What's more important is the ability to steer well while decelerating. That way you don't get that fender-bender because you were tailgating, as you can avoid the vehicle that stopped. And you avoid the risk of some of the more serious accidents too, like hitting an oncoming vehicle (or a tree!) dead on because panic braking reduced steerability.
Grovsnus is offline   No_Country
      12-09-2012, 07:00 PM   #21
TKM399
Drives: 2007 GL450, 2013 X1 X28i
Braking from 70-0mph: 189 feet
I'm confused. I have not seen any other reviews slam the X1's braking, yet.
http://www.caranddriver.com/reviews/...8i-test-review
TKM399 is offline   Reply With Quote
      12-09-2012, 09:49 PM   #22
Monterra
Monterra's Avatar
Drives: 09 128i 6MT
70-0 in 189 is pretty bad. While 10 or 20 feet might not make the difference as noted earlier, you do feel that difference and that feel inspires confidence and having confidence when the shit suddenly hits the fan is a good thing.
6MT-Montego/Terra 128i ZSP
Save the manuals, bring the diesels BMW!
Monterra is offline   Reply With Quote
Forum Jump
