FORUMS
- 5
| 11-04-2012, 05:17 PM | #1 |
Drives: 2012 X1 xDrive28i All Packages Join Date: Dec 2009
Winter tires/Wheels installed (pictures)
Hi,
I just installed my winter wheels. 17x7.5 MSW Type 22 BLK PAINT 225/50R-17 Michelin Pilot Alpin PA2 ZP Run Flat Quick Question. I Have the Sport Package with 18" Wheels. The inflate PSI is 35\front and 38\back. Does someone can tell me if I should inflate my tires with the same pressure since I installed 17" wheels instead of 18" ? This is somes pictures of before and after : |
| 11-04-2012, 09:29 PM | #3 |
WU -- Wuerzburger license plates , I've been there couple times .... Bavaria ...
2012 E84 Sapphire Black xDrive28i with Premium ,Comfort Access, PDC,Electrical Seat/Memory
| 11-04-2012, 09:31 PM | #4 |
![]() Drives: 2013 X1 xDrive28i M Sport Join Date: Sep 2012
Looks good. Any problem resetting your TPM system? Mine won't reset with the winters.
BTW, I'm using the factory pressure settings until instructed otherwise. Last edited by HotRodW; 11-04-2012 at 09:37 PM. |
| 11-04-2012, 09:49 PM | #5 |
HottRodW, does your US spec car have tire pressure sensors? In Canada we only have flat tire monitors (detects flats via speed of wheel spin).
| 11-04-2012, 09:58 PM | #6 | |
Sorry, sfillion - I'm not trying to jack your thread. |
| 11-04-2012, 10:37 PM | #7 |
OP, How is the fitment with the brakes? To answer your question about tire pressure - they should be the same as your factory 18s. |
| 11-05-2012, 11:21 AM | #13 |
Nice wheels!
did you order them on Tirerack? I tried some RTX Berlin replica on my X1 and they don't fit... ![]() So i am looking for other wheels and i don't want to buy other wheels that don't fit. I have also the sport package with the 18' wheels, even if it seems that it doesn't change anything about the brakes diameter. Thanks |
| 11-05-2012, 02:40 PM | #14 | |
However, now I'm concerned about the tire monitoring and whether this'd work on a US spec car. HotRod, did you contact TireRack, were they able to confirm/resolve the issue with your set? |
| 12-07-2012, 08:50 PM | #18 | |
| 12-07-2012, 09:49 PM | #19 | |
![]() ![]() ![]() Drives: X1 x28i; 128i; S2000 Join Date: Jul 2010
| 12-08-2012, 07:36 PM | #20 | |
| 12-12-2012, 02:42 PM | #21 |
| Bookmarks |
