      10-30-2012, 12:29 PM   #1
bbg2d
bbg2d's Avatar
9
Drives: X1 35i Sport Line
Performance control retrofit?
Would it be posssible to retrofit the Performance Control off of the M-sport package onto the xLine or Sport Line?
      10-30-2012, 01:19 PM   #2
kychungkevin
Drives: BMW X1 xdrive28i
I want to know that too. Dealer would not do it.
      10-30-2012, 02:17 PM   #3
conceyted
conceyted's Avatar
9
Drives: 2013 X1
Can someone explain what this even is?
      10-30-2012, 03:06 PM   #4
dchao
Drives: BMW X2 M35i
When you're going around the corner, it works in conjunction with braking control to help you steer around the corner.
If you are turning right, it will boost the power the the left rear wheel, to introduce a controller-able amount of oversteering. Vice versa when you are turning left.
In the price list, it can only be added in combination with the sport suspension. So I doubt it can be retro-fitted.
      10-30-2012, 04:48 PM   #5
conceyted
conceyted's Avatar
9
Drives: 2013 X1
I didn't even see this option when I ordered my X1. Is this on US models?
      10-30-2012, 05:44 PM   #6
kychungkevin
It is standard on M sport.
From what I understand it is only a software program using the AWD distribution, traction and stability control; no hardware changes. So technically it can be retrofit?
      10-30-2012, 07:07 PM   #7
conceyted
conceyted's Avatar
9
Drives: 2013 X1
If it is software, then people on the coding forum can tell you whether or not it can be enabled via software. If it truly is just software, then it can be enabled.
      10-30-2012, 07:58 PM   #8
dchao
Drives: BMW X2 M35i
On the price list, the upgrade costs only $100. So it has to be a software job.
      11-01-2012, 02:52 PM   #9
DWB1873
Drives: X1 20d xDrive Auto
I have it on my 2011 x-drive 20 - sports suspension is not required. X-drive however is.
I've not driven as X1 without it, so I don't know how much of a difference it actually makes - I just liked the idea of it - bit like steering a tank
      11-01-2012, 06:34 PM   #10
bbg2d
bbg2d's Avatar
9
We have a coding-specific forum? Color me surprised. Where at?
      11-02-2012, 02:03 AM   #11
Jossen
Jossen's Avatar
Drives: X1 to come...
Yeah please give the link to the specific forum! Would like to know more about the Apps - and actually just plugin for Ipod interface!
      04-12-2013, 07:25 AM   #12
li21
Drives: X1
Any updates on this?
      04-17-2013, 10:20 PM   #13
li21
Drives: X1
this says it is a retrofit item:
http://www.realoem.com/bmw/showparts...=33&fg=95&hl=1
unfortunately the dealer here in Australia told me its not available as a retrofit *in Australia*
might have more luck overseas.
      04-29-2013, 05:53 AM   #14
li21
Drives: X1
Got quoted $1308 for retrofitting this by my BMW dealer
It sounds like completely software related encoding
Anyone have a cheaper way to do this?
      05-02-2013, 03:11 PM   #15
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [5.66]
The performance control is present on the X3 Msport without the sport suspension
      05-02-2013, 05:57 PM   #16
LatinBimmer
Peru
133
Drives: X5 2014 Sparkling Brown
is this only for diesel or gasoline?
      05-02-2013, 06:49 PM   #17
li21
Drives: X1
It's for any Xdrive
      05-02-2013, 06:50 PM   #18
Teemo Panda
2013 BMW X3  [5.66]
Originally Posted by li21 View Post
It's for any Xdrive
This ^
      05-02-2013, 06:54 PM   #19
LatinBimmer
Peru
133
thanks...
      06-18-2013, 11:32 AM   #20
li21
Drives: X1
Anyone have any updates?
I tried my luck on a BMW coding forum but they are all bastards on there who sneer at anyone who doesn't read the whole forum to learn for themselves.. I just don't understand the technical stuff..
      02-18-2014, 07:36 PM   #21
li21
Drives: X1
Bump?
Anyone have any info on this?
      02-20-2014, 02:55 PM   #22
BeemerX1
Belgium
14
I found this:
http://www.realoem.com/bmw/showparts...g=95&lang=enUS
I will call the BMW dealer tomorrow. I want to know if my car has it or not. If not, I want it if not to expensive, on RealOEM it seems to be a hardware unit (control unit?) and some recoding with it.
