FORUMS
- 5
| 11-14-2012, 04:56 PM | #1 |
Photographer
Fog Lights
DO any of you know how to change out the fog lights ?
Is there an easy way? Maybe im looking in the wrong spot to do it....... ![]()
| 11-16-2012, 04:07 PM | #3 |
Photographer
Ok I have given up on these fog lights and going to put a call into my service guy and see if he can hook me up ! I have cut my hand up trying to get to the lights. I found the place in the wheel well but its almost impossible to get too as you don't know what your pulling on....
| 11-20-2012, 03:01 PM | #4 |
Easy, there's two way, thru the engine bay or thru the wheel well cover.
The Left side you can't get to thru the engine bay, you have to turn to get the fog light loose. Right side can be reach from inside, same thing turn and unplug from harness. |
| 11-20-2012, 10:00 PM | #5 | |
| 11-20-2012, 10:04 PM | #6 | |
Photographer
| 11-21-2012, 01:27 AM | #7 | ||
Cfrem15
Drives: E84 N55 Join Date: Aug 2011
Told you guys just go with Lamin-x not worth getting all cut up!! |
| 01-05-2013, 06:10 PM | #8 |
OK, I had another go at this today, and in fact you can access the fog light bulbs from inside the engine compartment, but it's a tight squeeze. It helps if you have skinny arms.
The passenger side is the more readily accessible one, but I did have to temporarily disconnect the headlight wiring harness to provide extra space for my arm. Just stick your right arm down behind the headlight cluster, then reach forward. Accessing the driver's side fog light required opening the air filter housing and lifting the front portion out of the way. I also disconnected the headlight wiring harness, but this side seemed a bit roomier for my left arm. You'll have to remove and insert the bulbs by feel alone, as you can't see them at all from above. This is tricky, but not impossible. Just keep track of the fully seated and open positions before removing the old bulb, then reverse the operation on reinstalling the new bulb. I wore rubber gloves to keep from touching the bulbs with my fingers, and to fully protect the bulbs as I manoeuvred them up to the openings. Be sure not to scrape the sides of your bulbs when inserting them into the openings, or you may scratch off the coating (if any) on your bulb. Good luck! |
| 02-11-2013, 10:15 AM | #11 |
I changed my fog lights bulb by lifting up my car and access thru the factory suggested spot under the fender. Turn the wheels to opposite side and access could be easy. I have changed my bulbs to a pure yellow bulbs which are only HKD 110 dollars. Ran it for over 24 hours and still running well.
| Bookmarks |
